ReplayGain storage
jukkap
post Aug 11 2011, 22:31
I am currently building new Musepack plug-ins and I am wondering which is the preferred method of storing ReplayGain information to Musepack files ?
Store to Musepack format ?
or
Store to APE tag ?
Antonski
post Aug 11 2011, 23:36
According to specification, RG info must be stored in the file header. Every Musepack capable player that I've tried reads and writes RG in this way.
jukkap
post Aug 12 2011, 06:45
Thanks for pointing the Musepack wiki. I don't know why I did not see it earlier but it is lots of help. I will do both SV7 and SV8 and they both seem to have ReplayGain in the header.
Notat
post Aug 12 2011, 15:10
The ReplayGain specification suggests APEv2. Do we need to update/correct this?
This post has been edited by Notat: Aug 12 2011, 15:10
MostlyHarmless
post Aug 13 2011, 01:37
Musepack was the first (and only?) format with native ReplyGain support. Storing of ReplayGain info in tags seems to me as a workaround for older formats without native support.
saratoga
post Aug 13 2011, 02:29
QUOTE (Notat @ Aug 12 2011, 10:10) *
It should probably be updated to mention that replaygain tags are used with ASF tags (in the Extended Content Description Object) with the VorbisGain method (basically just a text comment field that says "replaygain_track_gain", ...).
See for example:
http://svn.rockbox.org/viewvc.cgi?diff_for...;revision=15340
Notat
post Aug 13 2011, 22:14
Appreciated but that's not very accessible information so can't just be C-P'd into the RG spec. If you can suggest some replacement text for the RG spec, we can get this corrected more quickly.
saratoga
post Aug 14 2011, 21:04
I added that it uses the Extended Content Description Object with a ascii value key pair like Vorbis comments. Might make sense to have Peter comment on it though, since AFAIK he came up with the standard. We just looked at ASF files tagged with foobar2000 and copied it's convention.
Lear
post Aug 14 2011, 22:02
VorbisGain developer
QUOTE (saratoga @ Aug 13 2011, 02:29) *
Antonski
post Aug 24 2011, 01:32
QUOTE (jukkap @ Aug 12 2011, 00:31) *
I am currently building new Musepack plug-ins ...
May I ask you what player(s) are they targeted?
As you can see in specification, there might be different RG values for every chapter.
RSS Lo-Fi Version Time is now: 20th September 2014 - 13:01
