Bug: ReplayGain not saved for some 24-bit wav files
benzin
post Mar 31 2013, 20:48
I have several mono and stereo wav files (all good and playable) which I'm trying to ABX compare. For this purpose, I need their gains adjusted.
For most of the files of the bunch ReplayGain scanning worked fine, but there were 4 mono files for which the scanning worked, showing the needed gain adjustment, but when I clicked "Update File Tags", the windows closed, but the info didn't get saved with the files.
I also attempted to convert the files to the same format, just changing the filenames, but this didn't work.
However, when I converted them to 16-bit, the info could be saved. Similarly when I converted them to 24-bit flac files, I could successfully scan and save the gains.
So currently I will use the flacs as a workaround, but obviously, something is wrong with the ReplayGain mechanism.
I tried this with v1.2 and then updated foobar to 1.2.4, but the bug remained.
Here's link to one of the problemmatic files:
24-bit mono wav file
(I hope it will work for unregistered users of the gearslutz forum)
Cheers!
benzin
Update: initially I linked to the wrong file, link updated.
This post has been edited by benzin: Mar 31 2013, 20:54
Peter
post Apr 2 2013, 11:17
foobar2000 developer
Group: Admin
Thanks for the report.
The file appears to be malformed; there are improperly aligned chunks at the end of it - looks like some application that wrote/updated the file before botched the process.
I recommend using foobar2000 converter to convert it to WAV - producing a fresh WAV file without the malformed chunks; then you can freely tag it.
benzin
post Apr 2 2013, 11:26
QUOTE (Peter @ Apr 2 2013, 12:17) *
Thanks, but as stated in the report, I tried this, and it didn't help. Only converting to a 16-bit WAV file allowed me to tag. Try this and see yourself. unsure.gif
BTW, the files I converted to 24-bit FLAC allow tagging, but won't allow seeking, e.g. I cannont jump to a different time in the file, so also ABX comparison didn't function.
This post has been edited by benzin: Apr 2 2013, 11:30
Peter
post Apr 2 2013, 12:17
Group: Admin
Indeed looks like Converter also doesn't properly handle WAV streams that carry odd byte counts (eg. mono + 24bit + odd sample count).
Bug fixed for the next version, thank you for your patience.
lvqcl
post Apr 2 2013, 15:39
QUOTE (benzin @ Apr 2 2013, 14:26) *
Try flac.exe from fb2k encoder pack: http://www.foobar2000.org/encoderpack
lvqcl
post Apr 2 2013, 22:47
Is it during playback or during ABX test?
RSS Lo-Fi Version Time is now: 24th July 2014 - 06:31
