21 Pages V  « < 18 19 20 21 >
foo_run 0.3.7, run external applications from foobar2000
marc2003
post Oct 20 2013, 08:53
Post #476
not possible. from another recent thread on the subject...
QUOTE (marc2003 @ Sep 18 2013, 18:58) *
as we haven't seen Florian around for quite some time, it's unlikely foo_run will be updated - but assuming you don't mind using buttons, i've made a script for WSH panel mod that can launch various websites using dynamic track titles. it looks like this...
the script is named web links inside this package. check the readme first. https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip
http://marc2003.x10host.com/updates
picco
post Nov 28 2013, 23:57
Post #477
hello, i have installed windows 8.1 with foobar 1.1.7 version. i need to extract with button the CD, and i use nircmd.exe
with windows 7 no problem, it work correctly, but with windows 8.1, foo_run not work!
you have experience with this?
marc2003
post Nov 29 2013, 03:29
Post #478
have you checked the application definitely works on 8.1 without using foo_run?
if it does work, there's no reason why 8.1 should behave any different to 7 when using foo_run. i suggest double checking your settings. also, remember that if your file path has () in it, they need to be escaped with ' like this...
C:\Program Files '('x86')'\blah\...
picco
post Nov 29 2013, 09:38
Post #479
QUOTE (marc2003 @ Nov 29 2013, 03:29) *
yes, it work correctly... sad.gif, i have tryed with compatibility winXP, windows 7, but not work with run service... i don't know...!!
This post has been edited by picco: Nov 29 2013, 09:54
mire777
post Nov 29 2013, 10:53
Post #480
For me on windows 7, foo run won't work if in path i have spaces like this C:\foobar2000 xch4\blabla.exe
What i need to write?
This post has been edited by mire777: Nov 29 2013, 11:06
marc2003
post Nov 29 2013, 11:05
Post #481
QUOTE (picco @ Nov 29 2013, 08:38) *
well as i'm running windows 8.1 myself, i installed foo_run and downloaded the nircmd app to test with and it works fine for me. i didn't have to do anything special. as i expected, the OS really is irrelevant.
QUOTE (mire777 @ Nov 29 2013, 09:53) *
it should work if you wrap the path in double quotes.
mire777
post Nov 29 2013, 11:16
Post #482
QUOTE (marc2003 @ Nov 29 2013, 12:05) *
picco
post Nov 29 2013, 12:08
Post #483
QUOTE (marc2003 @ Nov 29 2013, 11:05) *
i have tryed without double quotes in the path... this thing can be the problem? i have the spaces on the path...
This post has been edited by picco: Nov 29 2013, 12:10
marc2003
post Nov 29 2013, 14:13
Post #484
QUOTE (picco @ Nov 29 2013, 11:08) *
then you must use double quotes. give us the full command you're trying to use.
picco
post Nov 29 2013, 14:14
Post #485
QUOTE (marc2003 @ Nov 29 2013, 14:13) *
ok, so i will try!! thanks a lot!
picco
post Nov 30 2013, 09:06
Post #486
wolfsong
post Jan 28 2014, 08:23
Post #487
I have a bunch of albums where I want to grab both the cover and artist art using AAD. I have 2 separate entries right now but wondered if there was a way to do both in one step. I saw a similar reply here that suggested a batch file but I'm not sure how it would work. Here are the commands I'm currently using.
Album Cover
"C:\Program Files\AlbumArtDownloader\AlbumArt.exe"  /ae on -pf on /ar "%album artist%" -al "%album%" /p "$replace(%_path%,'\'%_filename_ext%,)" /f "cover.'%'extension'%'" /coverType front,unknown /mn 300 /sources all /exclude "LastFM Artist" /o o /localImagesPath "$replace(%path%,%filename_ext%,cover.jpg)"
Artist
"C:\Program Files\AlbumArtDownloader\AlbumArt.exe"  /ae on -pf on /ar "%artist%" /p "C:\Users\Cristov\Music\Artist Art\'%'artist'%'.'%'extension'%'" /sources "GoogleImage,LastFM Artist" /o o /localImagesPath "$replace(%path%,%filename_ext%,folder.*g)" /mn 150
[url="http://www.last.fm/user/wolfsong/"]Last.fm Profile[/url]
r3v0
post Jan 31 2014, 23:37
Post #488
Hi, i'm trying to figure out what I do wrong with this line:
"C:\Python27\python.exe" "C:\Users\Administrator\Desktop\test\test.py" -i "%_path%"
This opens quick a cmd window, and that shuts down immediately, and doesn't execute the python script. huh.gif
<3 f00
marc2003
post Feb 1 2014, 00:16
Post #489
try adding cmd /c to the start...
cmd /c "c:\python...
@wolfsong, you can pass parameters to a batch file like this....
aad.bat "%album artist%" "%album%"
then inside your bat file, you can access the first parameter with %1, the 2nd with %2 and so on. eg
albumart.exe /ar %1 /al %2
This post has been edited by marc2003: Feb 1 2014, 00:20
r3v0
post Feb 1 2014, 08:11
Post #490
QUOTE (marc2003 @ Feb 1 2014, 00:16) *
Thanks, I'll try that.
<3 f00
r3v0
post Feb 2 2014, 13:40
Post #491
QUOTE (r3v0 @ Feb 1 2014, 08:11) *
<3 f00
Anakunda
post Feb 9 2014, 10:49
Post #492
Hello, would that be possible make certain service commands show in menu conditionally depending on various media file parameters, like for example I want a command that would be available only for lossless files, a command for files only with extension from a limited list (depending on which formats the external app supporting), etc.. I think this would greatly improve the menu readability by excluding services not available for current selection. Also I'm curious if that would be possible insert separator lines or even submenus in the Services menu.
My second question is if it would be possible run service command for a whole selecction, ie. passing to external command a list of selected tracks separated by space or something such. Eventually the plugin could save the list of interpolated user's pattern to temp file instead, then passing the list filename to external service as argument. But this is most programs not supporting. A space delimited list on commandline would be enough ;P
wolfsong
post Feb 16 2014, 03:40
Post #493
QUOTE (marc2003 @ Nov 29 2013, 07:13) *
This doesn't work for me on 8.1 either.
"C:\Program Files (x86)\NirCmd\nircmd.exe" cdrom open d:
I copied it directly from a working shortcut on the desktop.
marc2003
post Feb 16 2014, 04:10
Post #494
() are special characters in foobar title formatting so you need to wrap them in single quotes like this...
"C:\Program Files '('x86')'\NirCmd\nircmd.exe" cdrom open d:
wolfsong
post Feb 16 2014, 06:30
Post #495
QUOTE (marc2003 @ Feb 15 2014, 21:10) *
Fixed!
magnar
post May 14 2014, 06:24
Post #496
Group: Banned
QUOTE (wolfsong @ Jan 28 2014, 08:23) *
Album Cover
Artist
Open notepad and make a cmd/bat file called something like Albumart_cover_and_artist_fetch.cmd containing something like this (which I quickly wrapped together for you. could probably have made it with less parameters, but works in my end):
@ECHO OFF
START "Searching for album cover" /d"C:\Program Files\AlbumArtDownloader" /i /NORMAL AlbumArt.exe /ae on -pf on /ar %1 -al %2 /p %3 /f %4 /coverType front,unknown /mn 300 /sources all /exclude "LastFM Artist" /o o /localImagesPath %5
START "Searching for artist picture" /d"C:\Program Files\AlbumArtDownloader" /i /NORMAL AlbumArt.exe /ae on -pf on /ar %6 /p %7 /sources "GoogleImage,LastFM Artist" /o o /localImagesPath %8 /mn 150
Alternatively you could do without the start command if you dont want both searches to simultaneously pop up (but I figured you did), this would simply queue the searches instead:
"C:\Program Files\AlbumArtDownloader\AlbumArt.exe" /ae on -pf on /ar %1 -al %2 /p %3 /f %4 /coverType front,unknown /mn 300 /sources all /exclude "LastFM Artist" /o o /localImagesPath %5
"C:\Program Files\AlbumArtDownloader\AlbumArt.exe" /ae on -pf on /ar %6 /p %7 /sources "GoogleImage,LastFM Artist" /o o /localImagesPath %8 /mn 150
The scripts parameters for the lovely Foobar2000 component Foo_run should then be:
Albumart_cover_and_artist_fetch.cmd "%album artist%" "%album%" "$replace(%_path%,'\'%_filename_ext%,)" "cover.'%'extension'%'" "$replace(%path%,%filename_ext%,cover.jpg)" "%artist%" "C:\Users\Cristov\Music\Artist Art\'%'artist'%'.'%'extension'%'" "$replace(%path%,%filename_ext%,folder.*g)"
This post has been edited by magnar: May 14 2014, 06:28
fohrums
post Jul 24 2014, 21:55
Post #497
How can I use foo_run Foobar2000 to open selection of tracks to audacity? Because this doesn't work
"C:\Program Files (x86)\Audacity\audacity.exe" "$directory(%path%)"
This post has been edited by fohrums: Jul 24 2014, 21:55
lvqcl
post Jul 24 2014, 21:58
Post #498
See post #494.
Hurlex
post Oct 9 2014, 03:01
Post #499
Is it possible to have a script embed artwork if you already have the image?
marc2003
post Oct 9 2014, 14:18
Post #500
just select some files>right click>tagging>attach pictures (or batch attach pictures).
RSS Lo-Fi Version Time is now: 4th March 2015 - 18:14
