17 Pages V  < 1 2 3 4 5 > »
foo_softplaylists, Aggregated playlists from last.fm's loved track feature
JohanDeBock
post Nov 30 2009, 17:57
Post #51
I've already seen a position where this could happen.
How should I use the in_metadb_sync objects?
foo_softplaylists: http://tiny.cc/kh9m9
Yirkha
post Nov 30 2009, 21:18
Post #52
Group: FB2K Moderator
For example, instead of this:
handle->metadb_lock();
// Call some handle->*_locked() methods or whatever
handle->metadb_unlock();
Do this:
  in_metadb_sync_fromhandle lock(handle);
See SDK/metadb.h for others - in_metadb_sync instantiates metadb (for access to the lock/unlock methods) itself internally, in_metadb_sync_fromptr uses an external pointer (for contexts where it's already available).
JohanDeBock
post Dec 1 2009, 03:37
Post #53
New version:
Soft Playlists 2009-12-01
-Added: Last.fm Love Track command (enter Last.fm password in configuration)
-Changed: Fixed some bugs
-Changed: Optimized some code
This post has been edited by JohanDeBock: Dec 1 2009, 03:39
JohanDeBock
post Dec 1 2009, 03:41
Post #54
QUOTE (2E7AH @ Nov 30 2009, 02:20) *
JohanDeBock, can you see why is this happening: http://www.hydrogenaudio.org/forums/index....showtopic=76575
made some changes, does this still happen?
2E7AH
post Dec 1 2009, 04:10
Post #55
Group: Validating
don't want to spoil the party, but when I press abort if component is parsing last.fm - it just stays locked that way until I exit foobar. does it happens at yours foobar also?
[edit] well it just doesn't abort, it's not locked
if I limit users to 50, and press abort, then it waits for all download to finish - that's all
This post has been edited by 2E7AH: Dec 1 2009, 04:16
JohanDeBock
post Dec 1 2009, 04:19
Post #56
I actually didn't do anything special yet for the abort function. Haven't figured it out yet how to correctly implement it.
I think now it just tries to finish the command, without actually aborting, no?
Just update the XSPF load code, should be much faster for 10000+ playlists.
This post has been edited by JohanDeBock: Dec 1 2009, 04:20
2E7AH
post Dec 1 2009, 04:23
Post #57
Group: Validating
yes, I'm on restricted 10 KB/s for couple of hours, that's why I noticed wink.gif
JohanDeBock
post Dec 1 2009, 04:25
Post #58
Does the love track feature work for you?
It should normally write
foo_softplaylists: successfully loved Event Horizon They Waited by Christ.
on the console if it worked.
This post has been edited by JohanDeBock: Dec 1 2009, 04:26
2E7AH
post Dec 1 2009, 04:31
Post #59
Group: Validating
yeah, works fine - this is my first loved track, I never used such function biggrin.gif
JohanDeBock
post Dec 1 2009, 04:35
Post #60
Then there will finally be something in your playlist when you do User Loved Tracks wink.gif
2E7AH
post Dec 1 2009, 04:48
Post #61
Group: Validating
+ your component will make me scrobble again, after I stopped as last.fm radio stopped working for me
This post has been edited by 2E7AH: Dec 1 2009, 04:49
carmenm
post Dec 1 2009, 08:56
Post #62
THANK YOU!
Keesface
post Dec 1 2009, 09:01
Post #63
Fractal_Mortalit...
post Dec 1 2009, 09:06
Post #64
QUOTE (JohanDeBock @ Nov 30 2009, 21:37) *
You sir, are my hero.
http://www.last.fm/user/magnumforce2006
marc2003
post Dec 1 2009, 11:10
Post #65
if you try and love a track with an "&" in it, it fails. console message-
foo_softplaylists: failed to love Son & Moon by Cortney Tidwell
wojtek
post Dec 1 2009, 12:14
Post #66
QUOTE (JohanDeBock @ Dec 1 2009, 03:37) *
WOW, brilliant!
Two things tho:
- would it be possible to somehow synchronize love tracks from last.fm with tags (for the moment one can't know if the track is already marked, I solved it by retrieving my love tracks and tagging it and then adding separate column, but something more automatic would be nice smile.gif )
- using new menu would be nice, at the moment context commands are in "Legacy commands" category.
http://foobar2000.pl/ :: unofficial polish forum
JohanDeBock
post Dec 1 2009, 14:07
Post #67
QUOTE (marc2003 @ Dec 1 2009, 11:10) *
Will check it out.
QUOTE (lwiczek @ Dec 1 2009, 12:14) *
Can't do anything about that now, must wait for new SDK.
This post has been edited by JohanDeBock: Dec 1 2009, 14:08
dreadroach
post Dec 1 2009, 14:12
Post #68
Thank you for "love track" feature, works great!
If you add support for generating playlist based on last.fm tags, this will be my favorite foobar component biggrin.gif
Disregard the constabulary.
wojtek
post Dec 1 2009, 15:35
Post #69
QUOTE (JohanDeBock @ Dec 1 2009, 14:07) *
Hmm... weird. I have some plugins (i.e. last.fm radio or foo_uie_tagger_mod) that put commands in context menu outside Legacy group. I just thought it was already possible, therefore the suggestion. Sorry if I made wrong assumption.
Yirkha
post Dec 1 2009, 16:00
Post #70
There are fallbacks for some of the common group names, so that at least some of the non-updated components don't not end up in the Legacy group. If one context menu service doens't return multiple different default paths, that is. Or provide dynamic submenus, I think.
Fractal_Mortalit...
post Dec 1 2009, 16:19
Post #71
QUOTE (lwiczek @ Dec 1 2009, 06:14) *
Great suggestion. Something like a simple masstagger script to tag each track with "loved track" would be sufficient enough, unless anyone else has any suggestions.
marc2003
post Dec 1 2009, 17:09
Post #72
for anybody that uses columns UI, i've made a WSH panel mod button that can "love" a track and also tag the file at the same time.
download (includes WSH panel mod + images) - http://cid-649d3bfeaf541fbb.skydrive.live....oobar/loved.zip
extract contents into foobar directory. add a WSH panel to your layout. now right click it and choose "Configure". use the text from "code.txt" to replace the existing contents. it should work straight away but check the comments at the top for settings you might want to change.
when playing, it works on the "now playing" item and when playback is stopped, you can use it to love/tag the selected item.
This post has been edited by marc2003: Dec 1 2009, 17:09
carmenm
post Dec 1 2009, 17:30
Post #73
QUOTE (Fractal_Mortality @ Dec 1 2009, 17:19) *
ACtually the lastfm api can tell you if a track is loved (track.getInfo)
So one thing we could do is do something like what biography_view does, which is add a temp tag to the playing song with the flag for loved. That way we could now if the playing track is already loved.
After that we could imagine a masstag script to do so as a permanent tag.
What do you think JohanDeBock?
On something else, i dont know if you saw my last comment in audioscrobbler thread but i feel today like we have too much lastfm related plugins(lastfm_radio, biography_view and softplaylists), and that maybe, if all dev would agree, they should be combined in one ULTIME plugin. What do you think?
Keesface
post Dec 1 2009, 18:26
Post #74
QUOTE (carmenm @ Dec 1 2009, 17:30) *
I totally agree. I would love to have one plugin that grabs all kinds of data from last.fm and puts it into custom taggin fields or temporary fields. I currently use biography_view to show similar artists and last.fm playcount, and make playlists with soft_playlists. I would love to hear the opinion of some component developers smile.gif.
JohanDeBock
post Dec 1 2009, 18:51
Post #75
This is already fixed, but not released yet.
Also trying to solve problems with special characters like in "Röyksopp".
I can already correctly get the top tracks of Röyksopp", but not love any tracks of Röyksopp".
I'm sending the parameters utf8 encoded like they should be, but it still doesn't work.
This post has been edited by JohanDeBock: Dec 1 2009, 18:52
RSS Lo-Fi Version Time is now: 24th November 2014 - 10:51
