12 Pages V   1 2 3 > »
FooNight FooDay, Columns UI PSS Configuration
qwertz
post May 2 2009, 12:28
Night:
Day:
Download Old Version (Including FooDay)
Download Version 1.1
For installation instructions read the included READ ME.txt
v1.1
- added compact mode
- added 2nd playlist
- added optional Playlist Tabs (turned off by default)
- bug fixes
- dropped FooDay
This post has been edited by qwertz: May 8 2009, 15:03
bubi jackson
post May 2 2009, 12:33
http://www.last.fm/user/BubiJackson
lokioki
post May 2 2009, 12:48
Thanks qwertz :3
ludowam
post May 2 2009, 13:27
Many thanks ! Nice & usefull.
VILLA21
post May 2 2009, 13:32
i got the following error msg:
"The layout import was aborted because the following required panels are not installed,
library tree
Textbox
biography"
qwertz
post May 2 2009, 15:16
QUOTE (bubi jackson @ May 2 2009, 12:33) *
swmmng
post May 3 2009, 13:50
Could you provide some explanation for the six buttons to the right of the search box? I kind of know what the first three and the last one do, but it would be nice to be sure about all of them.
qwertz
post May 3 2009, 22:01
It's:
Quicksearch same Artist / Album / Title / Genre
Activate Now Playing
Scrollbar Show / Hide
Cablespider
post May 4 2009, 01:29
Just wanted to say thanks!
Hawk
post May 4 2009, 05:15
Can I get the artist image in the left panel instead of the album cover and how do I achieve that? Thanks for a very cool config. smile.gif
Jny
post May 4 2009, 06:38
good job
what about background pic? wallpaper/cover/artist (like Falstaff configs)
qwertz
post May 4 2009, 08:47
@Hawk
Right click on menu -> Script -> Per Track: Replace
'G:\MP3\_Artist_\'%artist%'.jpg'
with your artist path
Right click on cover -> Script -> Per Track: Replace
$get_ps_global(cover.path)
with
$get_ps_global(artist.path)
Or you could simply point Biography View to your custom images.
@Jny
I deliberatly passed on transparency. There is still code for background images in the script though. Search for //------------Background in the main PSS.
FavioD
post May 4 2009, 09:41
i think this will be the first custom config i'll actually stick with tongue.gif
thanks!
This post has been edited by FavioD: May 4 2009, 09:43
pee_wee
post May 4 2009, 19:01
I like it. Does everything I want it to do. Going to tweak some colors and its good to go. thanks. (might change the buttons on bottom also). smile.gif
Hawk
post May 4 2009, 22:32
Post #15
QUOTE (qwertz @ May 4 2009, 09:47) *
@Hawk
with
@Jny
kenboldt
post May 5 2009, 14:11
Post #16
First off, fantastic config. It is clean, simple, great. If I can make a request though, would it be possible to place a button next to the star rating buttons below the album cover on the left for setting mood on/off (sets Last.FM loved to yes or no). I know that Falstaff has it in some of his configs and I have used it a lot.
The relavent code from Falstaffs kameleon config is below:
// MOOD TAG SET/UNSET to feed automatically auto-playlist for my iPod or iPhone
$if($stricmp('FOO_LASTFM',$left(%path%,10)),
$imageabs2(12,12,0,0,0,0,61,1,$get(img)'/bt/mood0.png',nokeepaspect)
$ifgreater($if2(%MOOD%,0),0,
$button(61,1,0,0,12,12,$get(img)'/bt/mood1.png',$get(img)'/bt/mood0.png',TAG:SET:MOOD:0,TOOLTIP:"Unset")
$button(61,1,0,0,12,12,$get(img)'/bt/mood0.png',$get(img)'/bt/mood1.png',TAG:SET:MOOD:1,TOOLTIP:"Set")
// SKIP TAG SET/UNSET
$imageabs2(12,12,0,0,0,0,75,2,$get(img)'/bt/skip0.png',nokeepaspect)
$ifgreater($if2(%SKIP%,0),0,
$button(75,2,0,0,12,12,$get(img)'/bt/skip1.png',$get(img)'/bt/skip0.png',TAG:SET:SKIP:0,TOOLTIP:"Unset")
$button(75,2,0,0,12,12,$get(img)'/bt/skip0.png',$get(img)'/bt/skip1.png',TAG:SET:SKIP:1,TOOLTIP:"Set")
Thanks in advance for even considering this request.
Ken
This post has been edited by kenboldt: May 5 2009, 14:12
tgpo
post May 5 2009, 17:48
Post #17
Easily the best PSS config yet. Great job.
http://www.tgpo.org
qwertz
post May 5 2009, 20:05
Post #18
@kenboldt
Probably not, this weekend I finally replaced Trackinfo Mod with WSH Mod, and WSH Mod is a constant struggle for me (that I'm losing btw), so I won't add things I'm not using myself.
But you already posted the code for Trackinfo, and it really isn't a big deal to implement mood/skip yourself.
First copy mood0.png, mood1.png, skip0.png, skip1.png to foobar2000\images\foonightday\bt\
Then right click on the cover -> Script -> Per Track and replace
$movepanel_c(Rating,$div($sub($get_ps_global(l.panel.w),60),2),$add($get_ps_global(cover.size),$el_scale(30,$get_ps_global(cover.size)),20),60,12)
with
$movepanel_c(Rating,$div($sub($get_ps_global(l.panel.w),90),2),$add($get_ps_global(cover.size),$el_scale(30,$get_ps_global(cover.size)),20),90,14)
Lastly open Trackinfo and insert the following code at the end of the script:
$imageabs2(12,12,0,0,0,0,61,1,$get(z)'/bt/mood0.png',nokeepaspect)
$button(61,1,0,0,12,12,$get(z)'/bt/mood1.png',$get(z)'/bt/mood0.png',TAG:SET:MOOD:0,TOOLTIP:"Unset")
$button(61,1,0,0,12,12,$get(z)'/bt/mood0.png',$get(z)'/bt/mood1.png',TAG:SET:MOOD:1,TOOLTIP:"Set")
$imageabs2(12,12,0,0,0,0,75,2,$get(z)'/bt/skip0.png',nokeepaspect)
$button(75,2,0,0,12,12,$get(z)'/bt/skip1.png',$get(z)'/bt/skip0.png',TAG:SET:SKIP:0,TOOLTIP:"Unset")
$button(75,2,0,0,12,12,$get(z)'/bt/skip0.png',$get(z)'/bt/skip1.png',TAG:SET:SKIP:1,TOOLTIP:"Set")
(I only fixed the paths) By the by, the only thing the lastfm part of the code does, is to deactivate the buttons, while listening to it.
@tgpo
kenboldt
post May 5 2009, 21:47
Post #19
WOW, that worked perfectly. Thanks so much, that's awesome!
Hawk
post May 6 2009, 15:15
Post #20
After playing around with this config I am really satisfied by the result. It is light, fast, and exactly how I like it.
This post has been edited by Hawk: May 6 2009, 15:15
barty
post May 6 2009, 22:58
Post #21
Thanks for this theme. It's nice and light.
Noob questions:
1) I have lousy eyesight and I've managed to increase the font size for most things except the artist/album/genre filter panel. possible?
2) I'd like to increase the size of the play trackbar/seeker at the bottom too, like maybe double in height.
3) is there a way to add playlist horizontal tabs at the top or bottom (my preference) to switch playlist? I tried to do it and managed to replace my whole play list with the playlist switcher panel, which isn't what I want anyway.
thanks in advance for your help.
qwertz
post May 7 2009, 07:56
Post #22
1) Preferences -> Columns UI -> Colours and Fonts
2) Couple of things to change:
$puts(bottom.h,40) -> increase the toolbar height at the bottom
$puts(play.button.top,$sub(%_height%,36)) -> adjust top position of playback buttons
$puts(play.button2.top,$sub(%_height%,33)) -> adjust top position of play list switcher
$imagebutton($sub(%_width%,32),$sub(%_height%,40),22,35,$get_ps_global(image.path)'/icons/logo_off1.png',$get_ps_global(image.path)'/icons/logo_on1.png',WINDOWSIZE:$if2(%foonight_default_width%,820):$if2(%foonight_default_height%,620);REFRESH,,) -> change $sub(%_height%,40) and adjust top position of resize button
finally:
$movepanel_c(Seekbar,10,$sub(%_height%,8),$sub(%_width%,150),5)
$movepanel_c(Volume,$sub(%_width%,130),$sub(%_height%,8),120,5)
where $sub(%_height%,8) is the top position and 5 is the height of the bars
tgpo
post May 7 2009, 14:11
Post #23
I'm not a fan on having a config always taking up a lot of space, so one customization on my list to do is to add a collapse/expand button that shrinks the window to look like this:
http://www.tgpo.org
pee_wee
post May 7 2009, 15:49
Post #24
great idea, and a great band tgpo
Hatredcopter
post May 7 2009, 16:29
Post #25
QUOTE (qwertz @ May 2 2009, 19:28) *
You can set the following variables in foo exvar:
                            Default:
fooday_bg_color             246-246-248-255
foonight_bg_color           015-015-016-255
fooday_left_panel_width     300
foonight_left_panel_width   300
foonight_default_width      820
foonight_default_height     620
fooday_default_width        820
fooday_default_height       620
Thanks in advance
RSS Lo-Fi Version Time is now: 23rd September 2014 - 00:17
