IPB
EAC: how to compress after full rip (!per track)
ydeologi
post Oct 9 2005, 13:41
Post #1
Group: Members
I'm trying to configure EAC to run the external (lame) WAV->MP3 compression after an entire CD is ripped, rather than after each track is ripped, because right now, my CD ripping time stinks.
Can't find the option anywhere in EAC config. I'm thinking about disabling compression -- just using EAC for ripping and manually compresing each folder afterwards.
Am I missing the option in EAC?
Go to the top of the page
+Quote Post
Frank Bicking
post Oct 9 2005, 13:52
Post #2
Group: Super Moderator
First of all, you should enable the option Tools - On extraction, start external compressors queued in the background and set the number below to your amount of logical CPUs. This will cause EAC to rip the next track while the current one is being encoded.
+Quote Post
ydeologi
post Oct 9 2005, 13:54
Post #3
Group: Members
QUOTE (Frank_Bicking @ Oct 9 2005, 07:52 AM)
Thanks for the great tip - and for the quick response. I read this to mean a setting of 0 if you have 1 CPU, so that's what I'll do. Is there a FAQ I should read up on somewhere?
This post has been edited by ydeologi: Oct 9 2005, 13:56
+Quote Post
ydeologi
post Oct 9 2005, 14:14
Post #4
Group: Members
Next question: is it okay to run two instances of EAC ripping from two drives simultaneously?
+Quote Post
Frank Bicking
post Oct 9 2005, 14:19
Post #5
QUOTE (ydeologi @ Oct 9 2005, 02:54 PM)
To start 0 (=zero, no) compressors in the background while the next track is ripped makes no sense.
1 for a single core CPU (i.e. Athlon 64)
2 for a single core CPU with Hyper-Threading (i.e. Pentium 4)
2 for a dual core CPU (i.e. Athlon X2 or Pentium D)
4 for a dual core CPU with Hyper-Threading (i.e. Pentium D Extreme Edition)
+Quote Post
ydeologi
post Oct 9 2005, 14:25
Post #6
Group: Members
QUOTE (Frank_Bicking @ Oct 9 2005, 08:19 AM)
Thanks for helping it make sense.
+Quote Post
SlowPulse
post Oct 9 2005, 14:44
Post #7
Group: Members
QUOTE (ydeologi @ Oct 9 2005, 05:14 AM)
Yes, but if your drives are on the same IDE channel, then no
+Quote Post
SlowPulse
post Oct 9 2005, 14:46
Post #8
Group: Members
Also, you can make use of 'Compression queue control center' (Tools menu).
After you enable compressing in the background (EAC config, Tools tab), you can pause the queue, and then unpause it after you've done ripping in the control center
+Quote Post
k.eight.a
post Oct 10 2005, 10:39
Post #9
Group: Members
QUOTE (Frank_Bicking @ Oct 9 2005, 05:19 AM)
...or is it better to rip everything and then unpause the compression queue?
Sorry for my poor English, I'm trying to get better... ;)
"The greatest trick the Devil ever pulled, was convincing the world he didn't exist."
+Quote Post
Martin H
post Oct 12 2005, 03:17
Post #10
Group: Members
QUOTE (k.eight.a @ Oct 10 2005, 11:39 AM)
Yes...
QUOTE
No...
-Martin.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 21st October 2014 - 03:12
