Id3 Tags as windows command line tool?, Need taglib or id3lib as windows command line
yenerich
post Oct 18 2011, 18:08
Hello
Im looking for something like tag.exe, but i found that tag.exe has some bugs or limitations.
What i want to do is to copy the tags from one file (lets say an mp3) to a file in another format (acc, ogg, etc).
Also want to be able to read and write the tags.
As i have a large collection, i want to find a command line tool.
Please, if possible, point me to the right direction.
vampirnata
post Nov 8 2011, 16:06
I am not sure why you would want a command line tool as the GUI ones will do this much easier/faster.
Try MP3Tag or TagScanner (using this one now and it's growing on me)
db1989
post Nov 9 2011, 11:19
If an automated GUI solution is a possibility, consider this the inevitable mention of foobar2000; it can copy metadata fields between two sets of files, provided they are arranged in equivalent order in two playlists.
viktor
post Nov 9 2011, 11:56
foobar2000.
This post has been edited by viktor: Nov 9 2011, 11:57
yenerich
post Nov 9 2011, 13:17
Thnaks for all your replies.
I am looking for a windows command line solution, if there is any.
Why? Because i am a developer too and im planning to use it in a manager i am building for my own use.
db1989
post Nov 9 2011, 20:14
Good to know. Unfortunately I canít be of much help in that case. This question (both the general idea and the desire for something better than tag.exe) comes up quite frequently, but I donít recall there being any program that decisively answers it. Hopefully thatís just my memory failing me! wink.gif
Kohlrabi
post Nov 9 2011, 20:37
I don't know in what language you are planning to write your manager, but a google search will probably give you some results on tagging libraries for popular languages. For example you could use mutagen (Python 2.3+) to read and write tags using Python. I didn't test it so far, but the library looks clean and easy to use, and you could set up your own Python command line tool in short time (if you know some Python).
EDIT: Typos.
This post has been edited by Kohlrabi: Nov 9 2011, 20:39
viktor
post Nov 9 2011, 20:58
QUOTE (yenerich @ Nov 9 2011, 13:17) *
so what's your problem with id3lib?
Kohlrabi
post Nov 9 2011, 21:18
QUOTE (viktor @ Nov 9 2011, 20:58) *
QUOTE (yenerich @ Oct 18 2011, 18:08) *
viktor
post Nov 9 2011, 21:19
QUOTE (Kohlrabi @ Nov 9 2011, 21:18) *
yes, so obviously add all the other required format's libs?
This post has been edited by viktor: Nov 9 2011, 21:19
alondon
post Nov 10 2011, 18:20
Have you looked at this?
http://developer.kde.org/~wheeler/taglib.html
Juha
post Nov 12 2011, 17:38
Long ago I did make a VBScript for this type usage (I had also feature which constructed music library based on tag information (create folders by artist/album etc.).
I couldn't find those scripts I made anymore but, still located the sources I got ideas from to start.
http://www.motobit.com/tips/detpg_change-id3-tags-script/
http://www.motobit.com/tips/detpg_list-id3-tags-script/
Juha
This post has been edited by Juha: Nov 12 2011, 17:39
RSS Lo-Fi Version Time is now: 1st August 2015 - 01:40
