IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
2 Pages V   1 2 >
Closed TopicStart new topic
foobar2000 1.3.8 beta discussion
askold
post Mar 3 2015, 18:16
Post #1
Group: Members
compiled with Microsoft Visual Studio 2013
Go to the top of the page
+Quote Post
marc2003
post Mar 3 2015, 18:42
Post #2
Group: Members
it's only the default. you can bypass it. (when i say you, of course i mean Peter tongue.gif)
https://msdn.microsoft.com/en-gb/library/7t5yh4fd.aspx
This post has been edited by marc2003: Mar 3 2015, 18:43
+Quote Post
lvqcl
post Mar 3 2015, 19:38
Post #3
Group: Developer
QUOTE
Now compiled with Microsoft Visual Studio 2013.
Does it mean that min. OS requirement is XP SP3 now? If yes then IMHO it's a good idea to upgrade fb2k "System requirements".
+Quote Post
eahm
post Mar 3 2015, 22:14
Post #4
Group: Members
Loading the streams/radios is super fast now, almost instantaneous.
+Quote Post
ChronoSphere
post Mar 3 2015, 22:34
Post #5
Group: Members
New ReplayGain playback mode picking album/track gain depending on current playback order.
Great! I guess this makes foo_rg_trn obsolete?
It seems the replay gain mode changes for the next track, not immediately after changing playback mode. I found it to be a bit counter-intuitive, as I expected to hear a difference right after switching (minus the buffer delay)
+Quote Post
Peter
post Mar 4 2015, 11:22
Post #6
foobar2000 developer
Group: Admin
Re non SSE2-
Looks like VS2013 defaults - even when importing from older VS - enable SSE without asking.
Fixed for the next update.
Attached thumbnail(s)
+Quote Post
Case
post Mar 4 2015, 15:26
Post #7
Group: Developer (Donating)
QUOTE (lvqcl @ Mar 3 2015, 20:38) *
QUOTE
Perhaps. I tried to verify if things still work in Windows XP SP2 using VirtualBox and VMWare Workstation. It starts occasionally without trouble but other times the virtual machines die. VirtualBox just closes without error and VMWare turns into a tiny black window.
+Quote Post
marc2003
post Mar 4 2015, 15:47
Post #8
Group: Members
just drop support for XP. that would avoid any service pack confusion. tongue.gif
but seriously, people stuck on XP must know they should be running SP3. there is no reason not to.
+Quote Post
lvqcl
post Mar 4 2015, 16:07
Post #9
Group: Developer
I noticed that 1.3.8 b1 decodes FLAC and ALAC slightly slower than 1.3.7 (the difference in decoding speed is several percent). Maybe it's the result of Whole Program Optimization turned off.
+Quote Post
Euclid
post Mar 4 2015, 17:22
Post #10
Group: Members
I would like to vote against disabling the SSE2 optimizations.
Users with CPUs that do not support the SSE2 instructions (old Athlons) can always use an older version of foobar2000. The same applies to users that refuse to install SP3 on Windows XP.
On the other side everybody else (>99%) will benefit from the SSE2 optimizations.
So please enable the SSE2 optimizations again. Thank you
+Quote Post
askold
post Mar 4 2015, 20:21
Post #11
Group: Members
QUOTE (Peter @ Mar 4 2015, 12:22) *
Thanks from me and my Athlons. By the way retrying dropped connections over HTTP is really long-expected feature.
to Euclid
+Quote Post
VanderWiel
post Mar 4 2015, 21:49
Post #12
Group: Members
About the new replay gain mode option.
Great for de different playback modes, but how about custom playlists you're playing in default mode?
If it's just albums you'd want to use the album value, but if you have a list with (seemingly) random tracks then the track value would be appropriate.
An idea, it might already be like this, but ...
While in default mode, to use the album value IF the previous OR next track IS from the same album.
Anyway, a nice addition to profit from fb2k's replay gain functionality.
Using the album value by default would most of the time be okay.
btw, love the added retry for streams, it was a bit awkward to have it constantly switch stations when on a bad connection.
+Quote Post
ChronoSphere
post Mar 4 2015, 23:00
Post #13
Group: Members
QUOTE (Euclid @ Mar 4 2015, 17:22) *
+1 to that. Maybe make a legacy version that doesn't have them enabled, but there should be a limit to legacy support, really.
Old athlons are hardly usable nowadays (yes, I have some, and yes, I tried) and there is really no reason to stick with XP except on principle.
+Quote Post
TheRyuu
post Mar 5 2015, 01:53
Post #14
Group: Members
QUOTE (Peter @ Mar 4 2015, 05:22) *
Re non SSE2-
My guess is that because in the upgrade process the option isn't actually changing ("Not Set" -> "Not Set") only now it means /arch:SSE2 instead of (the now added) /arch:IA32. They probably want people to use it so that's why they have that behavior, I doubt it really matters for performance since the majority of the time you're just going to be playing back at 1x speed anyway.
Also please take a look at this[1]. I forgot to mention it in that post but the version of ffmpeg being shipped is old[2], the 2.4 branch is up to 2.4.7 now.
[1] http://www.hydrogenaud.io/forums/index.php?showtopic=108524
[2] https://www.ffmpeg.org/download.html#release_2.4
This post has been edited by TheRyuu: Mar 5 2015, 02:05
+Quote Post
Peter
post Mar 5 2015, 08:41
Post #15
Group: Admin
QUOTE (lvqcl @ Mar 4 2015, 16:07) *
This is most interesting:
1.3.7 stable:
ALAC: 324.123x realtime
FLAC: 828.854x realtime
1.3.8 beta [SSE]
ALAC: 308.505x realtime
FLAC: 758.120x realtime
1.3.8 alpha [no SSE]
ALAC: 307.728x realtime
FLAC: 758.339x realtime
Whole program optimizations are enabled.
The offending optimizer feature (devirtualizing function calls):
* Was not available in VS2010 in first place
* Is not relevant to lowlevel decoding code (pure C), affects C++ only as far as I know
* The compiler switch that suppresses it - /d2notypeopt - isn't actually enabled for libFLAC code yet libFLAC turned up suspiciously slow also.
So, for some reason VS2010 build was faster. If we find no further advantages to using VS2013 compiler, we'll fall back.
Note that this doesn't affect formats that we handle through FFmpeg which is compiled externally with GCC.
I don't think you really understand what happened here.
foobar2000 has carried various SSE optimizations (also for newer SSE revisions) for a long time, enabled conditionally at run-time after checking for relevant CPU feature bits. Decoder libraries that we use - especially FFmpeg and libFLAC - already contain heavy optimizations for recent instruction sets. ReplayGain at >1000x realtime is only possible thanks to SSE2 code.
What happened is that while upgrading toolchain, whole foobar2000 was accidentally compiled with SSE instructions generated in place of legacy x87 opcodes for all floating point math, as the same compiler options turned out to have different meanings in different VS versions. But as you can see from the numbers I quoted above, this made no difference at all on decoding speeds (at least with these two formats). Once there are actual benefits to compiling everything with SSE enabled, we'll reconsider, but for now there are none.
Once the above speed issue is sorted out I can provide builds with different SSE modes enabled, then you can find out by yourself if anything actually gets faster from it.
You can also rebuild FFmpeg by yourself using the exact version I used but different configure line to get different SSE modes in it. The version I include with fb2k performs runtime CPU detection to enable the optimal mode.
+Quote Post
TheRyuu
post Mar 5 2015, 21:11
Post #16
Group: Members
QUOTE (Peter @ Mar 5 2015, 02:41) *
There are other advantages to using VS2013 such as improved buffer security checks and better global data optimizations[1] (this must be manually added to the command line but it shouldn't break anything AFAIK). It is interesting that there is such an obvious performance regression. I may try and profile it out of curiosity to see if there's an obvious spot which regresses but it is strange that two different libraries both have the similar performance regression.
Also lets not forgot we're still talking about something which is hundreds of times faster than realtime here so the perceived difference may be smaller than what the numbers may suggest.
[1] https://msdn.microsoft.com/en-us/library/dn305952.aspx
This post has been edited by TheRyuu: Mar 5 2015, 21:26
+Quote Post
Peter
post Mar 5 2015, 21:42
Post #17
Group: Admin
Update, ALAC can be made decode at speeds nearly equal to VS2010 output by tinkering with lowlevel options (intrinsics, inlining and so on).
However FLAC is a tough one, I cannot repro the slowdown testing stock FLAC.exe compiled with VS2010 vs VS2013, so there might be some other factors than just libFLAC code.
+Quote Post
mville
post Mar 6 2015, 18:39
Post #18
Group: Members
foobar2000 change log - version 1.3.8, states:
Can someone elaborate on the above statement, or point me to documentation on exactly what is happening here? TIA
+Quote Post
Daeron
post Mar 6 2015, 18:55
Post #19
Group: Members
^ Download and install the current version in portable mode to see for yourself. You can simply delete the installation folder after.
This post has been edited by Daeron: Mar 6 2015, 19:00
+Quote Post
ChronoSphere
post Mar 6 2015, 19:47
Post #20
Group: Members
QUOTE (mville @ Mar 6 2015, 18:39) *
default+repeat mode -> auto set to album gain, any form of random -> auto set to track gain.
+Quote Post
Zarggg
post Mar 6 2015, 23:32
Post #21
Group: Members
Thanks for confirming this. I wasn't able to look into that myself yet and it's a feature I've been missing.
Would it be possible to have it set the "Shuffle (albums)" mode to album gain, if it does not so already?
This post has been edited by Zarggg: Mar 7 2015, 00:22
+Quote Post
ChronoSphere
post Mar 7 2015, 00:20
Post #22
Group: Members
I think it already does (would make sense), but I haven't tested it.
Speaking of "shuffle (albums)", the issue I reported still persists with 1.3.8.
+Quote Post
audiophool
post Mar 7 2015, 07:54
Post #23
Group: Members
QUOTE (ChronoSphere @ Mar 6 2015, 19:47) *
It would be cool if it worked like the "intelligent" ReplayGain in Logitech Media Server. It will switch to track gain if adjacent tracks in the current play queue have different album gains and to album gain if they have the same album gain.
+Quote Post
GeSomeone
post Mar 8 2015, 22:40
Post #24
Group: Members
QUOTE (Peter @ Mar 5 2015, 08:41) *
If I understand what you're saying, the reason could be that the option is NOT set, so the (new offending) feature is NOT suppressed. Sorry if didn't.
+Quote Post
Peter
post Mar 9 2015, 11:06
Post #25
Group: Admin
QUOTE (GeSomeone @ Mar 8 2015, 22:40) *
You got it right.
However the VS2013 bug affecting foobar2000 is making our code crash or produce invalid results, not just slow down - relevant optimizer feature is meant to improve C++ code size & speed and does a good job at it when not confused by multi-DLL environment.
On top of that it affects C++ code only while libFLAC is pure C, hence the switch is meaningless for libFLAC - as far as I know.
+Quote Post
2 Pages V   1 2 >
0 Members:
RSS Lo-Fi Version Time is now: 30th March 2015 - 17:36
