73 Pages V  < 1 2 3 4 5 > »
foo_wave_seekbar, pretty accelerated seekbar
ojdo
post Jan 4 2010, 11:01
Post #51
Thank you very much for this very promising component!
Bugs:
  • The panel is not correctly redrawn when switching (CUI) layouts: the waveform disappears and the whole panel is filled with the highlight colour. Correct appearance is restored when starting playback on a new song. Addition: The behaviour is equivalent to the second bug. The panel only visualises the song's first second.
  • When adding a second panel instance to the same or another layout, both panels stop working properly. No waveform is visible and the panel seems only to visualise the first second of the song, so the selection bar quickly "runs" through the panel and vanishes.
Feature request:
  • Allow mouse wheel to seek (just like the default seekbar does).
This post has been edited by ojdo: Jan 4 2010, 11:03
http://freemusi.cc/
NullString
post Jan 4 2010, 11:26
Post #52
storing the data in the file tags would be awesome, besides it would take advantage of the compression of the fb2k database
fuflo
post Jan 4 2010, 12:08
Post #53
thanks for this great component. and well, since everybody's asking questions, i'll ask this - where are the settings saved? i don't see a separate config file in config dir. also checked registry - nothing's there. the settings are kept after deleting wavecache.db, so it's not there. also removing the component and then restoring it ( removing foo_wave_seekbar.dll ) doesn't remove the settings. where are they?
(Sly)
post Jan 4 2010, 12:14
Post #54
In the directory where foobar2000.exe is in file "wavecache.db"
There is no config file because it does need to save any configuration right now.
This post has been edited by (Sly): Jan 4 2010, 12:15
LAME 3.99.5 -V0
TomBarlow
post Jan 4 2010, 13:00
Post #55
Looks like a nice component, but it doesn't work for me. I guess it's my 5 year old laptop not having good enough hardware. I get this in the console:
Seekbar: taking Direct3D9 path.
Seekbar: frontend creation failed: Direct3D9: could not create texture.
The panel draws whatever was on the screen previously, but it still acts as a seekbar. It seems to process the songs properly as well (i.e. create the waveforms). Is there anything I can do?
Zao
post Jan 4 2010, 13:46
Post #56
Group: Members (Donating)
QUOTE (skelly831 @ Jan 3 2010, 22:14) *
I just want to ask for a tooltip that shows the bars' time when I drag it, like the standard seekbar
Planned eventually.
QUOTE (ojdo @ Jan 4 2010, 11:01) *
Bugs:
Feature request:
Those aren't bugs, those are features:
  • CUI probably does horrible things to my window when mangling layouts.
  • This and the first is likely due to failing to re-acquire the proper track length, defaulting to 0, showing an infinitesimal slice of the track. cool.gif
Things I didn't know existed:
  • Heh, didn't know that you could use the wheel for that. Will probably implement some day.
QUOTE (NullString @ Jan 4 2010, 11:26) *
The foobar2000 database has compression? I do not believe so. I do need to look into whether it's feasible to compress this data.
QUOTE (fuflo @ Jan 4 2010, 12:08) *
The only settings it has currently is per instance of the UI panel/element, which are stored using the DUI/CUI configuration framework.
QUOTE (TomBarlow @ Jan 4 2010, 13:00) *
Ooh, fun.
I have a fallback path that is good enough for the horrible Intel cards, but apparently not horrible enough.
What kind of graphics hardware do you have?
The fallback path uses an A2R10G10B10 (2 bits alpha, 10 bits for each of red, green, blue) for the waveform data, but I suppose one might try A8R8G8B8 if that fails.
This post has been edited by Zao: Jan 4 2010, 13:47
randal1013
post Jan 4 2010, 13:49
Post #57
QUOTE (randal1013 @ Jan 3 2010, 20:50) *
crashes my foobar when i try to place the component.
win7 x64, foobar 1.0 beta6
will directx 9.0c co-exist peacefully with directx 11?
i ended up having other windows problems to deal with last night. the seekbar works fine and looks cool.
2E7AH
post Jan 4 2010, 13:59
Post #58
Group: Validating
I guess zooming (middle scroll) is out of question? (in case some time grid is added as requested)
This post has been edited by 2E7AH: Jan 4 2010, 13:59
Zao
post Jan 4 2010, 14:15
Post #59
The data set used is rather sparse, just 2048 data points. You'd just be looking at interpolation when zooming or with a large enough window.
2E7AH
post Jan 4 2010, 14:23
Post #60
Group: Validating
It's CEP/AU behavior I'm used to, scroll to zoom or middle click then slide to go right/left
This post has been edited by 2E7AH: Jan 4 2010, 14:23
Zao
post Jan 4 2010, 14:27
Post #61
I'll put that under the category ╗maybe if I'm horribly bored some dayź.
2E7AH
post Jan 4 2010, 14:28
Post #62
Group: Validating
Hengest
post Jan 4 2010, 15:20
Post #63
Well just to say thankyou for this component - it's really great smile.gif.
Also, would it be possible to scale the waveform according to replaygain values for each track/album?
"Lifting Shadows Off a Dream"
ojdo
post Jan 4 2010, 16:33
Post #64
QUOTE (Zao @ Jan 4 2010, 13:46) *
Bugs: [...] The panel is not correctly redrawn when switching (CUI) layouts. [...]
Those aren't bugs, those are features: CUI probably does horrible things to my window when mangling layouts.
So this should be reported in the foo_ui_columns thread, right?
This post has been edited by ojdo: Jan 4 2010, 16:50
http://freemusi.cc/
bbt-hh
post Jan 4 2010, 17:17
Post #65
Everything loads fine, but the Waveform Seekbar shows nothing than white space? Seeking works though. (Win XP SP3, Radeon 9550)
rol
post Jan 4 2010, 17:57
Post #66
Can u fix high CPU usage? On Win7 and Pentium 4 i have ~20%, without plugin 0% sad.gif
TomBarlow
post Jan 4 2010, 18:09
Post #67
QUOTE (Zao @ Jan 4 2010, 12:46) *
I have an Intel 82852/82855 GM/GME Graphics Controller: http://www.intel.com/support/graphics/intel852gm/index.htm
I'll update my driver and see if that makes a difference.
bb10
post Jan 4 2010, 18:22
Post #68
QUOTE (TomBarlow @ Jan 4 2010, 18:09) *
I'm afraid you're out of luck.
QUOTE (rol @ Jan 4 2010, 17:57) *
Are you using D2D?
This post has been edited by bb10: Jan 4 2010, 18:49
rol
post Jan 4 2010, 18:49
Post #69
DX 9.0c
Horst Fux
post Jan 4 2010, 19:00
Post #70
QUOTE (Snowknight26 @ Jan 4 2010, 05:18) *
If only you could replace the toolbar's seekbar with this one..
You mean like this?
The seekbar at top isn't supposed to be there, just added it 'cause I wanted to try something.
This post has been edited by Horst Fux: Jan 4 2010, 19:02
NullString
post Jan 4 2010, 19:40
Post #71
QUOTE (Zao @ Jan 4 2010, 09:46) *
right, some compression would be appreciated. The .db file weights 730MB, and the compression ratio is like 75% (using rar). not that it matters, because the indexing of the data and the requirement of secuential reading to decompress the whole db would make it not feasible.
although these sqlite extensions might point you to a better approach, compressing each row with zlib:
http://www.mail-archive.com/sqlite-users@s...g/msg17018.html
(which is wrapped in a better way here)
http://geomapx.blogspot.com/2009/11/fts3-compression.html
or an alternative,
http://lserinol.googlepages.com/sqlitecompress
TomBarlow
post Jan 4 2010, 20:01
Post #72
QUOTE (TomBarlow @ Jan 4 2010, 17:09) *
bb10
post Jan 4 2010, 20:23
Post #73
QUOTE (TomBarlow @ Jan 4 2010, 20:01) *
A driver update won't resolve the non-existent DirectX 9 support of your GPU. tongue.gif
Andreasvb
post Jan 4 2010, 20:29
Post #74
QUOTE (bb10 @ Jan 4 2010, 20:23) *
It says it's DX 9.0.
The Intel« 82830M and Intel« 82852/82855 GM/GME graphics controllers are compatible with versions of Microsoft* DirectX* up to 9.0.
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.6
TomBarlow
post Jan 4 2010, 20:51
Post #75
QUOTE (bb10 @ Jan 4 2010, 19:23) *
ok, I missed your reply. I think I have DirectX 9, it must be pixel shader support that I need. That was a problem for me with Shpeck+Milkdrop, I could only run a handful of presets. dry.gif (I didn't realise what PS meant in the OP ohmy.gif)
RSS Lo-Fi Version Time is now: 26th December 2014 - 12:13
