2 Pages V  < 1 2
looking for a mp3 player , can you give some advises?, a walkman
francesco
post Nov 23 2012, 11:28
Post #26
QUOTE (2Bdecided @ Nov 23 2012, 05:20) *
QUOTE (francesco @ Nov 23 2012, 06:35) *
you know what i miss , is a line out
The headphone output makes a perfectly good line out if you turn the volume up.
yes?
to connect to a densen amplifier , i'm worried to damage it
Sunhillow
post Nov 23 2012, 13:03
Post #27
Group: Members (Donating)
No worries, volume to max (and in settings maximum volume = "loud") ist just the normal line out level, only impedance is lower than a usual line out.
Does rockbox decode AAC?
skamp
post Nov 23 2012, 13:31
Post #28
Volume should be set to 0 dB in Rockbox, not the maximum which is +6 dB. And Rockbox decodes AAC, yes.
2Bdecided
post Nov 23 2012, 15:04
Post #29
ReplayGain developer
QUOTE (francesco @ Nov 23 2012, 10:28) *
yes?
I assume you mean a normal integrated amplifier, or a pre/power combination? If so, yes, it will be fine.
Don't use it with just a power amplifier (i.e. don't use it without a pre-amplifier). At very low volumes the clip is too hissy to be connected directly to a power amplifier, and isn't designed for that anyway.
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 25th July 2014 - 03:58
