2 Pages V  < 1 2
New portable Musepack decoder library, including fixed-point mode
Sebastian Anders...
post Aug 28 2004, 21:46
Post #26
Hello!
Is there any way to get the bits per sample (BPS) from the MusePack file?
Regards,
Sebastian Andersson
"I have not failed. I've just found 10,000 ways that won't work." -Thomas Edison
dev0
post Aug 28 2004, 22:06
Post #27
Why would you want to know the BPS of the source file?
Sebastian Anders...
post Aug 29 2004, 13:06
Post #28
QUOTE (Sebastian Andersson @ Aug 28 2004, 10:46 PM)
Hello!
Regards,
Sebastian Andersson
In this case, I need it for a function used by a BASS add-on (www.un4seen.com). But other reasons could be, to fill up the WAVEFORMAT structure with the proper information or whatever. smile.gif
dev0
post Aug 29 2004, 13:09
Post #29
QUOTE (Garf)
Why would the decoder care at all what the input resolution is, it doesn't matter at all for it?
It can choose freely whatever resolution or format it wants to decode to, there is no relation needed to whatever the input was.
This quote was related to AAC decoding but the same is true for MPC.
Sebastian Anders...
post Aug 29 2004, 13:11
Post #30
OK
This post has been edited by Sebastian Andersson: Aug 29 2004, 13:15
Sebastian Mares
post Sep 17 2004, 21:45
Post #31
So, is it possible or not?
http://listening-tests.hydrogenaudio.org/sebastian/
Tang
post Oct 20 2004, 20:58
Post #32
Group: Members (Donating)
I wonder there is no matter if I send a link to this thread to Rockbox team? Cause it could interest their iriverport project... smile.gif
Best regards,
Tang
PS: thanks also for foobar, even if it's a little off topic: i like your player
Tang
post Nov 3 2004, 01:42
Post #33
EDIT: i've just understood how the Rockbox WiKi was working... So i added directly the useful links/info in the Wiki: http://www.rockbox.org/twiki/bin/view/Main...Writing_CODEC_s
feel free to correct if there is something wrong (will need registering thought)
Pre edited post:
Just to say i've submited a link to this thread and the library itself on the rockbox board (for iriverport)...
here is the link:
http://forums.rockbox.org/index.php?topic=103.0
Best regards
This post has been edited by Tang: Nov 3 2004, 03:00
kuniklo
post Dec 12 2004, 17:34
Post #34
Group: Developer (Donating)
I've just finished a first rough port of this library to pure C, instead of C++, since a lot of people refuse to include C++ code in their apps.
It's currently available in a darcs repository at http://www.caddr.com/code/libmusepack/
I've started adding some documentation too, which can be found here:
http://www.caddr.com/code/libmusepack/docs/html/
I'd welcome any comments or suggestions. If you know of any project devs that would be interested in supporting musepack but have held off because of the C++ issue please let me know.
Thanks for the original work of putting this library together.
picard
post Dec 14 2004, 18:37
Post #35
I updated the old library in BetaPlayer's MPC plugin to libmusepack 1.03. But I had to put back SeekTable[] for faster seeking. Was there a reason why this was removed from libmusepack?
kuniklo
post Dec 14 2004, 18:40
Post #36
QUOTE (picard @ Dec 14 2004, 05:37 PM)
You're talking about the C++ version, right? I don't think there was such a thing in the 1.0.3 version I started with.
Lefungus
post Dec 14 2004, 18:45
Post #37
QUOTE (picard @ Dec 14 2004, 07:37 PM)
It was removed because it was broken and could produce artifacts.
It's a 'Jump to Conclusions Mat'. You see, you have this mat, with different CONCLUSIONS written on it that you could JUMP TO.
picard
post Dec 14 2004, 18:49
Post #38
Yes, I'am using the C++ version and the SeekTable was in the old version (before it was renamed to libmusepack I think).
Any more info in which case does it cause artifacts? More states should be saved not just frame length to be able to properly seek? Because for a mediaplayer the current non SeekTable solution is not really acceptable.
Tang
post Dec 14 2004, 18:55
Post #39
QUOTE (kuniklo @ Dec 12 2004, 08:34 AM)
Hi Kuniklo,
Very nice indeed... I do know the Rockbox firmware is written in C... I guess they would be interested for their iRiverport...
I'm gonna notify the team and give them your link... Maybe editing the WIki over there with your link too... smile.gif
Regards,
Tanguy
Lefungus
post Dec 14 2004, 18:56
Post #40
Some files have huge frame dependencies. There's no way to know how much, so the fast seeking can break on any file randomly. So although it can be made to seek correctly on most of the files, it's not error-proof.
Tang
post Feb 12 2005, 17:54
Post #41
The codec section of the Rockbox iRiverport wiki is updated:
http://www.rockbox.org/twiki/bin/view/Main/SoundCodecs
You can subscrbe to help in the API section:
http://www.rockbox.org/twiki/bin/view/Main...posal#CODEC_API
Cheers!
Tang
xmixahlx
post Feb 14 2005, 20:47
Post #42
someone on teh MDT should submit info for the "Encoder" table section...
RareWares/Debian :: http://www.rarewares.org/debian.html
Tang
post Feb 14 2005, 20:50
Post #43
QUOTE (xmixahlx @ Feb 14 2005, 11:47 AM)
??? Sorry what's MDT?
Florian
post Feb 14 2005, 20:52
Post #44
Mp3tag developer
Group: FB2K Moderator (Donating)
QUOTE (Tang @ Feb 14 2005, 08:50 PM)
Mp3tag - universal multi-format tag editor
http://www.mp3tag.de/en/
Tang
post Feb 15 2005, 18:43
Post #45
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 30th August 2014 - 00:43
