send to playlist/temporary entry
juglesh
post Nov 21 2009, 20:59
Hi, in 8.3 i have a keyboard shurtcut to "send to playlist/temporary entry" This sends the song to the previous (left tab) playlist, and focuses the playlist.
is there something like this in 9.6.9? the thing i see is "send to playlist..." which asks you every time which playlist you want it sent to.
what i do in 8.3 is open a blank pl in a tab, then my 'all' playlist. i can easy make cd's or pl's by hitting S (to send it to the blank pl) and then W (focus back to the 'all' pl, via Previous Playlist)
thanks
juglesh B>{)}
www.RadioKDUG.com
tpijag
post Nov 21 2009, 21:12
Use Foosion foo_util
http://foosion.foobar2000.org/components/?...on=0.6.2+beta+6
You can bind key to specific playlist. Don't think it will work exactly as your explained workflow...but it may get you acceptably close.
terry
2E7AH
post Nov 21 2009, 21:13
Group: Validating
or Ctrl-C + Ctrl-PgDn (bind to "previous playlist" command) + Ctrl-V
trout
post Nov 21 2009, 21:14
foo_utils will give you "send to" shortcuts to a specific playlist
http://www.hydrogenaudio.org/forums/lofive...php/t18276.html
edit : sorry about repeated info
This post has been edited by trout: Nov 21 2009, 21:15
juglesh
post Nov 22 2009, 19:44
it will only send or add to a named pl. so you have to make a 'collector' pl, name it something, bind 'add to playlist: collector' to shortcut. if you remove 'collector' pl, you will have an error in your shortcut prefs, but it seems like if you recreate it, the shortcut will work again.
so, yeah, that pretty much solves it smile.gif thanks
juglesh B>{)}
www.RadioKDUG.com
RSS Lo-Fi Version Time is now: 2nd August 2015 - 20:05
