5 Pages V  « < 3 4 5
ARCue.pl - Check whole CD rips with AccurateRip
Fandango
post Feb 25 2008, 18:15
Post #101
You misunderstood me: I said something along the line of "I'd love to be able to check individual files [...] ideally with a foobar2000 plugin."
Apart from that I would also appreciate an enhanced command line tool written in C or C++ that can at least check individual tracks as files in WAV format. Although that would make things more complicated for me than a fb2k plugin, because I'm very bad at writing these BASIC style batch scripts for Windows.
I was only talking about my own needs here.
This post has been edited by Fandango: Feb 25 2008, 18:21
Jose Hidalgo
post Feb 25 2008, 20:32
Post #102
Group: Banned
QUOTE (Omy @ Feb 25 2008, 18:05) *
I, along with many, many other people, don't use fb2k.
... just kidding. tongue.gif You are totally right, there are two kind of users out there :
- the foobar users,
(I'm out of here, I'm out of here, just kidding again folks)
Cerebus
post Feb 25 2008, 20:33
Post #103
QUOTE (Jose Hidalgo @ Feb 25 2008, 12:32) *
- the foobar users,
Omy
post Feb 25 2008, 22:34
Post #104
QUOTE (Jose Hidalgo @ Feb 25 2008, 19:32) *
- the foobar users,
As I see no reason not to post this here now, here is my C version. The library portion of it should be reasonable portable, but the accuraterip-crcgen code is very ugly and probably will only work on *nix systems. Having said that, I haven't actually tried it anywhere else. YMMV, but if you can make it work then it's significantly faster than the perl implementations.
torben
post Apr 8 2008, 15:47
Post #105
My problem is this:
I have lots of CDs ripped to FLAC, and I would like to use arflac to verify their quality. However unfortunately they were ripped using CDEX thus drive offsets were not taken into account while ripping.
Is there a tool which I could use to fix the drive offsets to the FLAC files before running arflac?
(There is also the added joy that I used a total of three different drives for ripping, but still it would be probably more convenient to run arflac three times than to convert everything once again using EAC... sigh)
greynol
post Apr 9 2008, 05:49
Post #106
QUOTE (rohangc @ Apr 8 2008, 21:31) *
Perhaps we must start a new thread for ARFlac.pl as most people may not look inside this thread when looking for a utility like this.
Omy started one for the version in C, but I'll split this one off.
ARFlac.pl can now be found here.
This post has been edited by greynol: Apr 9 2008, 06:11
Corwin
post Jun 26 2008, 11:11
Post #107
QUOTE (brainsoft @ May 27 2007, 18:40) *
redirecting the output leaves you stairing at a blank screen until the entire checking process is done, and then TYPEs the creative log to the screen. If the logfile creation were part of the script itself then you could still have regular file by file output while writing to the log file in perl.
If you add
select STDOUT; $| = 1;
to the top of the script it stops the buffering problem. Pipe-ing through Tee works great this way.
P.S. ARCue.pl works great on my 64bit Debian machine.
odyssey
post Jul 18 2008, 12:41
Post #108
I think I mentioned it earlier, but I *really* would like ARCUE to be able to determine an offset and still return the accuracy of a rip. This is also nessesary because of my recent experience:
I'm creating a script that will traverse all my albums and verify their accuracy with ARCUE, but an obvious problem makes this useless on almost any album. I've ripped all my music as seperate tracks with EAC. When a CD has any amount of silence in INDEX 00 in TRACK 01, it's impossible for me to recreate a true cuesheet that will work with ARCUE - All tracks will seem nudged the time of INDEX 00 to AR. sad.gif
I really hope that this feature could be incorporated so I will be able to check my rips.
reardon
post Oct 24 2011, 13:56
Post #109
QUOTE (odyssey @ Jul 18 2008, 03:41) *
I've updated the code with offset support, here
5 Pages V  « < 3 4 5
RSS Lo-Fi Version Time is now: 28th May 2015 - 19:37
