EAC/REACT - Missing Cuesheet error
Skinjob
post Apr 13 2008, 22:37
I just recently upgraded to the latest EAC (0.99pb4) and REACT (2.0.ssb16p). Now, whenever I try to rip to FLAC tracks, I get an error message "REACT: Missing Cuesheet" with the description "Unable to move cuesheet. File does not exist".
I'm ripping tracks, not images, and I have CreateAllCuesheets=0 in my REACT.ini, so I'm not sure why it's trying to create a cuesheet. I poked around in the source code and it seem like fGUICreateGleanCuesheet is called unconditionally. Is this be design?
The problem seems to be that EAC won't create a cue sheet. Even when I try to create one manually from the Action\Create Cuesheet menu it won't do it. I don't get any error message, but no cue file is created. But again, I'm not sure why REACT is trying to create one in the first place.
Sythetic Soul, it you're out there, could you please offer some advice?
Skinjob
post Apr 13 2008, 23:28
Never mind, I'm an idiot. I was missing a trailing backslash in the EAC extraction folder path. It's creating the cue file correctly now.
Still not sure why the cue file is needed, but at least it's working now.
Synthetic Soul
post Apr 14 2008, 09:02
QUOTE (Skinjob @ Apr 13 2008, 22:37) *
Later versions of my mod create a cuesheet in track mode to determine the number of audio tracks on the CD. EAC reports the total number of tracks - which may include data tracks - so this workaround is necessary to ensure that post-processing code is always run.
I'm glad that you managed to resolve it.
I'm on a horse.
Skinjob
post Apr 14 2008, 15:09
QUOTE (Synthetic Soul @ Apr 14 2008, 03:02) *
So you're saying that the post-rip processing (ReplayGain, etc.) at the end of the .cfg file will actually run now on disks that have a data session? If so, that's a very nice fix.
Do you still have to select the last audio track for this to work, or will it work with arbitrarily selected tracks that don't include the last one? This would come in handy when you get errors and have to rerip a few tracks. It would be nice if the ReplayGain was recalculated in that case. I always seem to forget it.
Anyway, thanks for the quick reply and thanks for continuing REACT development. As nice as dbPowerAmp is becoming, it still doesn't come close to the control and customization you have with EAC/REACT.
Moderation: Quotation fixed.
This post has been edited by greynol: Apr 14 2008, 17:38
Altair
post Sep 9 2008, 16:24
I got REACT working but I still have a small bug. I too am getting an error message from 'React v2.0.akku.b03' saying "Unable to move cusheet. File does not exit. Canceling will abort rip." I get choices retry or cancel.
I'm ripping to FLAC and Mp3 tracks with cuesheets= in my .INI file. There is a terminal backslash in my EAC path as described above. If I just keep hitting 'retry' everything works fine, but...? Any ideas?
Akkurat
post Sep 9 2008, 23:44
REACT Mod developer
QUOTE (Altair @ Sep 9 2008, 18:24) *
1) Does this happen with every CD?
2) Does pressing retry once solve the problem?
3) Do you see an "Analyzing" window with "Detecting Track Indices" (this is crucial, there are other "analyzing" windows) text in it when starting a rip?
  3.1) Does it stay visible long? (about seconds)
4) You said something like "had to downversion EAC" in the other thread, what did you mean, i.e. what EAC version are you using?
Put DebugMode=1 in INI and try to rip a CD (+retry until you succeed) and post the debugging.txt file (in REACT folder) contents to here (in CODEBOX tags). You can cancel the rip once it starts extracting the tracks.
Altair
post Sep 12 2008, 05:06
QUOTE (Akkurat @ Sep 9 2008, 17:44) *
Only on CD's subsequent to a CD whose album art cannot be located by aad.
Retry only brings another error of the same in a short while.
Only analyzing window is: "Detecting Pre Track Gaps", which appears when I cancel the missing cue sheet message.
It is present for about a minute on a 1hr CD
I am using EAC .95beta4
Before I "debug" my guess is the message is related to my closing aad in a wrong fashion when it does not find any or doesn't find an acceptable piece of album art. In these cases I have tried additional searches in aad by modifying the album name/artist as read from freedb. Sometimes I may try 3 or 4 times to find a classical cover. Each attempt opens a new aad window. I think perhaps REACT is linked only to the first window and my 'X'ing out of the additional windows after saving the art from an unlinked window creates the problem.
When I rip a CD that has artwork found by aad and saved by my clicking on it, the process goes smoothly and I move on to the next CD seamlessly.
So with this in mind, 2 questions:
1) What is the proper way to handle aad when it comes up empty handed?
2) .95beta4 doesn't have accuraterip, may I use .99prebeta4, and how would I upgrade without screwing up REACT?
Akkurat
post Sep 13 2008, 20:33
REACT Mod developer
QUOTE (Altair @ Sep 12 2008, 07:06) *
Before I "debug" my guess is the message is related to my closing aad in a wrong fashion when it does not find any or doesn't find an acceptable piece of album art...
I can't reproduce your problem.
1) With my tests, any way you like.. but that's not working with you right now. P.S. Opening new windows doesn't screw up the process since they do NOT open in new instances.. REACT just waits for the program to be closed (if RunCoverDownloader is set to 1 or 2 in INI (in track mode)).
2) Of course you can use the newest EAC. Updating EAC doesn't touch REACT settings.
I suggest that you update EAC to the latest version (.99pb4). If you still after that have problems, please post here a list of steps to reproduce the problem.
Akkurat
post Sep 16 2008, 12:04
REACT Mod developer
@Altair: I just had an idea; have you tried to change the "EAC -> Drive Options -> Gap Detection" settings? The about 1 minute duration of the "Detecting Pre Track Gaps" window you mentioned sounds a bit too long to me.. you could try to change the detection method. I have this 1 CD (out of about 400 CDs) which fails weirdly the gap detection method I've chosen and because of this, REACT gives me warning messages. Maybe the CD drive, gap detection method chosen & some of your CDs combination fails with you too. Long shot but easy and fast to try out.. you never know. smile.gif I don't know if the "detection accuracy" affect the process, I've it set to "Secure", but it maybe worth to try out also that setting.
dag0
post Oct 8 2012, 21:21
I have the same problem as Altair since upgrade to Win7 with Eac 0.99 (wich I used before with WinXP) but not with eac 0.95 beta4. My akkumod is b04. What could be the reason and what the disadvantage of EAC 0.95?
This post has been edited by dag0: Oct 8 2012, 21:26
dag0
post Oct 25 2012, 17:08
QUOTE (dag0 @ Oct 8 2012, 21:21) *
Silly me, I had only a "\" in my EAC-Config as Outdir. I thought this was automatically configured correctly by REACT. Now it works!
Other question: How do I get this "Additional Metadata Dialog" working. I can se my individual tags as configured in REACT.ini in the dialog, but they do not appear as tags in my encoded files. What do I have to do? I am encoding to flac-image plus cue-sheet.
This post has been edited by dag0: Oct 25 2012, 17:09
RSS Lo-Fi Version Time is now: 4th September 2015 - 03:12
