23 Pages V  « < 18 19 20 21 22 > »
Facets (foo_facets), Media library viewer
grimstermcnasty
post Oct 31 2012, 16:11
Post #476
Group: Banned
Hello. I can't get the 'Ignore leading "The" when sorting' option to work. All of my tags user lowercase everything, if that matters. Does it also ignore a's and an's? Is there a way to apply it to only certain columns (I might want the artist column to ignore "the" but not the album column)? Any help is appreciated.
BenB
post Oct 31 2012, 18:37
Post #477
QUOTE (grimstermcnasty @ Oct 31 2012, 10:11) *
Yes, that matters as it's case-sensitive.
No, it does not.
No, there isn't per column settings for the option.
If the tags in question have single values, then you can manipulate them fairly easily with title formatting. If multi-value tags are involved, then as I noted in this post, you may have to manipulate the individual values to obtain what you want. Bear in mind as I stated in that post, if you manipulate individual values as illustrated there, foobar cannot do remapping when tags aren't present.
The Title Formatting Reference is here.
[RANT]
I really wish people would format their tags how they want them to display (and bear the consequences) or start using sort tags instead of trying to manipulate their tags to the umpteenth degree with title formatting or expecting component developers to do it for them.
[/RANT OVER]
This post has been edited by BenB: Oct 31 2012, 18:50
Hazey
post Oct 31 2012, 22:33
Post #478
QUOTE (q-stankovic @ Oct 31 2012, 11:49) *
@hazey
not possible!
Thanks. I thought so, but was hoping that there's a way.
Moth
post Nov 2 2012, 06:59
Post #479
@Hazey You and me both as well as a few others. The creator of the plugin doesn't like the idea or finds it redundant, I can't remember so don't quote me.
zradu
post Nov 16 2012, 15:12
Post #480
Online troubleshooter report about this:
foobar2000 troubleshooter
The following components found on your system are known to be problematic and should be either uninstalled or updated to their latest versions:
foo_facets.dll : Facets 1.0
Reason: Repeated crash reports.
This post has been edited by zradu: Nov 16 2012, 15:13
godrick
post Nov 18 2012, 19:38
Post #481
facets is essentially nonfunctional with 1.1.17 in my DUI setup. I get a permanent deadlock, and CPU jumps to 50%, with no crash report every time I try to select any facets column when anything is playing. Only way to get out of it is to kill the process. I can navigate the facets columns and view the updated library selection playlist in Simplaylist without problems when nothing is playing. I have not made any other layout or configuration changes recently other than updating to 1.1.17. Removing and reinstalling facets after 1.1.17 install had no impact on the problem. Reverting to 1.1.16 makes the problem go away for a time, but the same behavior can ocassionally now trigger the same crash. Prior to 1.1.17, I don't recall seeing this crash with 1.1.16 or any other version, so one of the recent crashes may have corrupted something. No idea if this is a facets or core issue, but I reported it here since the use of facets triggers the crashes.
This post has been edited by godrick: Nov 18 2012, 19:46
mjm716
post Nov 21 2012, 20:02
Post #482
QUOTE (Bl@ck_warrior @ May 5 2011, 18:52) *
Hi there,
It would be great to have the possibilities to configure for the "Ignore leading "The" when sorting"
I really like this feature, but I'd like to be able to have the same behaviour with "Les, La, Die, Le".
I second this feature request. Especially as swap/strip commands are so inconsistently handled (e.g. fields with multiple values)
Perhaps instead of the "Ignore leading 'The'" checkbox, it is a field so one could enter multiple values to ignore?
This post has been edited by mjm716: Nov 21 2012, 20:04
diypig
post Nov 22 2012, 15:29
Post #483
i think it would be really nice if it was possible to have a separate search bar. there are others you can install as components, but they will only work in the playlist, not the facets album view, right? or is it possible to have a search bar control the facets library?
(i want to have the search bar in a different place on the screen, not attached to the facets ui)
but regardless of that, thanks a lot for this, i can tel a lot of work has gone into it and it is very nice!
Erich_2
post Nov 22 2012, 16:18
Post #484
QUOTE (joshuatm @ Nov 22 2012, 15:29) *
i think it would be really nice if it was possible to have a separate search bar. .... or is it possible to have a search bar control the facets library?
Facets toolbar = search bar
Help: "Facets toolbar"
diypig
post Nov 23 2012, 12:50
Post #485
QUOTE (Erich_2 @ Nov 22 2012, 15:18) *
hmmm ok, so is it possible or not? maybe i do not understand you, or maybe you did not understand my question? thank for your taking your time to reply though, any help is appreciated smile.gif
Emcee
post Dec 14 2012, 15:25
Post #486
Feature request: Reset button to reset all panels with one click.
Regards.
neothe0ne
post Dec 15 2012, 01:43
Post #487
If Frank Bicking is still around and willing to continue development, I would like to see loading of Facets changed... if Facets is not a panel in Default UI, every time you bring it up via Library menu > Facets, it has to reload from scratch. I hope there's a way to make it stay loaded.
mjm716
post Dec 17 2012, 13:31
Post #488
QUOTE (neothe0ne @ Dec 15 2012, 02:43) *
Related to this (in DUI) is that Facets reloads *every time* any writable change is made to an item.
e.g. changing a tag value or even renaming files.
It would be AWESOME if facets could maintain the location view at time of change, as currently whenever a change is made, it resets the view to the top of the list.
e.g. in an alphabetical example, if I edit something in the 'S's', after the change, I'm reverted back to seeing '#'s/A's' and must manually scroll back to my previous position.
(not to mention the delay as the entire thing is reloaded, which is considerable on large collections, which for me means a 6-10 sec pause for every little edit I make to my collection)
[I've asked Santa, so we'll see if I've been good or not.]
Beavis04
post Jan 3 2013, 02:55
Post #489
How does one get the Various Artists to group together?
No matter which mode I put it under, the Compilation albums are split up under each artists so I'm getting the same album appearing 16 times in my list...is it possible to merge it?
BenB
post Jan 3 2013, 03:27
Post #490
QUOTE (Beavis04 @ Jan 2 2013, 19:55) *
Make sure your various artist albums have an ALBUM ARTIST tag. The tag should be consistent for the album and could be VA, Various, Various Artists or whatever you prefer.
Alternatively, you could add an ITUNESCOMPILATION tag with a value of 1 to those files. foobar will automatically write "Various Artists" to the album artist tag.
Facets does not determine how the files are grouped in the playlist. This is determined by the group script you're using. I suggest changing %artist% to %album artist% in the script. You do not need to add an album artist tag to all of your albums for this, only your various artists albums. foobar will look for an album artist tag and upon not finding one will use the artist tag instead.
This post has been edited by BenB: Jan 3 2013, 04:02
Beavis04
post Jan 5 2013, 01:42
Post #491
Thank you Ben.
AvtomatAK
post Jan 5 2013, 12:44
Post #492
When I add a few songs from Library to Playlist by drag-and-drop they are added in some strange order (I couldn't get the sorting pattern), not as they are sorted in Facets at the moment.
For example, I want to listen some artists favorite songs - I select this artist in Facets, then click on Played Count column header to sort them, then select let's say 20 top songs and drag them into playlist. When I do it songs are added in random order, so first one may be the song with 5 plays, 2nd - with 40 plays, 3rd - with 20 plays etc, not in decreasing order (40 -> 20 -> 5 -> ...) as they were displayed in Facets.
I don't know whether it is issue of Facets or SimPlaylist, which I use, but I hope someone could help me to find how to fix it, if it is possible.
BenB
post Jan 5 2013, 18:09
Post #493
QUOTE (AvtomatAK @ Jan 5 2013, 05:44) *
... then select let's say 20 top songs and drag them into playlist. When I do it songs are added in random order...
Files are always sorted by the default sort as defined under Preferences > Shell Integration > Sort incoming files by when you add them to a playlist. That randomness isn't as random as it seems. Neither Facets nor Simplaylist has any effect on sorting in a playlist.
The solution for you is temporary sorting. Temporary sorts can be found in the right-click context menu under Sort (they can also be found via the main menu under Edit > Sort). In any case, select the files and in Sort select Sort by.... In the box that opens, enter %play_count% followed by any other criteria you want to affect the sort and click 'OK' to apply it.
This post has been edited by BenB: Jan 5 2013, 18:11
AvtomatAK
post Jan 5 2013, 18:13
Post #494
QUOTE (BenB @ Jan 5 2013, 19:09) *
Thank you very much! This really helps.
I changed sort order to $sub(1000, %play_count%) so now it is sorting as I wanted - most played at top, less played - at bottom, when I add songs to playlist.
This post has been edited by AvtomatAK: Jan 5 2013, 18:25
roc
post Jan 9 2013, 23:53
Post #495
When right-clicking on a facet filter entry, and selecting "send to new playlist", is there a way to have this newplaylist named the same thing as the filter entry (so for example if you have a filter with Genre, and right-click on the "Pop" entry -> "send to new playlist" it names the newly created playlist "Pop").
This behaviour is how ColumnsUI filters work.
Could this be incorporated or someone tell me a workaround?
Another issue regarding playlists is that using ColumnsUI there is a 'File' -> 'save all playlists' command, whereas in my current DefaultUI + Facets setup you can only save one playlist at a time?
Thanks in advance!
tpijag
post Jan 10 2013, 01:04
Post #496
Can not help with the first. For second, Shift+File will give you a save all option.
roc
post Jan 10 2013, 01:55
Post #497
Many thanks tpijag! Spent days adding / removing components (without losing facets, or using columnsUI) to try and get that functionality!
Now if I can find a way to have the playlists that are created from the filters to be named without typing each one out then I will be able to fully migrate over to the latest foobar2000 with DUI+Facets! Hope someone can help me out on that!
QUOTE (tpijag @ Jan 10 2013, 00:04) *
BenB
post Jan 10 2013, 01:57
Post #498
QUOTE (roc @ Jan 9 2013, 16:53) *
That behavior is how ColumnsUI filters work.
Not via a right-click. You can go into the Facets options and bind this behavior to a double or middle click.
roc
post Jan 10 2013, 02:13
Post #499
Thank you BenB!
I also found out that "send to new autoplaylist" after right-clicking on the filter entry creates an autoplaylist with the same name as the filter, which is fine for my purposes also.
So I'm all sorted now. Thanks all for the help!
QUOTE (BenB @ Jan 10 2013, 00:57) *
djchristian
post Jan 14 2013, 05:31
Post #500
What is Facets anyway and was is it for?
Please someone explain that to me!
RSS Lo-Fi Version Time is now: 15th September 2014 - 10:42
