9 Pages V  « < 6 7 8 9 >
foo_dsp_effect, A effect array for FB2K
mudlord
post Jan 25 2013, 02:10
Post #176
Group: Developer (Donating)
well it would be very helpful to know what tag it uses....
markanini
post Jan 25 2013, 04:28
Post #177
QUOTE (EpicForever @ May 7 2012, 08:33) *
This delay between channels is added intentionally - in purpose of widening stereo basis. Stereo widening effects (like making stereo from mono signal) are always based on adding interchannel delay. So such DSP will be destroying effect rather than sound tuning effect.
Youre referring to Haas effect processes which are sometimes applied to a few instrumments in a mix. It's more common in the DAW era with the exception for some experiments in the 1960s where the intentional delays were orders of magnitude higher than the unintentional delays from tape transport misalignment.
I'll put forward my feature suggestion again: Please consider an effect for adding a small delay on either LR channel controlled by a custom tag field. The field value might look something like: 'L5' denoting the L channel be delayed by 5 samples. A range of 1-50 samples would be plenty for 44100Hz.
This post has been edited by markanini: Jan 25 2013, 04:30
mudlord
post Jan 25 2013, 22:15
Post #178
and I say:
http://www.hydrogenaudio.org/forums/index....st&p=794716
im pretty much done with this component and many things in general.
This post has been edited by mudlord: Jan 25 2013, 22:16
kode54
post Jan 25 2013, 22:24
Post #179
Group: Admin
Sounds like an interesting effect, although I would rather implement it using something more serious. Although I would probably take to a bit of mockery by making it a foo_dsp_silly_effects component.
Yeah, mudlord made a lot of effects he thought would be useful, but now feels some of these are just getting too silly for him to consider, even if they would be fairly easy to implement. I could get to work on some of this crap later.
mudlord
post Jan 25 2013, 23:00
Post #180
Yes, easy to implement.
A) get your current track via play_control
B) get your file_info from the metadb ptr given
C) Parse tags using file_info methods.
D) do delays based on timing from tags
Honestly though, cannot be arsed though. What annoyed me greatly is now I am getting requests outside the scope of what I intended for this component to be. And plus, I can't find a personal use to implement them.
EpicForever
post Feb 2 2013, 18:23
Post #181
I'm not sure weather this issue is caused by foo_input_exe or foo_dsp_effect so i post it in both threads, maybe authors will find what can be wrong.
My DSP chain looks like this: Skip Silence - > convert 5.1 to stereo -> convert mono to stereo -> playback rate shift. Playback Rate Shift requires 2ch signal. So used DSP effects provide such signal.
When I play 6ch FLAC encoded from DVD-A everything works OK. Signal is downmixed and I can use PRS actively or just unused, but present in chain. But when I play audio from video files and I use foo_input_exe to wrap signal decompressed by FFMPEG.exe from that files, then 6ch audio decoded from .VOB file generates error: "Unrecoverable playback error: Illegal number of channels". It means that Playback Rate Shift gets 6ch audio instead of 2ch - like "convert 5.1 to stereo" wasn't working or something like this... Why? What can I do to avoid this error in such playback configuration?
Porcus
post Feb 2 2013, 19:31
Post #182
You have likely been home in the meantime, but anyway, dBpoweramp uses <PRE-EMPHASIS>, value 'Yes'. Different value, different tag name (note the hyphen).
(Myself I store those pre-emph'ed CDs in a different format (great excuse to pay homage to WavPack) just in case I accidentally delete tags, so I don't mind doing the extra work to write another tag to them.)
One day in the Year of the Fox came a time remembered well
mudlord
post Feb 3 2013, 02:42
Post #183
QUOTE (EpicForever @ Feb 2 2013, 12:23) *
Weird, doesnt sound like a problem on my end if the "convert 5.1 to stereo" isnt working. Indeed, the SoundTouch based DSPs only work on stereo channels.
EpicForever
post Feb 3 2013, 13:49
Post #184
Just for your information mudlord - it turned out that it might be a problem in handling of channel mask by "Convert 5.1 to stereo" plugin. Surround channels aren't properly handled (SR, SL) while back channels (BL, BR) are. That was said to be solved on Peter's end in "Convert..." plugin. So PRS doesn't trigger any problems in above scenario smile.gif
This post has been edited by EpicForever: Feb 3 2013, 13:50
lvqcl
post Feb 14 2013, 16:04
Post #185
a bug found: http://www.hydrogenaudio.org/forums/index....st&p=824194
mudlord
post Feb 16 2013, 12:33
Post #186
noticed the problem with the aliasing and such
mudlord.info/temp/foo_dsp_effect.zip
mudlord.info/temp/foo_dsp_effect_nodemph.zip
This post has been edited by mudlord: Feb 19 2013, 10:45
EpicForever
post Feb 24 2013, 20:42
Post #187
Question - does regular version of foo_dsp_effect contains POSTPROCESSOR service for de-emphasis or only DSP/IIR filter based De-emphasis functionality? I can't find it in documentation on regular download site (foobar2000.org/components).
Rollin
post Feb 25 2013, 09:29
Post #188
Postprocessor
The tag "PRE_EMPHASIS" must be used on content which is supported by FB2Ks decode processor services, for this to work. Pre-emphasis can be signified in your media with the values "1" or "0".
EpicForever
post Mar 1 2013, 22:50
Post #189
QUOTE (EpicForever @ Aug 25 2012, 15:27) *
(...) I think about possibility of preserving information about preferred Playback Rate Shift, Pitch Shift and Tempo Shift for certain files in tags. It could be done like this: user manually adds tag field to his file - for exampla tag named "PRS" (for "Playback Rate Shift") and puts there a value - for example "+5" or "-10". Active DSP reads tag field and automatically applies shift. (...)
QUOTE (Rollin @ Aug 25 2012, 17:41) *
I used it and it works great smile.gif it takes some effort to configure it (chains, tags, dsp config) but it gives me desired option. Thx again smile.gif
EpicForever
post May 10 2013, 18:48
Post #190
One question - is it possible to make foobar display length of track after playback rate shift modification? I'm thinking mostly about status bar.
mudlord
post May 11 2013, 11:21
Post #191
No.
EpicForever
post May 11 2013, 12:14
Post #192
OK, but you mean impossible because you are not willing to code it or because of foobar's limitations?
mudlord
post May 12 2013, 03:28
Post #193
from what I know, the latter.
EpicForever
post May 22 2013, 18:25
Post #194
I got another question and probably request - is it possible to use some title formatting switch/variable that will allow me to see in status bar that Playback Rate Shift DSP is currently running ? Something like possibility to display "Playback Rate Shit: running/not running" (or "Playback Rate Shift running: yes/no".) in status bar (like with HDCD). If it isn't possible at the moment, then I want to kindly ask you mudlord for coding such thing. I have about 20-30 tracks that have TRACKDSP tags to use with DynamicDSP plugin. All these TRACKDSP tags contain values that enable automatic Playback Rate Shifts triggered by DynamicDSP. Unfortunately DynamicDSP can loose it's config under certain circumstances, so sometimes I got weird feelings while listening to some tracks and in the end it turns out that something doesn't work like it should. But it always takes some time and effort. With such thingy it would be very easy to detect whether DynamicDSP works or not. And to check whether I set Playback Rate Shift to 0% after some experiments that I sometimes do with other tracks smile.gif . So is it possible?
mudlord
post May 23 2013, 11:16
Post #195
I am honestly unsure whether DSP services can do get_dynamic_info(). I know its certainly possible in preprocessor services, though.
mudlord
post Sep 10 2013, 03:15
Post #196
http://mudlord.info/temp/foo_dsp_effect.dll
needs tests in iir filter module before being uploaded to main repo. also any other bug reports are welcome.
CoRoNe
post Nov 3 2013, 11:32
Post #197
QUOTE (mudlord @ Aug 15 2012, 06:56) *
Hmm, AVISynth returns complete samples?
In the effect source for dsp_soundtouch.cpp, for get_latency, I return the amount of buffered samples divided by the samplerate to get current latency of the DSP. I run a buffer to basically get samples, and output them. I guess in the process there is a bug of sorts?
Any updates on this, mudlord?
DC-Bass Source Mod: http://reino.degeelebosch.nl
mudlord
post Nov 3 2013, 21:52
Post #198
I don't care about that "bug", since the DSPs were intended for listening, not for archiving. >_>
eahm
post Nov 20 2013, 09:26
Post #199
Thanks for the component but...from 0.9.2 you went to 0.10, 0.11, 0.12? That's lower, you should do 1.0, 1.1, 1.2. Was this already discussed?
/lwAsIimz
detmek
post Nov 20 2013, 10:35
Post #200
It is not lower. Version numbers are not decimals. 0.9.2 is not 0,92.
So, you have leading 0, 9 as main version and as subversion. In 0.10, 10 is main version, which is higher then 9.
RSS Lo-Fi Version Time is now: 15th September 2014 - 05:07
