IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
Can Foobar read a list of cue sheets?
ech3
post Sep 19 2012, 03:18
Post #1
Group: Members
I'm starting a huge flac to mp3 conversion of thousands of albums.
I'd like to be able to feed FB2K a huge list of cue sheets, each with a fully qualified path name.
Can it do something like that? Or some other way of adding batches of hundreds of cue sheets at a time?
Go to the top of the page
+Quote Post
shakey_snake
post Sep 19 2012, 04:24
Post #2
Group: FB2K Moderator
File -> Add folder... ?
This post has been edited by shakey_snake: Sep 19 2012, 04:33
elevatorladylevitateme
+Quote Post
ech3
post Sep 19 2012, 23:27
Post #3
Group: Members
But doesn't this load everything (mp3, flac, etc)? I only want to load .cue files.
+Quote Post
ruebe
post Sep 19 2012, 23:59
Post #4
Group: Members
why don't you just search in the file manager of your choice for *.cue and then drag'n'drop them into foobar?
too simple?
+Quote Post
ech3
post Sep 20 2012, 00:34
Post #5
Group: Members
Well, yeah. But...
It's very easy to generate a file of cue sheets by doing: dir /s /b *.cue >filelist.txt
I've already done this and edited out a bunch of albums I don't want to convert.
If I could feed this file to Foobar it would make this a lot easier.
+Quote Post
Boiled Beans
post Sep 21 2012, 18:32
Post #6
Group: Members
You could also use File -> Preferences -> Media Library to restrict to, or exclude the file types.
+Quote Post
foosion
post Sep 21 2012, 20:00
Post #7
Group: FB2K Moderator (Donating)
Short answer: Create a playlist file containing all cue sheets and load it into foobar2000, for example using drag and drop.
Long answer:
Create a text file with one line per cue sheet. Each line should contain the path to a cue sheet. The path can be absolute or relative to the directory where you store the file. Perhaps that is exactly what you already have.
Give the file the extension ".m3u" or ".m3u8" if the file is UTF-8 encoded. Now you have a playlist file in M3U format containing cue sheets. Each cue sheet can contain multiple tracks. Foobar2000 can reference individual tracks inside the cue sheet. However the M3U format does not support this feature of foobar2000. So when foobar2000 encounters a cue sheet in an M3U playlist, it just loads all of the tracks.
http://foosion.foobar2000.org/ - my components for foobar2000
+Quote Post
ech3
post Sep 22 2012, 13:33
Post #8
Group: Members
Foosion, I *swear* I tried exactly what you described but I couldn't get it to work. When I loaded the .m3u file, I just got a blank playlist.
Tried again and now it works. <shrug>
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 2nd September 2015 - 16:50
