2 Pages V   1 2 >
Converting to WMA
OrcaMarinha
post Dec 18 2010, 00:44
Is there a way to convert FLAC to WMA using foobar just like its possible to converto to mp3 ?
kode54
post Dec 18 2010, 02:23
Group: Admin
This topic has instructions for setting up the converter to produce WMA 9 files.
Merlin_de
post Jan 5 2011, 15:39
QUOTE (OrcaMarinha @ Dec 18 2010, 00:44) *
hello,
since win7 MS decide to change from old WM9Encoder (COM based ) to the new Windows Media Encoder IWMEnc Interface.
WME is afaik part of the Windows Media Player. therfor win7 user dont need to install WM9Encoder (dont work anny more).
based on the BASS audio library http://www.un4seen.com/ i made a small console app that convert
*.mp3;*.mp2;*.mp1;*.ogg;*.wav;*.aiff;*wma -> wma.
the command line is the same as used by the known WMCmd.vbs / WME9.vbs
eg.
Encoder: WMAenc.exe
Ext: wma
Parameter: -a_codec WMASTD -a_setting Q50_44_2 -input "-" -output %d
-input "-" = input from STD
-input "%s" = foobar temp file
-input "D:\myFile.mp3" = file
-output %d = output file name (foobar variable)
-output"D:\myFile.mp3" = output file name
-a_setting Q50_44_2 = VBR 50% 44000 kbits 2 channel (use other supportet wma codecs if you want)
-a_setting Q100_44_2 = lossless
you use
.\ WMAenc.exe
.\Bass\bass.dll
.\Bass\basswma.dll
WMAenc.exe work on all win >= win2k
on win2k - xp WM9Encoder.exe codecs from MS must be install onyour system (like for WMCmd.vbs / WME9.vbs)
on win7 only the win7 Windows Media Player must be install.
i am noob in dev plugins for foobar, so i need help from a dev to create a foobar plugin enviroment for the Converter Setup page (like the Flac GUI page). if some dev can help me, i can make a nice GUI Plugin for foobar.
maybe some dev contact me.
DOWNLOAD:
WMAEncoder.zip
This post has been edited by Merlin_de: Jan 5 2011, 16:15
tgckpg
post Jan 10 2011, 21:29
Good! Thanks! I'm using windows 7 and confused with wma!
Great! Works fine!
mudlord
post Jan 11 2011, 05:36
Group: Developer (Donating)
GUI component?
What do you need? Does it need to be a context menu item? To me, it would make much more sense taking selected entries, decoding to PCM, and then piping them to the WMA encoder. Only issue I can see there then is you need to make BASS/BASSWMA somehow multiinstance usable. But then you support *any* format that FB2K supports...Plus, it should remove the dependancy on bass.dll itself, as it seems BASSWMA's encoder can be called without a BASS instance.
edit: Noticed a issue with your encoder. Seems to crash whenever no parameters are given to it. I assume the encoder was coded in Delphi or Visual Basic? (judging from the error message)
This post has been edited by mudlord: Jan 11 2011, 17:57
saivert
post Jan 11 2011, 19:47
It is because he didn't check for parameters in his program. The only error is that you didn't provide the required paramters -input -output and -a_setting.
QUOTE (merlin_de)
FLAC has a special setup dialog because foobar2000 directly supports it. You still need to provide flac.exe as it doesn't come with the encoder. It only has a built-in setup dialog. Same with wavpack, ogg vorbis, mp3, wav, et.al.
All other formats need to be setup with the custom option, including wmaenc.
This post has been edited by saivert: Jan 11 2011, 20:01
http://foobar2000.saivert.com - foobar2000 component repository
eevan
post Jan 12 2011, 17:59
I tried this tool on x32 Win 7 Ultimate and got the WMAPRO encoded files without any problems. But when I tried to play them in Rockboxed Fuze v2, I noticed some issues, so I run them through foobar2000's Verify Integrity tool. This is the result:
Item: "G:\MUSIK\Alice In Chains\The Essential\10 - Them Bones.wma"
Warning: Reported length is inaccurate : 2:30.045000 vs 2:30.000000 decoded
Item: "G:\MUSIK\Alice In Chains\The Essential\11 - Angry Chair.wma"
Warning: Reported length is inaccurate : 4:48.413000 vs 4:48.367347 decoded
Item: "G:\MUSIK\Alice In Chains\The Essential\12 - Would_.wma"
Warning: Reported length is inaccurate : 3:28.163000 vs 3:28.117914 decoded
Item: "G:\MUSIK\Alice In Chains\The Essential\13 - Dirt.wma"
Warning: Reported length is inaccurate : 5:16.746000 vs 5:16.700680 decoded
Item: "G:\MUSIK\Alice In Chains\The Essential\16 - Rooster.wma"
Warning: Reported length is inaccurate : 6:16.236000 vs 6:16.190476 decoded
All items decoded successfully.
5 items decoded with minor problems.
List of decodable but suspicious items:
Files play normally in foobar or WMP, but I'd like to know if anybody else get these inaccurate length warnings. Maybe that's a source of playback problem on Rockbox...
Files were converted from TAK lossless sources using foobar2000's converter and WMAenc.exe tool. Parameters used:
-a_codec WMAPRO -a_mode 2 -a_setting Q90_44_2_24 -input %s -output %d
Cheers!
If age or weaknes doe prohibyte bloudletting you must use boxing
lvqcl
post Jan 12 2011, 18:37
That's normal for WMA in foobar2000.
kode54
post Jan 12 2011, 23:25
Group: Admin
This is a limitation of the stream format used by WMA files, namely ASF. It appears to store packet play position timestamps and durations in milliseconds. Thus, Microsoft's own WMA handling code is limited to returning track lengths in milliseconds.
eevan
post Jan 13 2011, 00:38
Thanks for clarification!
Zin-Uru
post Jan 20 2011, 14:56
Very good! Thank you!
Zin-Uru
post Jan 21 2011, 08:10
It seems like your encoder does not support 2-pass encoding. Or some special parameters needed?
dazzle
post Jan 21 2011, 12:09
I have just tried the WMAenc.exe in EAC and it's working flawless. What I miss is an opportunity to tag my .wma files when I rip them. With the old WMencoder from EAC it was possible. Does anyone know if there are any parameters that could be added which would then write the tags. EAC has already the tags from freedb.
I have tried this: -output %d -author "%a" -title "%t"
But it does not work - no tags :-(
Can anyone help?
Regards
Dazzle
Merlin_de
post Jan 22 2011, 00:58
QUOTE (Zin-Uru @ Jan 21 2011, 08:10) *
no it dont support 2-pass encoding coz basswma.dll dont support it.
QUOTE (dazzle @ Jan 21 2011, 12:09) *
tagging is not support, maybe in next release if more people want tagging
Steve Forte Rio
post Jan 22 2011, 14:29
Post #15
Why does encoder can't work without bass libraries even if they aren't needed (foobar2000 encoding)?
Can you fix this?
This post has been edited by Steve Forte Rio: Jan 22 2011, 14:30
Merlin_de
post Jan 22 2011, 15:43
Post #16
QUOTE (Steve Forte Rio @ Jan 22 2011, 14:29) *
Can you fix this?
WMAenc is only a wrapper for bass libs. the encoding is done inside basswma.dll.
i don't intend to code the whole wma encoding for the diffrent windows version native by c++ at this time.
what is the problem with the 2 dll ?
Steve Forte Rio
post Jan 22 2011, 18:08
Post #17
It is always more convenient to use only one executable file for encoding...
And this library in it's turn uses some Windows libs? Am I right?
This post has been edited by Steve Forte Rio: Jan 22 2011, 18:08
mudlord
post Jan 22 2011, 22:30
Post #18
Most likely is a wrapper to the encoder/decoder DMO...
Yes, it would make sense using the encoder DMOs natively...no matter how obtuse and stupid the APIs are.
Ljubo44
post Jan 22 2011, 23:51
Post #19
is there any way to convert WAV 24-bit/96kHz 2CH to WMA 24/96 - 768kbps 2CH
So far I have seen only 5,1 CH but how to be in only 2 channels stereo on that bitrate?
Merlin_de
post Jan 23 2011, 00:36
Post #20
QUOTE (Ljubo44 @ Jan 22 2011, 23:51) *
he microsoft wma encoding always depend on the source audio format
if you dont resample (change input audio format) afaik you only can use wmaprofessional
Parameter: -a_codec WMAPRO -a_setting xxx_96_2_24 -input "-" -output "%d"
xxx can be afaik
Q100, Q98, Q90 or Q75 (VBR mode - Q100= lossless )
or
440, 384, 256 or 128 (CBR mode)
other values like 768kbps not support by microsoft (for 96kHz, 2 channel, 24bps source)
This post has been edited by Merlin_de: Jan 23 2011, 01:26
Ljubo44
post Jan 23 2011, 01:36
Post #21
on Q98_96_2_24 after encoding i get wma on 337kbps with a lot of losses and missing blocks in audio file from 16kHz to 48kHz ermm.gif
but thanks for help
This post has been edited by Ljubo44: Jan 23 2011, 01:37
Apesbrain
post Jan 23 2011, 02:46
Post #22
The only form of WMA that supports 24/96 is WMA Lossless. You can follow the guidelines in this thread and use the following parameters:
//NoLogo -silent -input %s -output %d -a_codec WMA9LSL -a_mode 2 -a_setting Q100_96_2_24
Or continue what you've started here and make the equivalent changes.
I just converted a 2-channel 24/96 FLAC file to 24/96 WMA Lossless in foobar2000 using WMEncoder and it worked fine; converting from a 24/96 WAV should be no different.
This post has been edited by Apesbrain: Jan 23 2011, 02:48
dazzle
post Jan 23 2011, 11:32
Post #23
Thank you for the answer - I just have to use mp3tag for now then until hopefully more would like to see the tag function. Thank you for the converter - it works great.
This post has been edited by dazzle: Jan 23 2011, 11:32
mudlord
post Jan 23 2011, 13:54
Post #24
Started to write a native Windows Media Audio encoder though...so no outside DLLs.
Merlin_de
post Jan 23 2011, 22:04
Post #25
WMAenc 0.1.0.2 beta released
changelog:
- fix crash if call with no args
- add preencode tagging support
(do not use inside foobar convert !!! foobar tagg after convert)
Tagging:
option          related wma attribute (hardcodet)
-album          "WM/AlbumTitle"
-albumartist    "WM/AlbumArtist"
-trackno        "WM/TrackNumber"
-discno         "WM/PartOfSet"
-title          "Title"
-author         "Author"
-description    "Description"
-copyright      "Copyright"
-rating         "Rating"
-year           "WM/Year"
-genre          "WM/Genre"
example for EAC:
-a_codec WMASTD -a_setting Q50_44_2 -input "-" -output "Test.wma" -album "%g" -trackno "%n" -title "%t" -author "%a" -year "%y" -genre "%m"
Download
This post has been edited by Merlin_de: Jan 23 2011, 22:07
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 27th February 2015 - 14:35
