IPB
> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
Unresolved External Symbols, Linker errors from DECLARE_COMPONENT_VERSION
retierney
post Jul 12 2013, 07:05
Post #1
Group: Members
Hello,
I am new to foobar2000, and I am trying to write a simple plugin for myself. Right now I just have stub code to see if I can build it and run foobar2000 with it. However, when I build it I get linker errors. The errors are:
unresolved external symbol "char const * __cdecl core_api::get_my_file_name(void)" (?get_my_file_name@core_api@@YAPBDXZ)
unresolved external symbol "public: static struct _GUID const componentversion::class_guid" (?class_guid@componentversion@@2U_GUID@@B)
unresolved external symbol "public: static class service_factory_base * service_factory_base::__internal__list" (?__internal__list@service_factory_base@@2PAV1@A)
By process of elimination I found that these are coming from the DECLARE_COMPONENT_VERSION macro. I examined both foo_sample and foo_tutorial1 plus all of the online documentation that I could find, but I can't find out what I am missing. I am linking against libraries: pfc, foobar2000_SDK, foobar2000_component_client, and shared.
I am using Microsoft Visual Studio 2010 Express. Any ideas? Thanks...
My simple stub code is:
CODE
#include "stdafx.h" // just has: #include "..\SDK\foobar2000.h"
"Playlist Item Filter",
"1.0",
"Sorts the incoming playlist items by track number."
class playlist_incoming_item_filter_custom : public playlist_incoming_item_filter
public:
bool filter_items(metadb_handle_list_cref in, metadb_handle_list_ref out)
console::print("My filter_items function here...");
t_size count = in.get_count();
out.remove_all();
if (count > 0)
out.add_items(in);
return (count > 0) ? true : false;
Go to the top of the page
+Quote Post
fbuser
post Jul 12 2013, 13:21
Post #2
Group: Developer
The first missing symbol belongs to foobar2000_component_client, the other two belong to foobar2000_SDK. So, you're obviously not linking against these librariers. You should check your project settings.
+Quote Post
retierney
post Jul 12 2013, 15:46
Post #3
Group: Members
QUOTE (fbuser @ Jul 12 2013, 14:21) *
Oops! Apparently I didn't look close enough at foo_tutorial1 to see how I set up the additional link libs and lib paths. Egg on face and sorry...
Thank you very much...
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th March 2015 - 12:29
