Connecting computer to CRT television
JFS
post Aug 10 2010, 18:24
I want to connect my computer: Dell OptiPlex GX260. I have a video card with a VGA connection. My TV is a Sony, Model KV-20TS30. It has an SVideo as well as an RCA connector. How would I connect this, and what kind of picture could I expect? I want to use this for watching video.
I only have one VGA connection on the video card for my TV. Can I get a switch to choose the output for the computer monitor and the TV?
Appreciate any help. Thanks
DVDdoug
post Aug 10 2010, 19:30
That's a desktop computer, right? Your best option would be to get a video card that has a composite and/or S-Video output. that should allow you to choose either or both video outputs in software.
Or, you can get a VGA-to-Composite Video Adapter. I don't know what kind of quality you can expect. (I bought one of these for my laptop, but I haven't tried it yet.... And my antique analog TV has rather poor video quality anyway...)
And, you'll need a 'KVM' switch or A/B Switch, or a 'Y'-Adapter to run both at the same time.
Arnold B. Kruege...
post Aug 13 2010, 13:41
QUOTE (DVDdoug @ Aug 10 2010, 14:30) *
I've worked with inexpensive VGA to composite adaptors, and found that they do a really good job given that the basic quality of composite is pretty horrible compared to VGA. I've also found that expensive pro-quality hardware of this nature is really not that much better.
The problem is that as we both know, composite video is limited to really low bandwidth, and visually that means a lot of fuzz gets added.
Most of the VGA-to-composite adaptors I've used incorporate a splitter function so that you can run both displays at the same time without any extras. IOW, they have a VGA output that parallels the VGA input and doesn't unduely load down the source (PC).
JFS
post Aug 13 2010, 18:08
QUOTE (Arnold B. Krueger @ Aug 13 2010, 06:41) *
Thanks for the replies.
Would an adaptor that connected from the vga to the SVideo on the TV be better quality.
I found this on the Internet, does anyone have experiece with this ( from Squidoo); it connects to SVdeo or composite? Other suggestions?
Squidoo
DVDdoug
post Aug 13 2010, 21:27
I dont' know. Whenever I have a choice I'll choose S-Video because it's supposed to be "better". But, I've never done any A/B experiments and I've never noticed any difference... I've never said, "Boy, that looks sharp it must be S-Video". I think the basic specs are the same... S-Video doesn't have higher resolution.
Like Arnold said, you're not going to get computer-monitor quality in either case.
That $29 one looks identical to the one I got from Monoprice. Like I said, I haven't tried it yet. Maybe I'll hook it up this weekend.
Arnold was right about another thing... It has a VGA splitter/passthrough built-in so you DON'T need an A/B or KVM switch to use it along with your regular monitor. (This is not an issue with my laptop.)
DVDdoug
post Aug 15 2010, 19:52
OK, I tried the VGA to composite adapter. On my (old) TV, I don't see any difference between a DVD played on my DVD player and the DVD played on the computer.
The picture does look very "fuzzy" with normal-sized computer text, but the larger DVD-munu text is "readable".
Arnold B. Kruege...
post Aug 15 2010, 23:20
QUOTE (JFS @ Aug 13 2010, 13:08) *
Yes.
S-Video provides some advantage over regular coax analog video/
Component video does even more for you.
Squidoo
No, but Unless they've figured out how to circumvent the laws of physics...
I give them points for being honest about their projected results.
luecjennifer
post Dec 14 2010, 10:55
Its fairly easy, any vga switch will work for you.
Jennifer
RSS Lo-Fi Version Time is now: 30th September 2014 - 22:07
