16 Pages V  « < 5 6 7 8 9 > »
Which is the best lossless codec?, Discussion thread
Digga
post Apr 13 2005, 17:45
Post #151
QUOTE (rjamorim @ Apr 13 2005, 05:27 PM)
Oops, sorry about that. Actually 57% is the line.
In the comparision, I replaced "Compression efficiency not on par with other lossless codecs" with "Relatively slow encoding" (that is, comparing to other codecs that compress much more at same speed). I think it's fairer towards FLAC. Do you agree?
that's one (nice) possibility. however, it seems that compression efficiency is really not on par, so I would have just added this to WavPack also smile.gif
Nothing but a Heartache - Since I found my Baby ;)
smack
post Apr 13 2005, 17:47
Post #152
QUOTE (Skymmer @ Apr 12 2005, 08:53 PM)
Well I don't want to say that you lie but probably you're just little bit confused. I've tried MultiFrontend and LA Frontend with APEv1/APEv2 tags and also Foobar's Diskwriter Commandline Encoder with selected APEv2 tag and found that Winamp doesn't support APEv2 tags. Tried both 0.4 and 0.4b. Foobar does but it's more native Foobar functionality than support from format. Furthermore official documentation of LA says: ID3 v1.1 tagging support
Uhm, you are right. LA's Winamp plugin does NOT recognize the APE2 tags. Sorry, I didn't intend to spread false information... blush.gif
rjamorim
post Apr 13 2005, 22:27
Post #153
Rarewares admin
QUOTE (Digga @ Apr 13 2005, 01:45 PM)
Well, feel free to edit the Wiki article. That's another reason I moved there - that is, so that it doesn't stay in one man's hands and therefore is subject to his bias.
http://www.rarewares.org
Jan S.
post Apr 13 2005, 22:38
Post #154
Wiki page is here now: http://wiki.hydrogenaudio.org/index.php?ti...less_comparison
comparison was misspelled before.
jcoalson
post Apr 13 2005, 22:43
Post #155
FLAC Developer
QUOTE (rjamorim @ Apr 13 2005, 11:08 AM)
BTW: It's important to mention that efficiency is not compression ratio. Efficiency is a relation between compression ratio and encoding speed.
efficiency is not defined in the doc, it might clear things up. more helpful I think would be rating "encoding efficiency" and "decoding efficiency".
Josh
Digga
post Apr 14 2005, 06:35
Post #156
QUOTE (jcoalson @ Apr 13 2005, 10:43 PM)
decoding efficiency = fast decoding / decoding complexity (system resources usage)?
rjamorim
post Apr 15 2005, 22:45
Post #157
Rarewares admin
Hello. I'd like to inform you that I replaced the PNG table with a Wiki table, with lots of help from Jan S.
Check it out here:
http://wiki.hydrogenaudio.org/index.php?ti...omparison_Table
So, no more need for the Excel spreadsheet and the PNG image. People can edit the table directly (but be very careful when doing so, as it is easy to break everything with a misplaced |).
The only modification from the recent PNG table is that now TTA has "average" software support. I changed that after it came to my attention that no audio editor supports it.
So, clarifying how each codec gets the software support ranking:
"Bad" is when only a handful of players support this format, or even worse, only the player provided by the manufacturer (E.G, Real Lossless and, until recently, ALAC)
"Average" is just average support. A few players, no editors, etc.
"Good" ranking requires that a) the format can be played on more than one platform, preferably with several players and b) it can be imported and exported by an audio editing application.
"Very good" is not really quantifiable. You just know that format has that ranking, from the amount of applications supporting it in several different platforms.
Questions? Comments?
Regards;
Roberto.
This post has been edited by rjamorim: Apr 15 2005, 23:37
saverio
post May 2 2005, 10:18
Post #158
Hi, Roberto. Great guide. I'm starting a lossless conversion (in the sense that I'm starting to encode new things in lossless, almost like a religious conversion). As I'm on a mac, I'll stick with ALAC.
Just a pair of comments and a question:
1) ALAC is supported in linux (and maybe in gnu/hurd) there is a debian package called "la" that decodes apple lossless. Oh, well it is decoding. Said nothing.
2) ALAC is very fast on encoding. For me (G5@1,8GHz) it is 16x minimum when I'm not encoding H.264 video.
Now the question:
What is ALS? I could not get sensitive info using the search function. Is this a new format? (I thnk not, because it is not on the table) or just a cuesheet-like thingie for some other format?
Wish-list: ALAC/MP4 (and AAC/MP4) supporting internal cuesheet, as to have one file in the hard disk, but the whole album in the library (implementing also gapless automatically).
Busemann
post May 2 2005, 10:33
Post #159
ALS is a new lossless format that is developed for the MPEG 4 group to be a new ISO standard. Too bad it hasn't been standardized yet, as all major companies have made their own codecs by now.
Perhaps more interesting is the other effort by the MPEG4 group, the SLS codec. It is a hybrid codec based on AAC, so it can be played back on anything that plays AAC.
Mr_Rabid_Teddybe...
post May 8 2005, 18:05
Post #160
I see you added an "Oddball Formats" section to the Lossless comparison Wiki page. But not even there did Bonk or RKAU make it.... Poooor things! crying.gif
"ONLY THOSE WHO ATTEMPT THE IMPOSSIBLE WILL ACHIEVE THE ABSURD"
- Oceania Association of Autonomous Astronauts
Busemann
post May 8 2005, 18:07
Post #161
ALAC should be updated to reflect the changes made in QT7. This has to go at least:
Doesn't support multichannel audio and high resolutions
rjamorim
post May 8 2005, 18:55
Post #162
Rarewares admin
QUOTE (Mr_Rabid_Teddybear @ May 8 2005, 02:05 PM)
Haha. That just shows it's about time I add those formats to ReallyRareWares tongue.gif
Thanks, I just added them to the lists.
QUOTE (Busemann @ May 8 2005, 02:07 PM)
Ah, that's very interesting indeed. You tested it on multichannel and high resolution (96kHz/24bit) streams?
Busemann
post May 8 2005, 19:28
Post #163
QUOTE (rjamorim @ May 8 2005, 09:55 AM)
I tried a 96kHz stereo stream from archive.org, but it lists up to 192kHz and 5.0/5.1 in the settings window. If anyone know where to find multichannel files I'd be glad to test
This post has been edited by Busemann: May 8 2005, 19:35
rjamorim
post May 8 2005, 19:34
Post #164
Rarewares admin
QUOTE (Busemann @ May 8 2005, 03:28 PM)
Well, there's this multichannel stream I created to verify speaker positioning:
http://wiki.hydrogenaudio.org/upload/test.m4a
Busemann
post May 8 2005, 19:55
Post #165
Ok, the file plays back fine and it reports it as "AAC, 6 Channels, 48,000 kHz". But for some reason, QT freezes when pressing the "settings.." button in the export pane, so I can't convert it..
rjamorim
post May 8 2005, 20:00
Post #166
Rarewares admin
Meh. Buggy.
Try this then: It's a wavpack of that same multichannel stream
http://www.rarewares.org/rja/test.wv
You can decode it with the MacOS binary:
http://www.rarewares.org/files/lossless/wa...k-4.2-MacOS.zip
Edit: actually bzip compressed it nearly as well as WavPack, so you can use this if wavpack won't work for you:
http://www.rarewares.org/rja/test.wav.bz2
This post has been edited by rjamorim: May 8 2005, 20:05
Busemann
post May 8 2005, 20:29
Post #167
That did the trick!
I converted it to both AAC & ALAC as .mov's, but it doesn't seem to passthrough multichannel to the mpeg4 container sad.gif The alac file ended up as 174KB.
Should I upload the two .mov files?
This post has been edited by Busemann: May 8 2005, 20:34
rjamorim
post May 8 2005, 21:00
Post #168
Rarewares admin
QUOTE (Busemann @ May 8 2005, 04:29 PM)
Thanks for testing!
Yes, please. I'm curious about how my QuickTime 6 will behave with a multichannel ALAC.
Busemann
post May 8 2005, 21:59
Post #169
QUOTE (rjamorim @ May 8 2005, 12:00 PM)
Posted them here. I bet QT 6 will choke on both, but it's worth a try anyway.
This post has been edited by Busemann: May 8 2005, 22:03
rjamorim
post May 8 2005, 22:21
Post #170
Rarewares admin
Heh, it's interesting. It loads both files and recognize both as multichannel. But no sound comes out when playing them back.
Skymmer
post May 17 2005, 02:27
Post #171
I have updated WIKI page with this info:
- LA's error state changed from white to red just because
c:\Shifter\Software\MUSIC\Packers\Lossless\La v0.4\tools>la test1.la
Lossless Audio Compressor
Version 0.4b, copyright Michael Bevin 2002-2004
Decoding test1.la [**********..............]
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
- TTA's error state changed from red to green because
c:\Shifter\Software\MUSIC\Packers\Lossless\TTAEnc v3.3>ttaenc -d test1.tta
TTA1 lossless audio encoder/decoder, release 3.3
Copyright (c) 2005 Alexander Djourik. All rights reserved.
For more information see http://tta.sourceforge.net
File:    [Test1.tta]
Decode:  checksum error, 46080 samples wiped
Decode:  wrote 1408192 bytes, done, ratio: 0,74, time: 0
Total:   [1/1, 1,3/1,0 Mb], ratio: 1,377, time: 0'00
I also added a note about error robustness in TTA's pros
Gabber, Jazz and IDM
rjamorim
post May 17 2005, 02:38
Post #172
Rarewares admin
Edit: I added "Fits the Matroska container" to WavPack.
This post has been edited by rjamorim: May 17 2005, 02:43
Defsac
post May 17 2005, 15:44
Post #173
I added streaming support to MAC since the changelog for the latest release seems to indicate streaming is supported.
Changed: Decoding engine better at handling corrupt streams / loss of internet connection while playing
http://www.monkeysaudio.com/versionhistory.html
Edit: I just noticed that the wiki indicates Monkey's Audio doesn't support ReplayGain. I've edited that as well.
This post has been edited by Defsac: May 29 2005, 11:47
Defsac
post May 29 2005, 11:48
Post #174
Jan S. has since informed me "Some programs support replaygain thru tags but that is not the same as it being supported by the format.". I'd like to know what constitutes ReplayGain support.
Granted MAC doesn't conform to the ReplayGain standard (8 bit field in the header file), using APEv2 tags instead. FLAC also uses tags (vorbis comment) for ReplayGain and is listed as ReplayGain supported. So, are we defining ReplayGain support as standard compliant or tag support? If the former FLAC should be changed to "no", if the latter MAC should be changed to "yes".
This post has been edited by Defsac: May 29 2005, 11:53
dobz
post May 29 2005, 12:20
Post #175
When you encode with FLAC you can use "--replay-gain" option, so i guess that this is the reason for FLAC's support.
I had a quick look to see if Monkey Audio can do this but couldnt find the info and gave up looking.
Just because foobar can replaygain an audio file doesnt mean it nativly supports it?
RSS Lo-Fi Version Time is now: 2nd August 2015 - 07:53
