> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
basic playlist_loader
JohanDeBock
post Nov 27 2009, 02:58
class playlist_loader_spl_xspf : public playlist_loader {
virtual void open(const char* p_path, const service_ptr_t<file>& p_file, playlist_loader_callback& p_callback) {
pfc::list_t<metadb_handle_ptr> tracks;
How should I return the playlist in the open() function knowing that the metadb_handle_ptr's of the playlist traks are in the variable tracks?
foo_softplaylists: http://tiny.cc/kh9m9
Yirkha
post Nov 27 2009, 10:17
Group: FB2K Moderator
By calling various methods of p_callback during processing.
JohanDeBock
post Nov 27 2009, 15:51
Hmm I think it is impossible to do what I want with the normal playlist_loader .
I want to load an xspf playlist, but it will only include track_title track_artist couples, so no paths to a filename. A pure soft playlist.
So I need access to the library. But I think that is not possble?
static_api_ptr_t<library_manager> lm;
lm->get_all_items(library);
This doesn't seem to work.
So is there a way around it, or will i have to make a special menu entry to load these type of playlists?
And if yes, is there a fucntion provided to display a file load dialog filtered by an extension?
Yirkha
post Nov 27 2009, 21:06
QUOTE (JohanDeBock @ Nov 27 2009, 15:51) *
How specifically?
uGetOpenFileName().
foosion
post Nov 27 2009, 21:11
Group: FB2K Moderator (Donating)
From the SDK documentation for class library_manager:
All methods are valid from main thread only, unless noted otherwise.
JohanDeBock
post Nov 27 2009, 22:02
Thanks for the info, I've made separate menu entries for what I'm trying to do.
RSS Lo-Fi Version Time is now: 7th May 2015 - 08:54
