IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
How can foobar show total size of >1TB of data?, Total size disappears from Info panel
torturesauce
post Feb 16 2013, 07:53
Post #1
Group: Members
Hello,
I'm using Foobar2000 with the standard interface. I have a media library which exceeds 1TB in size (it's about 1.1TB). When I use the Info panel to calculate the total size of all files, the info disappears. It does appear only when my selected library parts are less than 1TB. Is it one of the software's limitations? Is there any way to show the total size info for libraries bigger than 1TB?
Go to the top of the page
+Quote Post
ojdo
post Feb 16 2013, 08:51
Post #2
Group: Members
What is the "info panel"?
To get the total file size of my library, I would do a
1. Main Menu > Library > Search
2. Enter "ALL"
3. Select all results (Ctrl+A)
4. Right-click and select "Properties"
5. Tab "Properties" has an entry "Total size" which shows the total file size instantly - at least for my <200 GB library.
http://freemusi.cc/
+Quote Post
marc2003
post Feb 16 2013, 10:25
Post #3
Group: Members
QUOTE (ojdo @ Feb 16 2013, 07:51) *
selection properties is basically the properties dialog>properties tab in a panel.
+Quote Post
Alexxander
post Feb 16 2013, 11:11
Post #4
Group: Members
I have foobar2000 1.2.3 and also set up a Properties panel in the standard UI. Right after starting up program I selected all files and indeed the Total size field disappeared. The breakeven point in my case was at 257GB
8968 items. Item 8969 made the the Total size not being displayed. But hitting the rightclick menu with mouse on selection did show up the total size. After this I tried selecting other files and total size was shown every time in the Properties panel, no matter how many items were selected. Then I realized my hard drives had just stopped crackling. This might have to do with some background updating? Console doesn't tell anything.
This post has been edited by Alexxander: Feb 16 2013, 11:12
+Quote Post
torturesauce
post Feb 16 2013, 14:59
Post #5
Group: Members
Nevermind, my problem got solved all by itself. Yes, I was using Selection Properties, accidentally referred to it as "info".
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th September 2014 - 01:49
