44 Pages V  « < 34 35 36 37 38 > »
foo_httpcontrol, control foobar via http
oblikoamorale
post Dec 19 2010, 16:48
Post #876
invoking context menu command is implemented for currently playing item only. it isn't hard to add what you want, but I'm busy with something else at the moment.
regi24
post Dec 19 2010, 17:46
Post #877
QUOTE (oblikoamorale @ Dec 19 2010, 16:48) *
It's a shame :/
I'm currently almost able to set the rating to an element from the playlist. With the /runcmd-playlist command it's possible to set the rating to the selected item from the playlist.
I've tried using the cmd=SetFocus command to select an item from the playlist but it doesn't get selected the same way as it gets selected when clicked with the mouse; so the /runcmd-playlist does not work.
Is there another way of selecting a desired item from the playlist? Or can the "SetFocus" command be changed to select the item "properly"?
Thanks for your efforts!
sonvolt
post Dec 20 2010, 22:46
Post #878
QUOTE (regi24 @ Dec 19 2010, 15:11) *
In my own interface I already set the rating for the currently-playing using the runcmd command but right now I'm trying to set the rating of an item from the playlist.
Care to post your interface ? Cheers..
regi24
post Dec 21 2010, 07:44
Post #879
QUOTE (sonvolt @ Dec 20 2010, 22:46) *
It's not finished yet. I just need to improve the look&feel, though.
Iíll try to finish a version the next week or so..
sonvolt
post Dec 21 2010, 09:30
Post #880
That would be great look forward to seeing it when your happy with it , merry xmas
wolfsong
post Dec 22 2010, 18:00
Post #881
QUOTE (oblikoamorale @ Dec 17 2010, 09:11) *
according to documentation, you have to put foo_httpcontrol_data folder to C:\Documents and Settings\<username\>Application Data\foobar2000
moreover, the path where component expects to find foo_httpcontrol_data is clearly shown in fb2k console error message.
Perhaps it should be noted that this component is not compatible with the F2K component installer in the documentation instead of expecting users to figure out what hasn't been resolved by the developer.
[url="http://www.last.fm/user/wolfsong/"]Last.fm Profile[/url]
yolan
post Dec 27 2010, 02:24
Post #882
Optimized template for Nokia N900, based on vakata2.
n900 template
regi24
post Dec 28 2010, 14:44
Post #883
I'm trying to use the new command "SetSelection" but it's not working for me..
I'm doing this:
?cmd=SetSelection&param1=0
What I'd expect is the first item from the current playlist to be selected but it doesn't.
I'm using foobar v1.0.3.
Edit: The same behaviour under v1.1.1
This post has been edited by regi24: Dec 28 2010, 14:50
oblikoamorale
post Dec 28 2010, 20:32
Post #884
works for me. example: http://127.0.0.1:8888/ajquery/?cmd=SetSele...ram3=NoResponse selects first item of active playlist.
show your full url and fb2k console output (enable "log access to console" in preferences beforehand).
regi24
post Dec 28 2010, 22:51
Post #885
QUOTE (oblikoamorale @ Dec 28 2010, 20:32) *
Now it's working for me too.. I haven't actually changed anything so I don't know what was happening before.. :/
This post has been edited by regi24: Dec 28 2010, 22:54
regi24
post Jan 9 2011, 23:58
Post #886
I've just released a first version of an Android app.
If anyone interested:
http://foobar2000controller.blogspot.com/
Hope you enjoy it.
alkasar
post Jan 10 2011, 00:56
Post #887
QUOTE (regi24 @ Jan 9 2011, 23:58) *
Hope you enjoy it.
I see there is a server : does it need foo_httpcontrol ?
sonvolt
post Jan 10 2011, 01:09
Post #888
Yes foo-httpcontrol needed.
Regi24 - How do you get into change settings if it wont connect?? do you need full path c:\users\house\appdata\roaming\foobar2000\foo_httpcontrol_data ?? (Windows 7)
This post has been edited by sonvolt: Jan 10 2011, 01:35
regi24
post Jan 10 2011, 07:58
Post #889
QUOTE (sonvolt @ Jan 10 2011, 01:09) *
You have to follow the instructions.
You need to unzip the file "foobar2000controller.zip" here: c:\users\house\appdata\roaming\foobar2000\foo_httpcontrol_data (if you have a regular foobar installation, not portable).
And then you need to configure foo_httpcontrol in foobar2000 as apropriate.
In the device you should only have to change the IP address from the server. The other fields are preconfigured to work with the default settings of foo_httpcontrol.
The settings folder in Android software is not the full path but the folder in c:\......\foo_httpcontrol_data\foobar2000controller". I mean, you have to write only foobar2000controller.
This post has been edited by regi24: Jan 10 2011, 08:06
tberman333
post Jan 10 2011, 17:57
Post #890
QUOTE (regi24 @ Jan 9 2011, 18:58) *
Hope you enjoy it.
Will this app work without the playback statistics component? I understand that the ratings part of it will not work, but am hoping that the rest will function correctly.
GO WHALE!!!
[url="http://www.toddberman.com"]My Website[/url]
regi24
post Jan 10 2011, 18:08
Post #891
QUOTE (tberman333 @ Jan 10 2011, 17:57) *
Hope you enjoy it.
The rating and playcount is not gonna work but the rest will work fine.
It's intended to use both foo_httpcontrol and playcount components, though.
tberman333
post Jan 10 2011, 18:28
Post #892
QUOTE (regi24 @ Jan 10 2011, 13:08) *
Hope you enjoy it.
Thanks for the answer. I use foo_playback_custom as I like the extra options it provides. I am going to try out your app in the next few days.
GO WHALE!!!
makita
post Jan 14 2011, 06:37
Post #893
Is anybody aware of any updates to the lxofith of kev0 templates for the iPhone? Specifically, I'm looking for a fix that enables playback of the 1st track when switching (or restarting) a playlist. For example, say I'm listening to track 5 on a playlist and I try to play the 1st track, track 5 just starts from the beginning. Same thing happens if I open up a new playlist and try to start track 1. Whereas if I click on any other track than the 1st (while on either playlist), that track plays from the beginning (like I would expect it to). Make sense? I figure this is buried somewhere in the iphone.js file, but I'm too amateur to reverse engineer this JScript. regi24's Android app looks awesome BTW, but I have an iPhone ...
I've been searching for awhile now for the best way to play my FLAC files stored on the PC in my back office by wirelessly networking to the PS3 (and then receiver) in my living room. At first I just tried using foo_upnp to enable access to my foobar media library using the PS3, but that creates the annoying/intolerable side effect of gaps between tracks. foo_upnp Playback Stream Capture enables me to stream the audio output from foobar on my PC through the PS3 without gaps between tracks, but how do I control foobar while in my living room? Enter foo_httpcontrol and my iPhone. foo_touchremote was an option, but I couldn't get it to work on my XP machine and I'm not very enamored with iTunes-like navigation. Am I the only one who just wants to be able to choose a folder (by artist), open a subfolder (by album) and play it beginning to end anymore?!?
Other suggestions would be much appreciated. Thanks for reading ...
Kev0
post Jan 14 2011, 11:30
Post #894
Makita. I'm afraid I'm not seeing your first track problem. I can start the first track no problem, and flick between playlist and start from anywhere. So I'm not sure how I can help.
Just a suggestion on your other point, in the foo_upnp settings, under streaming profiles, at the bottom I have "Audio Processing" in there there is settings for crossfader and skip silence. I wonder if they could help you?
This post has been edited by Kev0: Jan 14 2011, 11:30
tberman333
post Jan 14 2011, 15:01
Post #895
Kev0 - Your config is my favorite to use, but unfortunately I have had to stop using it as scrolling through the tracks in a playlist does not seem to work on my phone (I have the Original Motorola Droid running Android 2.2). These seemed to happen when my Android version went from 2.1 to 2.2. Do you know if there is any fix for this issue?
GO WHALE!!!
oblikoamorale
post Jan 14 2011, 18:06
Post #896
makita: these fixes should solve your problem kevo lxofith
makita
post Jan 15 2011, 03:01
Post #897
QUOTE (oblikoamorale @ Jan 14 2011, 09:06) *
Thanks all for the expedient replies. Oblikoamorale, your script was the exact solution I was looking for.
This post has been edited by makita: Jan 15 2011, 03:02
Gehirnmaehung
post Jan 23 2011, 23:56
Post #898
I just reinstalled my HTPC which is running foobar with this great plugin, controlled via iPod. I did a complete uninstall of foobar and reinstalled the latest version of both foobar and the plugin. I experience that the mobile-templates (simplebasic, ixofith, kevo) don't work anymore - at least for me. SimpleBasic is completly destroyed on both FF and iPhone, ixofith and kevo don't display any playlists, i can not play anything. AJquery and Default are working as usual. Am i missing some new/changed configuration steps?
edit: to make that exact: i do not have any navigating issues with my iOS devices, simplebasic looks like a bomb hit it (displaying the correct album art though), while the other two i mentioned do not display anything of what is playing on foobar. The situation is exactly the same on my desktop with firefox.
This post has been edited by Gehirnmaehung: Jan 23 2011, 23:59
oblikoamorale
post Jan 24 2011, 05:41
Post #899
try latest component version, I've just removed additional non-ascii char stripping which seems to affect most of the 3rd party templates.
Hamallainen
post Jan 24 2011, 12:01
Post #900
QUOTE (Hamallainen @ May 3 2010, 15:25) *
Hello.
Small bug : in the 0.63 version of the ajquery template, you added shift+[ or shift+] to resize playlist height but for me, shift+[ doesnt work while shift+] works well. foobar2000 1.03; foo_httpcontrol 0.96.12.1; firefox 3.63
Hi. I still have this problem. I have updated both ajquery and foo_httpcontrol to 0.64 and 0.97.6. I tried with 2 browsers, Firefox 3.6.13 and Chromium 10.0.647. Am i the only one ?
RSS Lo-Fi Version Time is now: 21st September 2014 - 21:53
