Frontah, multi frontend, big app alternatives?, looking for small but current utility to convert format and keep tags
MrSinatra
post Apr 18 2013, 12:07
hi all,
I am looking to convert some well tagged FLACs to mp3, and want it all done nicely, cleanly, by the book, by a little, lightweight app.
I kinda remember frontah and multi-frontend, but they seem old and out of date. I want something smooth and current for win7.
I know MM and fb2k and dbpa and so on are good apps, but I am looking for a small utility, not a big app.
any ideas? thanks.
Silversight
post Apr 18 2013, 12:11
How about LameDropXPd?
Nothing is impossible if you don't need to do it yourself.
Heliologue
post Apr 18 2013, 21:11
Not sure what your definition of "small utility" is. I assume that means you don't want playback or ripping functionality (as with MM, fb2k, and dbpa)?
TAudioConverter is a very recent project announced here on HA.
If you want a bare-minimum utility, I would second Silversight's suggestion of LameDropXPd.
MrSinatra
post Apr 19 2013, 00:45
QUOTE (Silversight @ Apr 18 2013, 07:11) *
very sweet utility. lightweight the way frontah and multi frontend were.
I figured out how to use it pretty quick, but what is "input scaling?" it seems to be RG related, but I don't understand exactly, is it actually adjusting the gain to the file, a la mp3gain?
also, it doesn't seem to copy RG tags no matter what. no big deal, I can re-analyze. no "album artist" tags either.
and where does auto tagging get its info? freedb?
QUOTE (Heliologue @ Apr 18 2013, 16:11) *
more involved, but useful. I also want to convert FLACs to ALAC, so very nice for me. however, again the RG tags don't copy [to alac anyway], (but the AA tags do).
thx guys!
This post has been edited by MrSinatra: Apr 19 2013, 00:48
MrSinatra
post Apr 19 2013, 11:51
something else that's weird with lamedrop:
if your track tags are like 4/11 it writes 4_11
and it also adds a LENGTH field (not in the source file) with values like 235643 in it. whats that?
where can I find the homepage for lamedrop? i'll report it to the dev if I can.
This post has been edited by MrSinatra: Apr 19 2013, 11:51
Silversight
post Apr 19 2013, 18:35
I don't actually use LamedropXPd myself, just know about its existence. So I don't have an answer to most of your problems with it, sorry.
However, I know that the RG tags are not supposed to be copied over. Due to the way lossy compression works, there can be peak values > 1 between the samples of the decoded stream. If there is no volume adjustment applied in the encoding process, the gain values of source and target won't audibly differ, but they have to be recalculated nonetheless.
aztec_mystic
post Apr 19 2013, 19:02
QUOTE (MrSinatra @ Apr 19 2013, 01:45) *
what do you mean by "lightweight"?
i think the most resource-intensive thing is going to be the mp3 encoding which is the same regardless of the frontend. it's not that the programs are "big apps." dbpa is like 7mb compiled, it's consumption of hdd space when installed is completely negligible. it's not exactly cpu-intensive, either, unless you're transcoding something.
sure, if you still got a pentium p5, you'll appreciate a leaner frontend, but you wouldn't wanna run an mp3 encoder on a p5 anyhow..
MrSinatra
post Apr 23 2013, 11:37
thx again guys,
by lightweight, I mean like lamedrop, a small utility, pref no real install or registry mucking about, very focused, and space is a concern on my SSD.
still, TAC seems great. but one question: how does flac do gapless, and does it translate that gapless info into pgap atoms in the m4a ALACs it creates?
slks
post Apr 24 2013, 23:56
ReplayGain tags shouldn't be copied if you are trying to do it "by the book". The decoded MP3 is going to be different from the original FLAC, and will give different numbers in a RG scan. Usually the difference in the gain number is inaudibly small (~0.1 dB or so). But there can be significant differences in the peak values.
foobar2000 has a nice checkbox that will automatically re-scan the output files and give them updated RG tags, in addition to moving the rest of the tags. Looking at my foobar installation it fits these criteria:
Less than 20 MB on disk (including plugins),
Less than 35 MB in memory (even with 10,000 tracks loaded),
Minimalist interface that doesn't bombard you with irrelevant options on the main screen,
A "Portable mode" where it can be used without modifying the registry
If that doesn't fit your definition of "lightweight"... neither should Windows 7 smile.gif
http://last.fm/user/sls
RSS Lo-Fi Version Time is now: 5th July 2015 - 22:59
