6 Pages V  « < 4 5 6
Closed TopicStart new topic
flac 1.3.0 pre-release
ktf
post May 25 2013, 13:35
Post #126
QUOTE (BFG @ May 24 2013, 23:24) *
Quick question - does anyone have (or can anyone build) a script which will decode all 1.2.1-FLAC files in a given folder structure, and reencode at 1.3.0, preserving metadata/tags? I always use the strongest possible compression so would be interested in doing this, even if the disk space saved would be miniscule.
To answer this question, the flac command line tool can do this. Just use 'flac -f file.flac' to re-encode the FLAC file while preserving all tags. To do this with a whole folder would be 'flac -f *.flac', with a whole folder of folders of flac files 'flac -f */*.flac' and so on.
skamp
post May 25 2013, 14:57
Post #127
Or, on Linux / OS Ⅹ / Unix:
$ find . -type f -iname '*.flac' -exec flac -f --best '{}' ';'
Porcus
post May 25 2013, 20:24
Post #128
Is flac -f safe? Or can it mess up the transaction under e.g. write errors?
One day in the Year of the Fox came a time remembered well
skamp
post May 25 2013, 20:35
Post #129
flac -f writes to a temporary file, before overwriting the original.
ktf
post May 25 2013, 21:56
Post #130
I guess you should use it with -V to check that the encoding went right. It transcodes to a temporary file (file.flac,fl-ac+en'c), and when finished, it removes the original and renames the new file.
Which makes sense, because a lossless codec should be as safe as possible. The command line tools have been designed with the same goal.
This post has been edited by ktf: May 25 2013, 21:56
romor
post May 27 2013, 22:18
Post #131
For restless, it arrived: http://downloads.xiph.org/releases/flac/
For normal people, it should be formally announced in next day or two
scripts: http://goo.gl/M1qVLQ
lamedude
post May 28 2013, 08:18
Post #132
For even more restless I made binaries. Requires VC12 runtime.
Brazil2
post May 29 2013, 09:02
Post #133
QUOTE (ktf @ Apr 10 2013, 11:50) *
This is the build I tested this morning, which is current git plus the two UTF-8 patches by case. This one is without the long line patch though.
http://www.icer.nl/misc_stuff/flac-mingw-g...utf8patches.zip
Please, is there any chance to get a GCC build of the release as well ? smile.gif
ktf
post May 29 2013, 11:57
Post #134
QUOTE (Brazil2 @ May 29 2013, 10:02) *
Yeah, sure, but you haven't told me yet why the Visual Studio build isn't good enough. It isn't faster (yes, I actually tested that), only a little bigger. http://www.icer.nl/misc_stuff/flac-1.3.0-final-minGW.zip
Brazil2
post May 29 2013, 12:56
Post #135
QUOTE (ktf @ May 29 2013, 12:57) *
Because:
I want to do some tests and comparisons between different builds.
I find the GCC builds slightly faster than the MSVC2010-2012 builds on my main multimedia machine which is still running XP. It's about the same speed as MSVC2008 builds though (Dj vu).
I'm often moving and changing location and the GCC builds can run out of the box on any machine I may work on, including older Windows versions, without the need to find and install the required runtimes which is sometimes impossible to do if the machine has been locked by some admin.
Anyway, thanks for this build, it's working like a charm as expected smile.gif
Wombat
post May 29 2013, 16:18
Post #136
Werent John33 ICL compiles from RareWarez always that slightly faster?
BFG
post May 30 2013, 02:18
Post #137
QUOTE (ktf @ May 29 2013, 05:57) *
Confirmed to work with EAC.
DragonQ
post Jun 12 2013, 11:07
Post #138
I wonder why the download links on the Xiph website aren't updated yet? I only ever use FLAC in two programs - Foobar and EAC, and both work with FLAC 1.3.0 so that's fine for me.
ernstblaauw
post Jun 13 2013, 19:13
Post #139
I'm looking for a 64-bit Linux build for my Linux Mint system. Possibly just a standalone static linked build, that would be fine (of course a .deb would be the best).
However, I cannot find a Flac 1.3.0 version for a Debian-based system. Does anyone here know how I can get one?
Makaki
post Jun 13 2013, 19:29
Post #140
http://packages.debian.org/search?keywords=flac
see: sid (unstable)
1.3.0-1: alpha amd64 armel armhf hurd-i386 i386 ia64 kfreebsd-amd64 kfreebsd-i386 mips mipsel powerpc powerpcspe s390 s390x sparc sparc64
NOTE:
To check the same on Ubuntu:
http://packages.ubuntu.com/search?keywords=flac
(but ubuntu doesn't seem to have 1.3.0 at the time of this post)
ernstblaauw
post Jun 13 2013, 19:43
Post #141
QUOTE (Makaki @ Jun 13 2013, 11:29) *
see: sid (unstable)
NOTE:
I had to download the flac amd64, libflac8 amd64 and libflac8 i386 build. Now, I have flac 1.3.0 available on the command line.
db1989
post Jun 13 2013, 20:41
Post #142
Since (A) this thread was meant for discussion about the pre-release, not the final, and (B) its usually suboptimal for both readers and staff to have multiple discussions open about one specific subject, I think this thread should be closed in favour of the final-specific thread in Validated News. If no one presents any valid objection in the near future and everyone can get the loose ends of discussion tied up, Ill do just that.
I would split this, but then, yknow, wed still have two threads. Neither can I merge the relevant posts with the other thread as the first of them predates the opening post over there, and anyway, birdie made an effort to submit that thread to News, so its polite to let birdie retain authorship of it. Ill consider merging in some of the later posts from here but can make no promises; that sort of thing can get very confusing. tongue.gif
greynol
post Jun 13 2013, 21:07
Post #143
Naw, this thing should have been closed once it was released.
Placebophiles: put up or shut up!
6 Pages V  « < 4 5 6
RSS Lo-Fi Version Time is now: 24th July 2014 - 02:55
