Recompressing existing FLAC files to 8 (without duplication)
philaphonic
post May 22 2012, 19:03
I have about 5,000 FLAC albums at various levels of compression. A lot are already at level 8, but many are not. Is there some nifty app. that will run through the non-8 compressed ones and recompress them to an 8 for me, checking its work?
I cannot see that dBpoweramp can do this.
Thanks for any insights.
EagleScout1998
post May 22 2012, 19:24
There is no way, that I know of, to convert a file without duplicating it. However, dBpoweramp does have a DSP that will delete the source file after conversion.
Addendum: I stand corrected.
This post has been edited by EagleScout1998: May 22 2012, 19:47
Ouroboros
post May 22 2012, 19:31
From the FLAC documentation page.
flac abc.flac --force
I'm sure a little experimentation with foobar2000 convert and the --force option would lead you to a workable solution.
db1989
post May 22 2012, 19:44
Is $info(codec_profile) populated by the compression level in the case of FLAC files?
skamp
post May 22 2012, 21:19
Nope. The compression level information isn't stored anywhere in FLAC's metadata blocks, and I don't believe it can be derived from anything.
spoon
post May 22 2012, 22:00
dBpowerAMP developer
Group: Developer (Donating)
Correct, FLAC does not indicate its compression rate (unless it was written to the ID Tags).
Spoon http://www.dbpoweramp.com
Soap
post May 23 2012, 02:04
Not that it matters. Recompress them all. It's not like you'll need your slide rule and a ream of paper to do it. It very well may take two weeks, but idle cycles are the devil's playthings!
Creature of habit.
Porcus
post May 23 2012, 11:27
In old days, there were lots of warnings that the --force might eat your files (the right thing for a converter to do is to write, compare, and then delete -- I believe this is the feature of dBpoweramp mentioned by EagleScout1998). If using --force, I would (and did) copy, recompress, verify and then copy back.
One day in the Year of the Fox came a time remembered well
RSS Lo-Fi Version Time is now: 26th December 2014 - 10:02
