Closed TopicStart new topic
Lossless Codecs, Choose your favourite
The best to you is???
LossLess Audio [ 5 ] ** [3.01%]
Monkey's Audio [ 52 ] ** [31.33%]
FLAC [ 90 ] ** [54.22%]
PAC [ 1 ] ** [0.60%]
OptimFrog [ 2 ] ** [1.20%]
WavPack [ 9 ] ** [5.42%]
RKAudio [ 0 ] ** [0.00%]
WMAudio [ 5 ] ** [3.01%]
Bonk [ 0 ] ** [0.00%]
Shorten [ 2 ] ** [1.20%]
Total Votes: 249
Sniffer
post Aug 8 2003, 11:58
I really want to Know your opinion, i decided to make this Poll because all i have seen regarding lossless is between Flac and APE, althought i have been searching around and LA gives the better compression, why don't you use it instead of FLAC or APE, I know Flac gives other features but..........
One question, with Foobar we can apply replaygain in all formats, don't we???
Thanks for your time.
gutzalpus
post Aug 8 2003, 12:01
LA has great compression ratios, but is WAY too slow at compressing/decompressing. I might switch over to it once CPUs hit about 10GHz.
bigjohnson
post Aug 8 2003, 12:11
Where can I take a look or get LA?
AMD T-Bird 1400
Abit KT7A Raid
2 WD 40g @ 7200rpm raid 0
1 Maxtor 30g @7200rpm
1.5gb pc133
GeForce FX-5200
Creative Audigy 2
Cendyne 24x10x40 cdrw
Toshiba DVD 16X
Thermalright AX7
Sniffer
post Aug 8 2003, 12:12
www.lossless-audio.com
For me the best and i have take some comparations test's.
Update:
La is supported by
XMMS (Linux)
Winamp (WIN32)
Foobar (WIN32)
You need net.framework (update windows) for LA to work.
Update 2:
This post has been edited by Sniffer: Aug 8 2003, 12:22
Mac
post Aug 8 2003, 13:21
I tested LA out, and it gave noticably bigger files than APE extra high. This was on non-standard samples of audio, not regular songs.. but seeing as that's one of the main things I encode, I wasn't impressed.
< w o g o n e . c o m / l o l >
mdmuir
post Aug 9 2003, 00:01
Group: Members (Donating)
My question is-why is shorten so popular on live band recording websites?
I know it encodes and decodes fast, but in my experience it is one of the worst when it comes to final file size. Is it just because they started with it and do not want to switch to something else?
you will make mp3's for compatibility reasons.
rjamorim
post Aug 9 2003, 00:16
Rarewares admin
QUOTE (mdmuir @ Aug 8 2003, 08:01 PM)
For the exact same reason MP3 is still popular despite better alternatives.
It's the most widely known and used format.
http://www.rarewares.org
ScorLibran
post Aug 9 2003, 04:28
Group: Banned
QUOTE (rjamorim @ Aug 8 2003, 07:16 PM)
But I prefer FLAC because...
-1- It's compatible with both of my primary listening platforms, my PC and my car's Music Keg (for which FLAC is the only currently supported compressed lossless format).
-2- It's open source. I'm not a software developer, but I do believe in the concept of open source.
-3- It has good encode/decode performance, which means it can be used on more marginal hardware without problems compared to other formats (which is the reason PhatNoise can support it in their PhatBox/Music Keg with an ARM 74MHz CPU and 32MB of RAM).
-4- It sounds cool to say "FLAC". Even cooler than "LA", and definitely cooler than "APE". wink.gif
LIF
post Aug 9 2003, 04:44
I use almost exclusively Monkey'sAudio, because:
1-Good compression and speed;
2-EAC, CDex,WinAmp, etc support it;
3-Its the most common format avaliable on the lossless newsgroups;
4-I never had problems wich "bad crc" on archived files.
Days ago, I just made some tests with FLAC, and despite its lower compression, its very usable.
Honor mention must go to WavPack also. Its the fastest one, but it generates files little bigger than Monkey's.
/edit/: Monkeys comes with its own frontend. but I only use the main executable (mac.exe) on Speek's Multifrontend, the Dll(macdll.dll) directly on EAC and in_ape.dll on WinAmp.
This post has been edited by LIF: Aug 9 2003, 04:58
"Jazz washes away the dust of everyday life" (Art Blakey)
smack
post Aug 12 2003, 10:15
LA - Lossless Audio because of the high compression ratio. B)
eltoder
post Aug 12 2003, 11:06
-Eugene
The greatest programming project of all took six days; on the seventh day the programmer rested. We've been trying to debug the !@#$%&* thing ever since. Moral: design before you implement.
_io_
post Aug 12 2003, 11:30
Hate to say this, but i used to use LA until I found that about 1 in 40 of my encoded songs would not decode losslessly, I don't know if this is solely a problem with the LA format or because I used apev2 tags with them, but it put me off using the format.
This post has been edited by _io_: Aug 12 2003, 11:31
bigjohnson
post Aug 12 2003, 11:59
QUOTE (Sniffer @ Aug 8 2003, 03:12 AM)
Update:
La is supported by
XMMS (Linux)
Winamp (WIN32)
Foobar (WIN32)
Update 2:
Thank you!
AMD T-Bird 1400
Abit KT7A Raid
1.5gb pc133
GeForce FX-5200
Creative Audigy 2
Toshiba DVD 16X
Thermalright AX7
ssamadhi97
post Aug 12 2003, 12:09
Group: Developer (Donating)
QUOTE (mdmuir @ Aug 9 2003, 01:01 AM)
Yes, that's basically it.
It's "The Standard". It has been embraced by the taping / trading communities when they started looking into online trading and distributing and Shorten (initially a voice codec, intended to compress mono speech material and equipped with lossy encoding capabilities) was the only decent, and now that everyone including the less computer savvy people is used to handling SHN files, people are reluctant to switch to alternatives.
FLAC is getting there, being endorsed in addition to Shorten at both etree.org and archive.org, but with many tapers who don't make hi-res recordings sticking to Shorten it doesn't stand much of a chance yet. People are unsure about how to handle the additional features FLAC brings as well, like the fingerprints / stored hashes of the raw pcm data, tagging support, etc.. that's why you won't see a real switch anytime soon.
Shorten's bad performance when it comes to compression ratio can be blamed on the simplistic predictors and lack of inter-channel decorrelation. Then again, those are the very same reasons why both the encoder and the decoder are so fast.
Edit:
I for one use Shorten all the time because I'm stuck in online trading communities as well - and now that it supports ape2 tagging in foobar one of my major beefs with it is gone as well. Disk space isn't really an issue for me.
For my own encoding business I use FLAC or APE, depending on my mood.
This post has been edited by ssamadhi97: Aug 12 2003, 12:12
A riddle is a short sword attached to the next 2000 years.
eltoder
post Aug 12 2003, 12:33
Post #15
QUOTE (_io_ @ Aug 12 2003, 05:30 PM)
Have you reported the bug?
-Eugene
_io_
post Aug 12 2003, 12:53
Post #16
I reported a different bug involving the foobar plugin where a particular song would always crash foobar, never heard anything back so I didn't bother with this one, besides I presumed it was due to me tagging with apev2 when this isn't in the spec.
danchr
post Aug 12 2003, 14:36
Post #17
FLAC - Because It Worksâ„¢
AstralStorm
post Aug 12 2003, 14:48
Post #18
FLAC - because it works in the background on Pentium 100.
ruxvilti'a
mcbevin
post Aug 12 2003, 15:15
Post #19
La developer
Just a few comments regarding La ....
The .NET Framework is only required for the frontend. The commandline program, Winamp plugin etc work without requiring .NET.
La is obviously slower than many of the other compressors. However, that doesn't neccessarily make it too slow for everyones needs. Around 15-20% CPU usage on my AMD-2400+ during playback is not an issue as far as I'm concerned, and even on my P-III 1000 its not an issue unless I'm wanting to do something CPU-intensive at the same time. Not sure I understand the need to wait for 10GHZ - would having only the remaining 4.6Ghz of a 5Ghz machine available during La playback be not enough for you perhaps?
This would be obviuosly a very serious bug if true and I would hope that anyone encountering such bugs would report them to me, along with a copy of the song involved! La has undergone extensive testing, and no such bug has been found in the current version, but that doesn't rule out such possibilities completely, so please do send me one of these problem songs so I can see what the problem is.
I remember one such bug that was reported in La 0.4 beta, and was then fixed a couple of weeks later in La 0.4 final. Is this the one you're referring to?
gutzalpus
post Aug 12 2003, 15:42
Post #20
Right now, since I'm primarily using a PIII-650, encoding time, decoding time, and playback CPU usage are definitely a concern. I currently have about 300 CDs encoded in FLAC format. I wouldn't want to take the time to switch all those over until I can do it relatively quickly. Currently the extra space used by FLAC is not much of an issue to me. I never said LA was too slow for everyone's needs. However, it is definitely too slow for my needs at this point.
den
post Aug 12 2003, 15:44
Post #21
Wavpack for me.
It's hybrid mode is very useful for me. I can retain lossless at home, and high quality lossy when I am "on the road". (I'm typing this from Manila, but tomorrow I am in Taipei so it must be Tuesday...)
Optifrog is also very good, but it is not the best for the CPU challenged. I am yet to own a PC that can crack 1G.
Den
My blog - http://www.iinet.net.au/~den
Polar
post Aug 16 2004, 10:22
Post #22
I really see no point in keeping this poll/thread open and active, if an update is available here. Apparantly, someone has recently cast the 165th vote, even though the mentioned update was well over a week under way, thus distorting these 1 year old results ermm.gif
So: admins, could you please close this poll (just like you did with the old lossy poll in favour of the new one) and perhaps even undo this latest vote?
The August 2004 version has resulted into this (with the 2003 poll results - as frozen to 164 votes - in (grey)):
This post has been edited by Polar: Aug 16 2004, 10:24
RSS Lo-Fi Version Time is now: 5th September 2015 - 02:24
