32 Pages V  « < 8 9 10 11 12 > »
QAAC: discussion, questions, feature requests, etc., [originally a thread for a feature request]
LigH
post Sep 10 2012, 09:26
Post #226
QAAC is only a user interface for the original Apple QuickTime AAC and ALAC encoders.
http://forum.gleitz.info - das deutsche doom9/Gleitz-Forum
Anakunda
post Sep 13 2012, 12:00
Post #227
Anu info about what;s new in CoreAudioCodec 7.9.8.1????
sluggy
post Sep 13 2012, 13:06
Post #228
QUOTE (Anakunda @ Sep 13 2012, 12:00) *
Id like to know also. I just checked to see if there was a quicktime update only to find the apple site says the latest is 7.7.1 where i have been using 7.7.2 for a while now??
eahm
post Sep 13 2012, 16:53
Post #229
http://www.hydrogenaudio.org/forums/index....showtopic=96970
sluggy
post Sep 13 2012, 17:09
Post #230
QUOTE (eahm @ Sep 13 2012, 16:53) *
Thanks eahm, im still wondering why on the apple site the latest quicktime says 7.7.1 where 7.7.2 has been out for a while?
eahm
post Sep 13 2012, 17:24
Post #231
QUOTE (sluggy @ Sep 13 2012, 09:09) *
I was thinking the same yesterday, I guess 7.7.1 was the latest included with iTunes? Now you have to install it separately, no idea btw.
This post has been edited by eahm: Sep 13 2012, 17:24
kevinsham
post Sep 14 2012, 02:31
Post #232
I cannot encode mono files to aac using qaac now .
The output is always stereo no matter what parameters I tried.
It even output an HE-AAC v2 file if i specify -he.
I've installed iTunes 10.7.0.21.
nu774
post Sep 14 2012, 09:00
Post #233
QUOTE (kevinsham @ Sep 14 2012, 10:31) *
Open with QuickTime Player->window menu->movie inspector.
Or, check with Mediainfo (install the latest version).
ffmpeg/libav seems to judge mono HE-AAC file generated by Apple encoder to be stereo.
kevinsham
post Sep 14 2012, 12:25
Post #234
Itunes says so
http://postimage.org/image/n3e3k99yl/
So does foobar
http://postimage.org/image/t7as83wgn/
Anyway, seems that the result is the same when I do "Create AAC Version" within Itunes 10.7: it is encoded as he-aac v2 in stereo
kevinsham
post Sep 14 2012, 12:40
Post #235
Seems that Itunes can keep it to mono if i encode as LE.
Encode as HE will make it HEv2 which is of course in stereo.
Encode as HE / LE in qaac both results in stereo.
nu774
post Sep 14 2012, 13:30
Post #236
QUOTE (kevinsham @ Sep 14 2012, 20:40) *
Not reproducing here. The result of qaac is the same as iTunes.
It's funny that iTunes says mono HE-AAC files created by itself as stereo HE-AAC v2.
It actually is not HE-AAC v2 and not using any SBR extensions including PS. I confirmed this looking into bitstream (using debugger).
In this case, QuickTime player and Mediainfo are correct.
kevinsham
post Sep 14 2012, 13:46
Post #237
QUOTE (nu774 @ Sep 14 2012, 20:30) *
Oh yeah, for the LC file, foobar says stereo and itunes / quicktime says mono. So the behaviour for qaac is consistent with itunes and any "issue" is that caused by itunes only.
I think quicktime actually always says he v2 files are mono: i tested one encoded with nero aac.
BTW, i notice that for the nero he v2 files: foobar says SBR+PS stereo
For the itunes he file (mono source), foobar says SBR stereo
This post has been edited by kevinsham: Sep 14 2012, 13:47
lvqcl
post Sep 14 2012, 15:01
Post #238
QUOTE (menno @ Dec 10 2004, 19:53) *
Your HE AAC file IS mono, the decoder just outputs upmixed stereo. This is because of parametric stereo, which is always signalled implicitly. Because of that, the decoder upmixes ALL mono files to stereo, even if there is no PS in the file.
Menno
kevinsham
post Sep 14 2012, 15:59
Post #239
QUOTE (lvqcl @ Sep 14 2012, 22:01) *
Menno
What "decoder" is that quote referring to?
If Mediainfo is correct, all the below behaviors is wrong:
Itunes encoded LC file with mono source is reported as LC stereo in foobar.
Itunes encoded HE file with mono source is reported as HE stereo in foobar.
Itunes encoded HE file with mono source is reported as HEv2 stereo in Itunes.
In all 3 cases: the software actually decodes to 2 channels, as verified by their "convert to wav" output.
I think it is problem with foobar and itunes then.
kevinsham
post Sep 14 2012, 16:07
Post #240
QUOTE (kevinsham @ Sep 14 2012, 22:59) *
Menno
The last test I am doing: Nero encoded HE(v1) with mono source:
Itunes reported as HEv2 stereo.
So seems that Itunes is just reporting any HE files as "v2" and try decoding as stereo.
Issues should be reported to iTunes and foobar than.
Thanks for all the prompt replies.
QAAC is a great tool.
eahm
post Sep 20 2012, 22:18
Post #241
nu774, sorry I have to ask this, is there an option to remove the "Tool" tag while converting? I have few iOS projects and I would like to use Apple/TVBR for music files but I don't want to show how I converted them.
If not, could you create a new version with a "-notool" or similar option?
This post has been edited by eahm: Sep 20 2012, 22:28
nu774
post Sep 21 2012, 02:38
Post #242
QUOTE (eahm @ Sep 21 2012, 06:18) *
It's technically possible, but looks too special to be implemented as a generic option.
Can't you just remove tool tag after encoding?
In case you don't know how to do it, try mp4tags(CLI app) of mp4v2 project: mp4v2 download page
The following command line will remove tool tag from foo.m4a.
mp4tags -rE foo.m4a
Currently only a deprecated pre-built binary for Windows is out there and probably it has issues on non-ascii text handling, but it will be enough for this rather simple usage.
eahm
post Sep 21 2012, 02:53
Post #243
mp4tags works perfectly.
An option on your CLI would be amazing for mass encoding without it but it's perfect for now.
This post has been edited by eahm: Sep 21 2012, 03:04
eahm
post Oct 8 2012, 18:44
Post #244
[qaac] release 1.42 (refalac 0.53)
posted 3 hours ago by nu 774
MP4 container minor fix: added "isom" to compatible brands.
Also I started a new project [url="https://github.com/nu774/cafmux"]cafmux[/url] at github, which is a simple command line audio remuxer using CoreAudioToolbox.
https://sites.google.com/site/qaacpage/cabinet
Thanks for the update.
This post has been edited by eahm: Oct 8 2012, 18:44
Anakunda
post Oct 17 2012, 08:43
Post #245
There's new version: https://sites.google.com/site/qaacpage/cabi...rects=0&d=1
Fixed passband of --rate (sample rate converter of libsoxrate). Regression on 1.40. Default passband was not properly set, and resulted in audibly muffled sound when you do --rate=32000 or something.
Modified transition band width of --lowpass (was unnecessarily small).
Support CAF tag reading (qaac only).
eahm
post Oct 17 2012, 09:03
Post #246
QUOTE (Anakunda @ Oct 17 2012, 00:43) *
Yes but please link to the cabinet's url (https://sites.google.com/site/qaacpage/cabinet), people know what to download by their selves.
This post has been edited by eahm: Oct 17 2012, 09:04
eahm
post Oct 19 2012, 16:33
Post #247
Thanks for the 1.44 update and fixiTunSMPB. One question, why qtaacenc never needs updates?
nu774
post Oct 19 2012, 16:57
Post #248
QUOTE (eahm @ Oct 20 2012, 00:33) *
Well, is that kind of a question I can answer? I don't know.
I'm sorry for long standing iTunSMPB problem, I didn't notice it until now since I'm a fb2k user, and nobody reported of it.
eahm
post Oct 19 2012, 16:58
Post #249
Don't qaac and qtaacenc use the same "engine"? Sorry I'm not a programmer.
This post has been edited by eahm: Oct 19 2012, 16:58
nu774
post Oct 19 2012, 17:07
Post #250
QUOTE (eahm @ Oct 20 2012, 00:58) *
Yes, eventually same AAC encoder of Apple is used, but that's all.
These two are completely different programs written by different authors. For example, qaac doesn't use QuickTime at all.
RSS Lo-Fi Version Time is now: 19th December 2014 - 04:40
