How to convert WAV 32 bit float to WV 32 bit float
David the Chanse...
post Oct 9 2013, 21:58
I have audio files in WAV (32 bit float, 96kHz) format, and I wish to compress them (losslessly) to save space. FLAC doesn't support 32 bit float if I am not mistaken, so I am hoping to convert these files to WV instead. How can I go about this? Is it possible/recommended to use Audacity? I have downloaded WavPack Win32 and the Winamp Plugin from wavpack's website, but I am unsure how to go about converting the WAV files retaining the 32 bit float bit rate. Any help would be greatly appreciated.
saratoga
post Oct 9 2013, 22:04
I would use a tool that can do batch conversions, like foobar2000 or dbpoweramp, then set the appropriate settings (lossless mode, 32 bit float) in the gui.
David the Chanse...
post Oct 9 2013, 22:50
QUOTE (saratoga @ Oct 9 2013, 22:04) *
I downloaded the latest version of foobar2000 (v1.2.9) and converted 1 of the WAV files to WV 32 bit (it doesn't specify that it's float). I then played it in Winamp with the plugin but the 1:55 file played extremely quickly, lasting just 10-15 seconds. It didn't sound like a sped up version of the original file either, it was just noise. Was the conversion 32 bit float? And why did the file play like this?
Edit: in the configurations for WavPack Decoder 2.8a in Input Plugins in Winamp, checking the "always output 16-bit audio" box makes the playback work. However, I would ideally prefer 24 bit playback. The WV file plays fine in foobar2000.
This post has been edited by David the Chansey: Oct 9 2013, 22:57
saratoga
post Oct 9 2013, 22:59
Edit: saw that you figured it out.
Do you actually need winamp at all? Generally one uses floating point for editing. If you're done editing and want to actually listen to the files I would convert them to something more compatible.
This post has been edited by saratoga: Oct 9 2013, 23:01
David the Chanse...
post Oct 9 2013, 23:12
QUOTE (saratoga @ Oct 9 2013, 22:59) *
I'd prefer to keep them at 32 bit float for archiving, but also be able to play them with no need for more conversion. I don't need Winamp, but I do like it. I'll see if I like foobar, and stick to it if I do.
Also, is the WV file actually 32 bit float? The option for bit depth when converting only said 32 bit.
eahm
post Oct 10 2013, 00:46
QUOTE (David the Chansey @ Oct 9 2013, 15:12) *
http://www.wavpack.com/ read the Features section.
4.70 stable is coming soon.
This post has been edited by eahm: Oct 10 2013, 00:46
David the Chanse...
post Oct 10 2013, 00:56
QUOTE (eahm @ Oct 10 2013, 00:46) *
Which part did you want me to read in particular? I'm trying to convert a 32 bit float WAV file to WV, retaining the 32 bit float bit rate.
greynol
post Oct 10 2013, 01:01
If you don't mind my asking, what is the content that requires such precision?
Your eyes cannot hear.
David the Chanse...
post Oct 10 2013, 01:10
QUOTE (greynol @ Oct 10 2013, 01:01) *
They are tunes that I have made and exported as 32 bit float wave files. I want to keep them at this bit rate just for the peace of mind that it's the highest bit rate possible - to be honest - in case I decide I want to use them in the production of future music. I also want to be able to play them without having to make additional converted copies. I'm the type of person who is anal about high quality, even if it is inaudible (lol).
The way I see it is if I can keep it at that bit rate and play them back ok, then I don't mind the cost of extra storage space.
greynol
post Oct 10 2013, 01:16
So long as you know the stuff below ~19-20 bits will never be reproduced with any consistency upon playback, which shouldn't matter because it is, in all likelihood, only noise anyway.
David the Chanse...
post Oct 10 2013, 01:34
Noise is all part of the music. wink.gif I see that the playback quality will not be improved with 32f since my audio interface plays 24 bit audio anyway. I just want to keep them as high quality as possible (even if the difference is ridiculously minuscule) and be able to play them back.
I have discovered that foobar's bit rate setting is indeed 32 bit float, not 32 bit integer. Also, foobar offers the "additional processing" option for further compression whereas dBpoweramp does not (at least in the trial version). I'll use foobar for some time and I'll probably end up liking it over winamp, like many others do. Thanks for the help.
db1989
post Oct 10 2013, 07:49
QUOTE (David the Chansey @ Oct 10 2013, 01:34) *
Not when (A) it is so far down in volume as to be inaudible and (B) your interface almost certainly just made the noise up arbitrarily with no relation to the music and then dumped it on top.
Even if your interface could play 32-bit audio, it would make no difference in audible terms (unless its implementation of 24-bit audio was hopelessly broken).
I can understand a compulsion not to downsample the files if you can avoid it. Saying it will ever matter audibly is a different matter.
phofman
post Oct 10 2013, 08:42
Checking whether the wav file is float32 format:
soxi float32.wav
Input File     : 'float32.wav'
Channels       : 2
Sample Rate    : 44100
Precision      : 24-bit
Duration       : 00:01:34.93 = 4186560 samples = 7120 CDDA sectors
File Size      : 33.5M
Bit Rate       : 2.82M
Sample Encoding: 32-bit Floating Point PCM
Econding to wavpack using http://www.wavpack.com/downloads.html
wavpack float32.wav
WAVPACK  Hybrid Lossless Audio Compressor  Linux Version 4.60.1
Copyright (c) 1998 - 2009 Conifer Software.  All Rights Reserved.
created float32.wv in 2.67 secs (lossless, 79.32%)
Checking resultant float32.wv format:
soxi float32.wv
Input File     : 'float32.wv'
Channels       : 2
Sample Rate    : 44100
Precision      : 24-bit
File Size      : 6.93M
Bit Rate       : 584k
Sample Encoding: 32-bit Floating Point WavPack
2Bdecided
post Oct 10 2013, 12:09
ReplayGain developer
QUOTE (David the Chansey @ Oct 10 2013, 01:10) *
Support for 32-bit float wav files, never mind losslessly compressed versions of them, is pretty patchy. Worse, when some software tries to play them, you just get full scale digital noise. Some software will play them, but downconvert them, and not necessarily in an optimal way (though audible problems shouldn't exist).
By all means keep them, and by all means losslessly compress them - but maybe make 96/24 and/or 44.1/16 copies for listening to.
Nick.C
post Oct 10 2013, 12:56
Post #15
lossyWAV Developer
QUOTE (2Bdecided @ Oct 10 2013, 12:09) *
.... or Float16 WAV versions to play in foobar2000 or RockBox.
I would expect that foobar2000 v1.3.0 will play 16-bit (Half Precision) or 24-bit float (truncated / rounded 32-bit float) encoded in WavPack using the --store-floats-as-ints parameter introduced in 4.70.0 beta.
lossyWAV -q X -a 4 --feedback 4| FLAC -8 ~= 320kbps
pdq
post Oct 10 2013, 13:37
Post #16
QUOTE (David the Chansey @ Oct 9 2013, 20:10) *
You are mistaken. Not that it matters, but 32 bit float has only 24 bits of mantissa, so it is inferior to 32 bit integer. The only advantage of 32 bit float is that it has a much higher dynamic range, but for audio data this is quite useless.
David the Chanse...
post Oct 10 2013, 17:36
Post #17
Sorry, I forgot to mention that I couldn't export the files in 32 bit integer, only 32 bit float. I'll convert them to 24bit, 96kHz FLAC for playback, as I have had no problems with FLAC playback so far.
One last question: is 24 bit audio actually going to my audio interface? I.e. does foobar, or any other music player, convert it to 16 bit?
Thanks for your help, and sorry for my stubbornness of wanting to keep 32 bit float.
saratoga
post Oct 10 2013, 19:16
Post #18
QUOTE (David the Chansey @ Oct 10 2013, 12:36) *
Depends on what hardware you have. Assuming its 24 bit capable, its probably using 24 bit. That said, almost everything these days will take 24 bit audio, although not all that many devices actually produce more than 16 effective bits.
2Bdecided
post Oct 11 2013, 10:00
Post #19
QUOTE (pdq @ Oct 10 2013, 13:37) *
You don't have to stay below "digital full scale" because it no longer is full scale. This is very useful when processing: no need to even think about headroom, just do whatever you like. Whether the result is far too loud or far too quiet, you always have 24-bits of precision relative to the peak, and you never get clipping.
With conventional audio processing, there are usually easy enough ways to keep the results within range anyway, but with experimental stuff the ability to go above digital full scale without issue can be very helpful.
You have to bring it back into range to listen to it. wink.gif But I'd argue that it's still audio.
Nystagmus
post Nov 9 2013, 20:34
Post #20
I am a musician and I use 32-bit float WAV's regularly. It's worth adding that in MultitrackStudio Pro Plus, at least in the old versions, freezing VSTi's could cause clipping UNLESS 32-bit float was used. Also, using CoolEdit2000 or similar, if the original file was a 32-bit float, the otherwise clipped audio could be normalised DOWN to 0 dBfs or just below.
It's for this reason that I've been using 32-bit float for many years. It's a good habit to avoid clipping during composing, but with some extravagant VST's and VSTi's chained together, it starts to get a bit more difficult. So I really do like having the peace of mind knowing that if I accidentally clip somthing I can just fix it with a simple normalise or appropriate gain command.
And like some other folks, I like knowing that my tunes are rendered to their fullest bit-resolution quality possible using 32-bit float. Naturally, wanting to find a lossless compression and playback utility set, I came across foobar2000 as one of the only players that could do 32-bit float back a few years ago. And then of course WAVpack was a no-brainer as pretty much the only way to losslessly compress a 32-bit float without esoteric hassles.
I would do 48 kHz 32-bit float audio files as my main format, since the higher sample rate of the DAW audio engine sometimes makes filters sound a bit better, but most of the time I can't hear the difference so I just stick with 44.1kHz. And the filesizes can get big!
By the way, OcenAudio is a pretty nice freeware audio editor. It can open and save 32-bit (IEEE) floats. It's a pretty good program for other formats, and it can write to FLAC or OGG or a few other formats.
Be a false negative of yourself!
saratoga
post Nov 9 2013, 20:47
Post #21
QUOTE (Nystagmus @ Nov 9 2013, 15:34) *
Technically 32 bit int is higher. 32 bit float is used for production because it won't clip like int. But if you're just storing music it doesn't really make sense.
kode54
post Nov 10 2013, 00:36
Post #22
Group: Admin
It still makes some sense if you haven't peak scaled your floating point WAV before converting to integer format. Or ReplayGain scan and apply, keeping the peak level at or below 1.0, in case whatever volume level it arrives at leaves peaks exceeding that.
RSS Lo-Fi Version Time is now: 25th December 2014 - 16:48
