Multichannel audio quality
~*McoreD*~
post Nov 30 2003, 05:13
Hi there guys,
When I was suggesting 128kbps Windows Media Audio 9 Professional would be enough for "CD Quality" to convert an AC3 file (which is extracted from DVD), one of my friends said:
I don't think 128kbps is good enough for encoding 5.1 sound. Think about it. 128 / 6 is 21.3. That's 21.3 kbps for each channel. That's the equivalent of encoding stereo sound at 42 kbps. I really don't think that's enough. I would recommend 384kbps for 5.1 sound. That's more like 128kbps for stereo and will sound much better.
My question: Is it how it works?
If that's correct we will need 384kbps at least in order to deliver 64kbps for each channel.
Thank you,
McoreD
Edit: Thanks guys for all your replied. Always learning something new. smile.gif
This post has been edited by ~*McoreD*~: Dec 24 2003, 02:15
rjamorim
post Nov 30 2003, 13:21
Rarewares admin
QUOTE (~*McoreD*~ @ Nov 30 2003, 02:13 AM)
No. Your friend ignored the existance of Multichannel Decorrelation.
This encoding technique means that the encoder encodes the redundancy among the channels only once, since it's a waste of space encoding this information on each channel separately.
That means something like: if you encode a stereo stream at 128kbps, the encoder encodes one stream "alone" at 56kbps, the other at 56 too, and the redundancy between them at 16 (56+56+16=128), giving each channel an actual bitrate of 72 (56+16) and not 64. (I hope I made myself clear)
AAC supports this technique, and WMA Pro probably does as well. Ogg vorbis does support, but it isn't implemented in the encoder yet.
I think a bitrate around 256-320kbps would be better for good quality.
This post has been edited by rjamorim: Nov 30 2003, 13:25
http://www.rarewares.org
JohnV
post Nov 30 2003, 14:11
Also LFE (Low Frequency Effect) channel is the supporting bass effect channel which probably doesn't take lots of kbps at all.
Juha Laaksonheimo
Latexxx
post Dec 2 2003, 16:31
A/V Moderator
Microsoft claims(http://www.microsoft.com/windows/windowsmedia/9series/codecs.aspx) that wma pro @ 192 - 256 would be similar to 384kbps ac3.
rjamorim
post Dec 2 2003, 16:34
Rarewares admin
QUOTE (Latexxx @ Dec 2 2003, 01:31 PM)
Microsoft also claims WMA std has the same quality of MP3 at half bitrate.
2Bdecided
post Dec 2 2003, 17:00
ReplayGain developer
QUOTE (rjamorim @ Dec 2 2003, 03:34 PM)
Yes, but the former is more believable, if not proven (yet).
Ivan Dimkovic
post Dec 2 2003, 17:18
Nero MPEG4 developer
In 5.1 channel config you have following situation:
2 channel pairs (L, R and L', R')
1 single channel ( C )
1 bass, or, LFE channel
In a coding system which does not use so-called inter-channel "coupling" you can figure it out by:
bit rate = 2 x stereo bit rate for same quality + 1 mono bit rate for same q + X, where X is only few kb/s for LFE...
So, for, say AAC - to achieve quality of 128 kb/s, stereo:
2 x 128 + 64 + 1 Kb/s = ~ 320 kb/s very close to, actually 321
For MP3 you would need:
2 x 160 + 80 + x... = ~400 Kb/s for the same quality
For HE-AAC:
2 x 48 + 32 (because of coupling channels need less) = 128 Kb/s
For MP2:
2 x 256 + 128 = 640 Kb/s
Etc...
This post has been edited by Ivan Dimkovic: Dec 2 2003, 17:22
Latexxx
post Dec 2 2003, 20:37
A/V Moderator
QUOTE (rjamorim @ Dec 2 2003, 07:34 AM)
The page, which I am referring to, isn't ment to be read by some lamers who believe that xing mp3 is listenable at 96 kbps. Its target audience is most likely to be big-scale broadcasters and tv companies because it compares wm9 to mpeg2 at broadcast bitrates instead of saying something like "mpeg-4 quality at half bitrate".
This page might give even some correct information because most of their claims are believable even when thinking mpeg-4.
RSS Lo-Fi Version Time is now: 2nd October 2014 - 15:27
