15 Pages V  « < 11 12 13 14 15 >
foo_quicksearch, New version of foo_uie_quicksearch
compoopers
post Dec 10 2012, 12:03
Post #301
I'm having a problem with genre searching.
I have, say, three albums.
One album is tagged "Jazz; Hip Hop"
Album2 is tagged "Jazz"
And Album3 is tagged "J-Jazz" (Japanese Jazz)
When I search "Jazz", I want Album1 and Album2 to show up. But not Album 3.
If I do "match all", all three albums show up. If I do exact, only Album2 shows up.
What do I do to fix this? I thought "Jazz; Hip Hop" should be treated as "Jazz" and "Hip Hop" not the singular tag "Jazz; Hip Hop"
Any insight on how to fix this
ONDr
post Jan 10 2013, 14:21
Post #302
Hello!
Would it be possible to add option to "select all" on focus? I mean if you click on the search box (or use shortcut), the edit box would automatically select the input (like if you press Ctrl+A). We already have option to clear the field after successful search, but this requires hitting Enter if autosearch is enabled. It is just a little detail, but it would be great feature for me, since I use shortcut to focus the search bar, but I often forget to clear the previous the input. This way it would be rewritten with new input. Also this way it would be still possible to edit the old input since it would not be cleared, just selected.
What do you think about this?
Thank you very much for reply.
kdefine
post Jan 18 2013, 00:59
Post #303
Hello folks, I can't seem to get quicksearch to show up in my toolbar options despite having it installed.
Dario
post Jan 18 2013, 03:13
Post #304
You can only do that with Columns UI, unfortunately. You'd have to add it as a separate element in the Default UI.
wolfsong
post Feb 6 2013, 06:51
Post #305
I'm trying to create a context item that will do a quicksearch for the same artist with ratings. I tried the following but it seems something is going on with the ratings portion that it doesn't like. I've tried with and without parens and I get results that pretty much ignore the ratings. Any ideas?
%artist% AND %rating% GREATER 3
BenB
post Feb 6 2013, 08:00
Post #306
Definitely something weird happening with %rating%. When performing any search regarding %rating% via the context menu, it results in only tracks with the rating of the file you engaged the context menu on being returned. Thus only tracks with a rating of 4 will be returned if you right-clicked on a track with a rating of 4.
If you append the search string to the playlist name, you'll see 4 GREATER 3, 4 LESS 3, 4 IS 3, 4 PRESENT, 4 MISSING, etc.
This post has been edited by BenB: Feb 6 2013, 08:02
NEMO7538
post Feb 7 2013, 07:23
Post #307
QUOTE (wolfsong @ Feb 6 2013, 06:51) *
Try %artist% %rating%. It will search for the same artist and rating than the current selection (unless rating is empty, in which case it will return all tracks from the same artist).
BenB
post Feb 7 2013, 20:24
Post #308
So... what wolfsong wanted isn't possible because, obviously, searches via the context menu can only use the value of the specified variable of the selected track. I should've realized that. I really shouldn't post at one in the morning when I'm wacko.gif .
wolfsong
post Feb 8 2013, 15:22
Post #309
QUOTE (NEMO7538 @ Feb 7 2013, 00:23) *
In that case it's going to produce the same results as just %artist% so there would be no way to just find rated tracks by artist.
This post has been edited by wolfsong: Feb 8 2013, 15:23
NEMO7538
post Feb 8 2013, 18:50
Post #310
QUOTE (wolfsong @ Feb 8 2013, 15:22) *
In that case it's going to produce the same results as just %artist% ....
No
BenB
post Feb 8 2013, 20:51
Post #311
QUOTE (NEMO7538 @ Feb 8 2013, 11:50) *
No
If the selected track is unrated, then he is correct that it is basically the same as using %artist% because %rating% is ignored and all tracks, rated and unrated, by that artist are returned.
I'd argue that it would be better if %rating% returned all rated tracks if the selected track is rated and all unrated tracks if it isn't (esp. when it is used in conjunction with other variables, if that is even possible).
QUOTE (wolfsong @ Feb 8 2013, 08:22) *
Searches via the context menu are essentially IS queries. If you do a search using %artist% %rating%, then it searches for all tracks where those tags match the selected track with the exception that if %rating% doesn't exist for the selected track, then %rating% is ignored, e.g.:
If the artist is "The Beatles" and the rating is "4" for the selected track, then it returns all tracks where the artist is "The Beatles" and the rating is "4".
If the artist is "The Beatles" and the track is not rated, then it returns all tracks where the artist is "The Beatles".
This post has been edited by BenB: Feb 8 2013, 21:01
NEMO7538
post Feb 9 2013, 09:50
Post #312
QUOTE (BenB @ Feb 8 2013, 20:51) *
Yes
NEMO7538
post Feb 9 2013, 11:03
Post #313
Then use %artist%[-%rating%]. It should produce the desired results.
wolfsong
post Feb 12 2013, 03:22
Post #314
QUOTE (NEMO7538 @ Feb 9 2013, 04:03) *
Even this does not produce the desired results. All tracks by the artist are returned, not just tracks that a rated. It doesn't seem to matter what is used, this is always the case.
[url="http://www.last.fm/user/wolfsong/"]Last.fm Profile[/url]
god_of_music
post Feb 12 2013, 05:34
Post #315
Hi. How can I view which of the 50+ playlists contain the searched item ?
NEMO7538
post Feb 12 2013, 07:28
Post #316
QUOTE (god_of_music @ Feb 12 2013, 05:34) *
You can't.
god_of_music
post Feb 12 2013, 08:03
Post #317
You can't.
Can you please add this feature to plugin ?
ubercow
post Feb 13 2013, 15:01
Post #318
QUOTE (ONDr @ Jan 10 2013, 13:21) *
Hello!
I came to find this thread just to ask for this, I have used this component for years and it is basically perfect apart from this sore usability problem.
rangi_chip
post Jun 13 2013, 04:02
Post #319
Hi there, absolute great plugin, love it!
Just two features that would go hand-in-hand that I would like to request if possible...,
Firstly, can you add a checkbox to Preferences > Media Library > Quick Search: "Start playback when sending search results to playlist"
And also, is there any way of keeping the focus on the Quick Search toolbar?
My aim is just to type in a search, hit enter, it plays that/those track(s) and then stops. Then I just type in my next search, hit enter, etc.
Thanks for your help!
This post has been edited by rangi_chip: Jun 13 2013, 04:04
mire777
post Oct 1 2013, 09:43
Post #320
This plugin is awesome, but i have some future request:
-Add transparent background for CUI-DUI
-Add custom bitmap (foobar)relative path (in that way we will not lose bit. image if move foobar on other location).
-Add tekst in input box: ''Quick Search'' when cursor leave box
-Add preset for search genre ''pop, rock, soul.. etc..
Did some of this can be implemented?
Thanks for this great plugin..
This post has been edited by mire777: Oct 1 2013, 09:46
k33
post Oct 11 2013, 13:48
Post #321
Hello, can anybody suggest about my problem:
When I search with either context menu or GUI element.
Search seems complete successfully.
Target playlist name appends with search string and I can see number of songs in Playlist organizer ...
But it turns 0 immedietly and can't be even activated.
Tundra
post Nov 18 2013, 09:57
Post #322
How do I jump to the next search result while in inline-search mode?
Tundra
post Dec 12 2013, 18:28
Post #323
QUOTE (Tundra @ Nov 18 2013, 12:57) *
This is really bothering me.
lvqcl
post Dec 12 2013, 18:40
Post #324
Is this what you need? -- "If "Set Focus to search results" is not selected in the preferences page, navigation in the selected results is available through the "Up" and "Down" arrow keys."
http://wiki.hydrogenaudio.org/index.php?ti..._quicksearch%29
This post has been edited by lvqcl: Dec 12 2013, 18:44
Tundra
post Dec 17 2013, 16:15
Post #325
Yes, exactly. But why would someone bind another two keys instead using same "enter" key to navigate through results ?
RSS Lo-Fi Version Time is now: 1st August 2015 - 15:02
