2 Pages V  < 1 2
FLAC 1.1.0 released
X-Fixer
post Feb 4 2003, 16:16
Post #26
http://x-fixer.narod.ru/download/in_flac.zip
updated version of winamp2 plug-in. includes some fixes and improvements, as usual.
Annuka
post Feb 4 2003, 16:24
Post #27
QUOTE (X-Fixer @ Feb 4 2003 - 05:16 PM)
A minor request:
Show bitrate of original wave - this is after all what comes out of my speakers.
Keep up the good work!
X-Fixer
post Feb 4 2003, 18:27
Post #28
you mean show this value in infobox? I'm afraid there's no space left tongue.gif
madah
post Feb 5 2003, 20:24
Post #29
I think I found a bug in flac, when encoding from stdin:
flac 1.1.0, Copyright (C) 2000,2001,2002,2003 Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
options: -P 4096 -b 4608 -m -l 8 -q 0 -r 3,3
-: 0% complete, ratio=1,593
-: 0% complete, ratio=0,647
-: 0% complete, ratio=0,628
-: 0% complete, ratio=0,640
-: 0% complete, ratio=0,662
-: 0% complete, ratio=0,678
-: 0% complete, ratio=0,689-: WARNING: unexpected EOF; expected 536870911 samples, got 1852416 samples
-: 0% complete, ratio=0,691
The resulting flac plays fine, but it has 1217 seek points, compared to 4 seek points when encoding directly from .wav.
When looking at metaflac --list, the piped .flac has total samples: 1853626, while the direct encoded one shows total samples: 1853615.
The piped .flac also has a lot of frame_samples=0 which doesn't seem right.
Used lame 3.92 --decode and flac 1.1.0.
The output logs (metaflac --list and stderr) was too large to post, so I zipped it up here
jcoalson
post Feb 6 2003, 01:29
Post #30
FLAC Developer
QUOTE (madah @ Feb 5 2003 - 02:24 PM)
Clarification:
1) you were piping in the same wave file?
2) how were you piping it in? a) command.com shell; b) cygwin bash (which version?); c) gui frontend (which?)
3) if a) or b) could you post the two encoding commands you used? (piped and non-piped)
In the meantime I'll take a look
Josh
(edit: disable cursed smileys)
This post has been edited by jcoalson: Feb 6 2003, 01:31
madah
post Feb 6 2003, 03:16
Post #31
I was bug-testing my own frontend (Frontah) but running this under cmd.exe (win2000) yielded the same results:
lame --decode inputfile.mp3 - | flac -o outputfile.flac - 2>stderr.txt
stderr.txt:
then trying manually decode to wav:
flac inputfile.mp3.wav 2>stderr2.txt
stderr2.txt:
tech1.mp3.wav: 0% complete, ratio=0,408
tech1.mp3.wav: 16% complete, ratio=0,629
tech1.mp3.wav: 32% complete, ratio=0,619
tech1.mp3.wav: 48% complete, ratio=0,634
tech1.mp3.wav: 64% complete, ratio=0,657
tech1.mp3.wav: 80% complete, ratio=0,674
tech1.mp3.wav: 96% complete, ratio=0,686
tech1.mp3.wav: wrote 5100793 bytes, ratio=0,688
X-Fixer
post Feb 6 2003, 06:18
Post #32
question to winamp plug-in users:
currently tag editor has field "comment", but uses tag "description" for it. I think this should be changed. but I don't know should I rename field to "description" or start using tag "comment"?
Volcano
post Feb 6 2003, 16:06
Post #33
Group: Members (Donating)
The lattter. smile.gif All other formats do it that way.
X-Fixer
post Feb 6 2003, 19:51
Post #34
ok, updated version is out.
jcoalson
post Feb 7 2003, 02:20
Post #35
FLAC Developer
QUOTE (madah @ Feb 5 2003 - 09:16 PM)
One last request, could you try the same piping command, but include -V also?
lame --decode inputfile.mp3 - | flac -V -o outputfile.flac - 2>stderr.txt
and let me know if you get a verify error? Thanks.
Josh
madah
post Feb 7 2003, 07:17
Post #36
stderr:
options: -P 4096 -b 4608 -m -l 8 -q 0 -r 3,3 -V
The file seems fine, to be absolutely sure:
flac -t outputfile.flac 2>stderr2.txt
outputfile.flac: testing, 16% complete
outputfile.flac: testing, 32% complete
outputfile.flac: testing, 48% complete
outputfile.flac: testing, 64% complete
outputfile.flac: testing, 80% complete
outputfile.flac: testing, 95% complete
outputfile.flac: testing, 100% complete
outputfile.flac: ok
It's just that it has a large amount of seek points.
X-Fixer
post Feb 7 2003, 08:26
Post #37
Josh (just to be sure), since we're talking about Windows, are you sure you set stdin and stdout modes to binary?
jcoalson
post Feb 7 2003, 20:52
Post #38
FLAC Developer
QUOTE (madah @ Feb 7 2003 - 01:17 AM)
OK, thanks. I'll try to reproduce it.
QUOTE (X-Fixer @ Feb 7 2003 - 02:26 AM)
Yep, that was fixed some time ago. It worked for me when I tested it in command.com, but for some reason it does not work with my (old) version of cygwin bash. But if I don't explicitly set the file mode, it works in bash but not in command.com. Maybe a newer version of cygwin would work.
I don't think have a cmd.exe to test with; my old windows box is NT4 SP5.
Josh
X-Fixer
post Feb 10 2003, 12:24
Post #39
QUOTE (jcoalson @ Feb 8 2003 - 02:52 AM)
well... my NT4 SP6.1 has cmd.exe, so I guess, your should have too. otherwise, I can send you cmd.exe from win2k - it seems to work fine under NT4.
CiTay
post Feb 10 2003, 14:42
Post #40
Administrator
Group: Admin
Is there a switch to show the compression speed (x * realtime)? If not, i hereby request this feature. wink.gif
fairway
post Feb 10 2003, 17:10
Post #41
Did you already think about implementing file splitting in several tracks when a cue sheet is found? I believe there was a plugin for winamp called mp3cue, so you might just ask the author how it is done. After all that cddb can be used for artists/tracks.
X-Fixer
post Feb 11 2003, 05:36
Post #42
mp3cue uses a different approach (not usable from input plug-in) - it creates it's own playlist window, instead of using standard one. that's not what I want.
in fact, the only problem is to add entries to winamp playlist. I don't know an easy way of doing this.
edit: may be someone can ask the author of mp3cue to add support for flac? it seems to be not too hard wink.gif
This post has been edited by X-Fixer: Feb 11 2003, 05:38
Volcano
post Feb 11 2003, 10:46
Post #43
QUOTE (X-Fixer @ Feb 11 2003 - 05:36 AM)
It already works with any audio format. See this thread for more information. smile.gif
X-Fixer
post Feb 12 2003, 05:58
Post #44
but it only works with external cue file, not with cuesheet metadata in flac file. doesn't it?
Sachankara
post Feb 12 2003, 07:45
Post #45
jcoalson,
How about allowing UTF-8 input via the command line encoder which can then be converted into Unicode by FLAC itself? I find it much more simple to pass UTF-8 formated text to a console application than trying to pass Unicode code. Or perhaps it's just me? huh.gif
(Something like --utf-8 could be used to tell FLAC that the text passed to it will be in UTF-8 format...)
This post has been edited by Sachankara: Feb 12 2003, 07:46
LordofStars
post Feb 12 2003, 21:37
Post #46
Xfixer to add files to the playlist why not use the enque to winamp function? Just use the same switches the shortcut passes to the exe file when you use the right click menu.
r3mix zealot.
X-Fixer
post Feb 13 2003, 10:25
Post #47
this is the only way I know (though I think there's an undocummented function for it, like the one for deleting entries from playlist). the main problem with it, is that files will be added to the end of playlist, instead of original entry location.
LordofStars
post Feb 13 2003, 20:37
Post #48
yeah it does appear as a problem but if people added one cue sheet then split it then added the next sheet it should work right? Somewhat tedious but they would only have to do it once.
r3mix zealot.
RenneCt
post Apr 2 2003, 15:50
Post #49
the plug-in has very low task priority, so i can't play games and listen to music sad.gif
X-Fixer
post Apr 4 2003, 04:54
Post #50
[FAQ] http://x-fixer.narod.ru/download/in_flac.zip
this one has priority slider in config
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 3rd September 2015 - 08:38
