IPB
Check FLAC compression method, for already encoded files
Azevedo
post Mar 22 2013, 01:59
Post #1
Group: Members
Hi
Is it possible to determine wich FLAC compression method was used in an already encoded file?
Go to the top of the page
+Quote Post
Kohlrabi
post Mar 22 2013, 09:13
Post #2
Group: Super Moderator
You mean which compression level? Can you be more specific?
+Quote Post
ktf
post Mar 22 2013, 09:53
Post #3
Group: Members
You can to a certain extend. You'll have to use the analyse switch present in the flac tools. The analyse file might tell you something, but that is not guaranteed. The compression level only tells the encoder what limits to use (for example, max LPC order of 12) but there's nothing in the decoded file that has to be a certain way because of the compression level.
With normal material (like most music), you can tell which compression level was used with the analyse option.
+Quote Post
Kohlrabi
post Mar 22 2013, 10:21
Post #4
QUOTE (ktf @ Mar 22 2013, 09:53) *
Maybe my imagination is not good enough, but for what purpose does one need information about the compression level? Since FLAC decodes very, very fast across all settings, I don't see any reason to determine the compression level.
+Quote Post
ktf
post Mar 22 2013, 11:23
Post #5
Group: Members
QUOTE (Kohlrabi @ Mar 22 2013, 10:21) *
I do not see a reason either, I just tried to answer the question rolleyes.gif
+Quote Post
skamp
post Mar 22 2013, 11:52
Post #6
Group: Developer
That question comes up a lot. Obviously, he wants to find out which FLACs weren't compressed with the maximum compression setting.
See my profile for measurements, tools and recommendations.
+Quote Post
Brand
post Mar 22 2013, 12:04
Post #7
Group: Members
Yep, I'm guessing that's it.
I also like to have all my FLACs compressed at setting 8 and if I get some that aren't, I'll re-compress them. (Even if it doesn't save much space, maybe it's OCD... wink.gif )
+Quote Post
Azevedo
post Mar 22 2013, 13:30
Post #8
Group: Members
Thanks for all the answers.
QUOTE (skamp @ Mar 22 2013, 07:52) *
Exactly. I have all this flac library 100's Gbytes which is compressed with different ratios (mostly at --best or -8).
I found this way to determine if the compression rate is too low and wasting disk space:
GENERICALLY, in a 2 channel flac, if the Bit Rate is above ~ 1100kbps then is very likely it had been encoded using a low compression method.
Of course it's not a rule. It depends on other factors, but generally I can find the 'fatty' flacs biggrin.gif
+Quote Post
pdq
post Mar 22 2013, 13:41
Post #9
Group: Members
That sounds as though you have a lot of FLAC files that were encoded by someone else. Let's hope that they are all legal copies. wink.gif
+Quote Post
andrew_berge
post Mar 22 2013, 14:21
Post #10
Group: Members
I created a special tag in all my FLAC files to store the compression level, all level 8 smile.gif
+Quote Post
Azevedo
post Mar 22 2013, 14:41
Post #11
Group: Members
QUOTE (andrew_berge @ Mar 22 2013, 10:21) *
That's clever!
I should have done this in the old days.
+Quote Post
Kohlrabi
post Mar 22 2013, 15:11
Post #12
IIRC both FLACCL and Flake can compress stronger than FLAC -8. Also, since FLAC encoding is blazing fast too, you can easily run a conversion script across your whole collection to encode everything again.
+Quote Post
skamp
post Mar 22 2013, 16:53
Post #13
Group: Developer
QUOTE (andrew_berge @ Mar 22 2013, 14:21) *
I'm adding 'ENCODING=' (optional) to caudec (for all codecs, not just FLAC).
This post has been edited by skamp: Mar 22 2013, 16:53
+Quote Post
IgorC
post Mar 22 2013, 18:15
Post #14
Group: Members
QUOTE (Kohlrabi @ Mar 22 2013, 11:11) *
Flake compresses a bit more than FLAC -8 but at cost of lower decoding speed and incompability in some cases. Official FLAC encoder has some settings which should give the same results as Flake.
+Quote Post
Porcus
post Mar 23 2013, 11:55
Post #15
Group: Members
All my FLAC files are compression level 8 too, so therefore I don't think I need that tag ;-)
+Quote Post
Takla
post Mar 23 2013, 20:52
Post #16
Group: Members
QUOTE (Kohlrabi @ Mar 22 2013, 14:11) *
flac at default -5 really is fast. flac -8 is a lot slower, and flake -12 is glacially slow.
I ran flac, flac -8, and flake -12 on the same album. Between each run I flushed my system's vm cache:
CODE
$ time flac *.wav
real    0m40.824s
user    0m33.406s
sys    0m2.414s
$ time flac -8 *.wav
real    1m51.575s
user    1m47.745s
sys    0m2.022s
$ time flake -12 *.wav
real    4m1.914s
user    3m56.816s
sys    0m2.090s
I also noticed that the difference in file size between flac -5 and flake -12 for the entire album amounts to about 1.2MB. The difference bween flac -8 and flake -12 is only 272 kilobytes in favour of flake. Sometimes flake -12 produces larger files than flac -8 (see tracks 4 and 5).
CODE
$ du -cs *.flac
33304    01 - Sounsoumba.flac
39812    02 - Sukunyali.flac
31452    03 - Kounadya.flac
40968    04 - Donso.flac
38784    05 - Wele Wele Wintou.flac
29448    06 - Senkele te Sira.flac
31008    07 - Djigui.flac
31912    08 - Seya.flac
47156    09 - Iyo Djeli.flac
37000    10 - Mogo Kele.flac
31900    11 - Koroko.flac
392744    total
$ du -cs flac8/*
33236    flac8/01 - Sounsoumba.flac
39700    flac8/02 - Sukunyali.flac
31372    flac8/03 - Kounadya.flac
40864    flac8/04 - Donso.flac
38732    flac8/05 - Wele Wele Wintou.flac
29368    flac8/06 - Senkele te Sira.flac
30892    flac8/07 - Djigui.flac
31840    flac8/08 - Seya.flac
47016    flac8/09 - Iyo Djeli.flac
36912    flac8/10 - Mogo Kele.flac
31816    flac8/11 - Koroko.flac
391748    total
$ du -cs flake12/*
33200    flake12/01 - Sounsoumba.flac
39620    flake12/02 - Sukunyali.flac
31356    flake12/03 - Kounadya.flac
40924    flake12/04 - Donso.flac
38776    flake12/05 - Wele Wele Wintou.flac
29280    flake12/06 - Senkele te Sira.flac
30896    flake12/07 - Djigui.flac
31808    flake12/08 - Seya.flac
46956    flake12/09 - Iyo Djeli.flac
36852    flake12/10 - Mogo Kele.flac
31808    flake12/11 - Koroko.flac
391476    total
On this album the reduction in file size of flake -12 over flac -5 is less than one third of a percent.
I did the same with another CD and did get a better result - slightly over half a percent reduction. It's hard to think of any situation where flake is preferable to flac (I want non-compliant files which might not play, which take longer to make and might be bigger than if I used flac? ) and running a conversion script on 100s of GB of flacs to convert them with flake is nutty as well as flakey.
btw can you imagine doing this and then finding your shiny new playback device/appliance chokes on flake encodes and you have to do it all again in reverse....
+Quote Post
saratoga
post Mar 23 2013, 23:36
Post #17
Group: Members
We tested flake in rockbox a while ago. Its basically the same speed to decode as FLAC:
flake - "15.21MHz" (13.94s), flac - "14.71MHz" (13.48s) (iPod Nano 2G)
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 27th January 2015 - 12:58
