IPB
encoding voice... bad sound, using stereo widening reveals alot of ar
punkrockdude
post Feb 21 2005, 03:43
Post #1
Group: Members
Hi everyone. This is my first post here and I hope you find it useable or interesting. I am no expert or anything when it comes to lossy audio compression. I just know what I think sound good and/or bad.
I would like to show you what I discovered when I used full one band stereo widening in Samplitude on audio with voice encoded with the latest OggdropXp with AoTuVb3 optimizing.
The ogg sample was encoded (q5) and then decoded with the OggdropXp version described above, and then processed in Samplitude using the built in stereo enhancer and saved as wav to not degrade the audio any further.
Uncompressed (unprocessed)
Uncompressed (processed. Full one band stereo widening)
OggOgg (processed. Full one band stereo widening)
I also encoded the audio in AAC (-b 160 and no low pass) using FAAC which didn't give me any audible artifacts.
What is your thoughts on this? Is this something that should be fixed quickly?
I have noticed that using stereo enhancers, you can easily hear if lossy compression has added artifacts. I always use this method to hear how good codecs are. It probably isn't the best and only way to hear/detect artifacts.
Best Regards
Rickard Gerthsson
http://www.damnsundaydrivers.com
Go to the top of the page
+Quote Post
kjoonlee
post Feb 21 2005, 03:45
Post #2
Group: Members
http://blacksun.ivyro.net/vorbis/vorbisfaq.htm
+Quote Post
Corezode
post Feb 21 2005, 04:02
Post #3
Group: Banned
I do that too, I use soundforge function called "pan\expand"
I also can do it on my headphones, I just switch it to 3d setting
This happens as the temporal masking affect and ear (nspsytune) models
They are desinged in codecs to sound good to human ear but not desingned to 3d sounding and stereo widening etc.. that's why you hear artifacts because lame and other codecs encode to human ear listining capabilities but not to audio processing
If you did the audio processing to the source then encoded it it would sound much better
EDIT: Typo
This post has been edited by Corezode: Feb 21 2005, 05:55
+Quote Post
punkrockdude
post Feb 21 2005, 04:33
Post #4
Group: Members
QUOTE (Corezode @ Feb 21 2005, 05:02 AM)
So this is something which is intended to happen becuase we can't hear it if we do not apply effects to the lossy audio? So this might show why lossless is best for editing and lossy is best for.... hm... listen to audio which are intended to be listened to "as it is"?
Aac didn't have this problem, but does it might have other "bad" things which ogg doesn't have?
Best Regards
Rickard Gerthsson
Edit: Oh, I now saw that Corezode answered my question about using lossy audio to listen to as it is and not for future archiving(?). Thanks for the help guys!
This post has been edited by punkrockdude: Feb 21 2005, 04:40
+Quote Post
kotrtim
post Feb 21 2005, 15:42
Post #5
Group: Members
hey punkrockdude
some stereo widening program (spatial) IS BAD (e.g.) I do have a "spatial" DSP in my windows playback control which creative driver includes.... it sounds terrible when i activate it!!!
anyway what stereo widening DSP are you using
I find foobar2000's spatial 3D quite good.....you can give it a try
it offers a few settings
QUOTE
oh I missed this point...NOTE...ogg use LOSSY stereo at -q 5, this might the reason there is artifact
FAAC uses LOSSLESS stereo!!
try (-q 6), see whether it solves this problem
This post has been edited by kotrtim: Feb 21 2005, 15:54
+Quote Post
punkrockdude
post Feb 21 2005, 16:07
Post #6
Group: Members
QUOTE (kotrtim @ Feb 21 2005, 04:42 PM)
hey punkrockdude
QUOTE
Hi Korttim.
I used the built in stereo enhancer in the sequencer Samplitude. I also tried encoding it in -q6 and -q7, though it sounds better the higher value I use, I still shows quite much artifatacts even at -q7
Regards
Rickard Gerthsson
+Quote Post
kotrtim
post Feb 21 2005, 16:53
Post #7
Group: Members
QUOTE
what artifact? hisshing?
i think it will be quite useful to developers........
+Quote Post
punkrockdude
post Feb 26 2005, 21:38
Post #8
Group: Members
QUOTE (kotrtim @ Feb 21 2005, 05:53 PM)
QUOTE
Even at -q9 i can hear the artifacts using stereo widening.
Man, I am so lost. Should I use AAC or Vorbis? I have tried aac and I ind it better sounding, but I don't want to let go of vorbis right away. If these artifacts wasn't there, I would not at all consider going over to AAC.
+Quote Post
Aoyumi
post Feb 27 2005, 11:24
Post #9
Group: Members
QUOTE (punkrockdude @ Feb 21 2005, 11:43 AM)
Best Regards
Rickard Gerthsson
Please use the encoder of reference by my web page. I do not hear a large problem like the above-mentioned sample.
This post has been edited by Aoyumi: Feb 27 2005, 11:26
+Quote Post
punkrockdude
post Feb 27 2005, 11:33
Post #10
Group: Members
I tried your reference encoder and it sounds the same. I want to say once again that these artifacts are only heard when I apply extreme stereo widening to the already encoded file.
+Quote Post
kjoonlee
post Feb 27 2005, 11:34
Post #11
Group: Members
QUOTE (kotrtim @ Feb 21 2005, 11:42 PM)
Not true! Not really.
Oggenc 1.0 and higher use LOSSLESS from q6, but q5.99 and below can be lossless too. Lossy channel coupling starts being used from 5.99, but lossless channel coupling can still be used if necessary.
+Quote Post
kjoonlee
post Feb 27 2005, 11:37
Post #12
Group: Members
QUOTE (punkrockdude @ Feb 27 2005, 07:33 PM)
http://www.catb.org/~esr/jargon/html/D/Don...that-then-.html
+Quote Post
punkrockdude
post Feb 27 2005, 11:49
Post #13
Group: Members
QUOTE (kjoonlee @ Feb 27 2005, 12:37 PM)
+Quote Post
Aoyumi
post Feb 27 2005, 11:51
Post #14
Group: Members
What I tried is the "uncompressed_stereo_widening.wav" sample shown you. Then, especially I did not encounter a problem.
It does not bring a severe result like "ogg_stereo_widening.wav."
+Quote Post
punkrockdude
post Feb 27 2005, 12:07
Post #15
Group: Members
QUOTE (Aoyumi @ Feb 27 2005, 12:51 PM)
Try the "Uncompressed (unprocessed)" and encode it to ogg. Then open the ogg with a program which can do stereo widening and listen.
+Quote Post
aspifox
post Feb 27 2005, 12:15
Post #16
Group: Members
QUOTE (punkrockdude @ Feb 27 2005, 10:49 AM)
Seriously, though. This is lossy perceptual encoding; when you alter the parameters of the perception (by heavy digital postprocessing) then all bets are off. If this problem isn't apparent in another format then that's only due to said format not being clever enough to throw away differences that would be inperceptable without such postprocessing, and it's not up to an encoder/format (except perhaps as hacky situation-specific encoding flags) to anticipate random combinations of postprocessing a user might want to apply.
+Quote Post
punkrockdude
post Feb 27 2005, 12:19
Post #17
Group: Members
QUOTE (aspifox @ Feb 27 2005, 01:15 PM)
Ok, thanks. I just wanted to show you my "discovery" and I thought that it might be useful. Now I understand that lossy formats are made to be "listened to as it is". No altering (stereo widening, eq:ing, etc), for that I'll use FLAC.
Regards
Rickard Gerthsson
Sweden
+Quote Post
lithoc
post Mar 15 2005, 02:28
Post #18
Group: Members
QUOTE (kjoonlee @ Feb 27 2005, 06:34 PM)
I remember oggenc does have loseless stereo build in any -q but it was missing since version 1. I still miss that features until today.
Could someone please put into oggenc wish list for the options??
I'm not coding guru, I heard the options can be tweak but need re-compile.
This post has been edited by lithoc: Mar 15 2005, 02:29
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 28th May 2015 - 03:13
