IPB
aacgain in dBs
Azevedo
post May 3 2014, 00:35
Post #1
Group: Members
Hi!
I'm using ffmpeg to encode an audio source to MP4 AAC using the switch -af volumedetect.
(actually I convert it to PCM wav and pipe the output to NERO AAC, but it is not the point)
Works neat and yet gives me the volume analysis bellow so I can save time and CPU not having to run aacgain to analyse the AAC stream to find the volume.
(Considering the source audio will be from a movie-kind length, so 2 hours+, which takes sooooooo long for aacgain to analyses and apply gain to it.)
[Parsed_volumedetect_0 @ 0000000000388040] n_samples: 5763072
[Parsed_volumedetect_0 @ 0000000000388040] mean_volume: -30.7 dB
[Parsed_volumedetect_0 @ 0000000000388040] max_volume: -6.2 dB
[Parsed_volumedetect_0 @ 0000000000388040] histogram_6db: 9
[Parsed_volumedetect_0 @ 0000000000388040] histogram_7db: 39
[Parsed_volumedetect_0 @ 0000000000388040] histogram_8db: 146
[Parsed_volumedetect_0 @ 0000000000388040] histogram_9db: 370
[Parsed_volumedetect_0 @ 0000000000388040] histogram_10db: 987
[Parsed_volumedetect_0 @ 0000000000388040] histogram_11db: 1907
[Parsed_volumedetect_0 @ 0000000000388040] histogram_12db: 3315
By doing some test I found that I have to apply this amount of gain to the encoded AAC file: 6.2 dB in order to get 89dB volume.
The problem comes up when I try to use aacgain.exe to apply those 6.2 dB to the AAC stream so it will be @ 89dB.
aacgain.exe /e encoded.mp4
Recommended "Track" dB change: 6.320000
Recommended "Track" mp4 gain change: 11
Max PCM sample at current gain: 3429.587245
From aacgain -h:
/g <i> - apply gain i without doing any analysis
And finally: aacgain.exe /g 6.2
It does apply the gain but instead of 89dB it goes to 101dB!
Am I doing something wrong or this aacgain tool won't do the gain in dBs as expected?
This post has been edited by Azevedo: May 3 2014, 00:38
Go to the top of the page
+Quote Post
[JAZ]
post May 3 2014, 00:41
Post #2
Group: Members
Even though I don't think you are obtaining what you think you obtain (i.e. max volume is not directly related to loudness), you are making a trivial mistake.
What is in here: "-6.2" that isn't in here: "6.2".
Or what's the difference between 101 and 89? 12. What's 6+6? 12.
+Quote Post
Azevedo
post May 3 2014, 00:56
Post #3
Group: Members
QUOTE
Well its obvious I want a gain of 6.2dB and I'm not getting it by
aacgain.exe /g 6.2 encoded.mp4
QUOTE
Coincidence my friend.
There is no correlation between those numbers ( I tested in others situations )
but thanks for answering
This post has been edited by Azevedo: May 3 2014, 01:27
+Quote Post
larswes
post May 3 2014, 07:13
Post #4
Group: Members
-6.2 dB is not a replaygain value, so it's useless if you want to aacgain to 89 dB.
-6.2 dB only tells you how far from clipping you are:
https://www.ffmpeg.org/ffmpeg-filters.html#volumedetect
This post has been edited by larswes: May 3 2014, 07:18
+Quote Post
[JAZ]
post May 3 2014, 12:34
Post #5
Group: Members
QUOTE (Azevedo @ May 3 2014, 01:56) *
QUOTE
Well... It is obvious to me that you do NOT want a gain of 6.2 dB.
QUOTE
A gain increases the volume.
Said that, I would like to know where did you get the 101dB value from. Scanning the modified file with aacgain? If so, what does it report previous to add the gain?
I know there is no correlation with the max_volume: -6.2 dB and the it goes to 101dB!. The question is what are you doing? (Other than using the wrong value)
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 25th April 2015 - 08:13
