72 Pages V  « < 47 48 49 50 51 > »
foo_discogs, Tags files with information from Discogs
den_po
post Feb 22 2012, 19:42
Post #1201
http://www.discogs.com/release/332284
Y4K &rarr; Dub Pistols - Next Level Breaks
pulha
post Feb 29 2012, 21:54
Post #1202
This plugin is not fetching the artwork properly.
When i am tagging the files with it the following error message apears on the console:
[20:49:36] foo_discogs: error: problem creating file D:\!MÚSICA\Adderall Canyonly\2010 - It Was A Dark And Stoney Night\folder.jpg [Access denied], skipping...
However, if i run it again, with everything tagged by now, it can fetch the artwork.
Please help!
pulha
post Mar 18 2012, 23:04
Post #1203
Same problem just as in here: http://www.hydrogenaudio.org/forums//lofiv...php/t71471.html
DISCOGS_RELEASE_ID is writing. Don't know what to do
den_po
post Mar 24 2012, 23:07
Post #1204
what about releases like this one? http://www.discogs.com/Prodigy-The-Dirtcha.../release/672166
TGK
post Apr 1 2012, 19:17
Post #1205
Hi !
When using the plug to fill foo_discogs tag to mp3 tag in some fields (particularly in the field of NOTES - where there are a few lines to the transfer and spaces) squares appear, I suspect it has something to do with space and / or coding. I tried to save different versions of ID v.2.3 and v.2.4, including compatibility mode does not help the squares still occur.
Do you have any idea how to remove these squares when using this plugin ?
mcladams
post Apr 26 2012, 14:22
Post #1206
Haven't used this for a few years, but now I have bought a Traktor Kontrol S4 I'm getting into the digital age...
Just reinstalled foobar2k and foo_discogs, I find that it no longer maps the Discogs Rating?
Is there something I'm missing or do I have to revert to an earlier version to get this (if so, which)?
Anakunda
post Apr 29 2012, 11:11
Post #1207
Anybody else having the discogs tagger connection problems too? Last week it very often stucks at information retrieval. And it also is very slow when fetching information from webserver. I get this: discogs error: release id=1106196: no error.
simcut
post Jul 13 2012, 05:25
Post #1208
Hey all, hope someone can help me.
I'm using the fileops function along with the discogs plugin to move my files to a folder with this structure
\$replace(%discogs_label%,*,)\ $replace(%discogs_catalog%,*,) - $replace(%album artist%,*,) - $replace(%album%,*,) ['('$replace(%date%,*,)')']/$replace(%tracknumber%,*,). $replace(%artist%,*,) - $replace(%title%,*,)
however, for some unknown reason, quite a lot of the time it doesnt recognise the discogs_label and puts a "_" instead (without quotations), but other times it recognises the label fine. I'm really confused as to what is causing this error....
Any idea what the cause is?
This post has been edited by simcut: Jul 13 2012, 05:38
_oao
post Aug 29 2012, 14:11
Post #1209
I'm getting a
discogs error: release id=1431576: problem connecting to discogs.com
And i can't tag anything using foo_discogs v1.30
Is anyone having the same problem?
lordfrikk
post Oct 3 2012, 09:46
Post #1210
Is it somehow possible to map the index track names to titles? I have this compilation where each track is composed of multiple tracks but the original tags had only the index name (Intro, The Soundboy And The Terrorist, Bring That Back, etc.) in the %title% tag. I was hopping I could edit the mapping but the index names aren't exposed (at all or just in your plugin?).
Other than that I suppose there is no way to create something similar, eg. titles with different sub-titles in the tags? Probably not but I'm asking just in case.
This post has been edited by lordfrikk: Oct 3 2012, 09:47
frozenspeed
post Oct 10 2012, 18:30
Post #1211
Anyone having trouble with this plugin as of Oct 10?
I can't do any lookups at all, it just spins into infinity.
alexinc
post Oct 11 2012, 08:54
Post #1212
for me it works...
hey bubble, only one little little request thats bugs me since years now. can you please add the possibility to move more than 1 marked track in discogs release screen up and down, so a whole block can be move? thx :-)
frozenspeed
post Oct 11 2012, 17:01
Post #1213
For the record it has started working for me again this morning, must have been something on discogs.com's side.
fuffi
post Oct 15 2012, 16:54
Post #1214
a feature request:
would it be possible to NOT list all the [master] entries, if searching for "master" ?
I was looking for a album named "master-view" in the plugins "find release" window, and the fine plugin showed me not only the hits, but all the [master] entries, which did NOT contain the word "master" in its shown title.
So it looks to me, that the fine plugin did a simple text search about all the words, but it seems not to be possible to exclude the nodes [master] from the search-result.
so my feature request, or, if I may, I'd like to ask some other users if they would do a search for "master", would you expect the result as described above? or do you actually filter for "[master]" in the small and tiny find-release-window?
Lasternom
post Nov 16 2012, 04:30
Post #1215
Hi, kinda new to the forum but i hope you guys could help me.
Been trying to fix my huge list of music with the discogs tagger.
However I noticed something weird. When I started tagging my mp3's, I was able to use it just fine.
But after one use of discogs, the tagger won't read the artist tag that is displayed in the file I just tagged.
Problem
top left is box is unable to find artist name, that is shown correctly on the right.
This only happens when I used the discogs tagger once on the files. And only discogs is unable to see the artist name, other parts
of foobar have no problems. I also tried resetting all setting to default but no luck.
Does anybody knows what is going on ?
thanks for all the help
-Lasternom
This post has been edited by Lasternom: Nov 16 2012, 04:31
alexinc
post Nov 16 2012, 10:39
Post #1216
not quite sure, but i guess the tagger only reads id3v1 - so after tagging with id3v2 it doesnt show the artist tag anymore...
NogginJ
post Jan 4 2013, 07:04
Post #1217
Is it just me or did it stop working again?
discogs error: release id=106509: problem connecting to discogs.com
Could it be opened up a little, maybe a config setting, so we could just copy/replace whatever it is that keeps killing it? I'm guessing its an address or something somewhere.
If this is something new, nevermind.
This post has been edited by NogginJ: Jan 4 2013, 07:04
NogginJ
post Jan 5 2013, 20:19
Post #1218
As of today, it's working again. Must've been a discogs thing.
Thanks yall.
eamon123
post Mar 6 2013, 20:47
Post #1219
Bug: Multiple disc releases are incorrectly tagged with an ‘x’ instead of a ‘×’.
pmg
post Mar 31 2013, 20:27
Post #1220
QUOTE (lordfrikk @ Oct 3 2012, 09:46) *
Is it somehow possible to map the index track names to titles? (...) I was hopping I could edit the mapping but the index names aren't exposed (at all or just in your plugin?).
Hi, having the same question/request. But, is the tagger still under development? It would be nice.
roded
post May 12 2013, 10:58
Post #1221
The foobar2000 discogs plugin has become quite slow since recently...
Is this a local problem or is anyone else experiencing such issues?
Roded
birrein
post May 17 2013, 16:25
Post #1222
I have this error:
discogs error: release id=4570505: XML parse error
When i try to tag this release:
http://www.discogs.com/Daft-Punk-Random-Ac...release/4570505
orchid
post May 27 2013, 18:52
Post #1223
QUOTE (birrein @ May 17 2013, 18:25) *
I have this error:
Same here
discogs error: release id=3746084: XML parse error
On release: http://www.discogs.com/Utah-Jazz-Groove-Th...release/3746084
Anakunda
post Jun 7 2013, 13:49
Post #1224
Is this abandoned project yet?
I'd very appreciate fixing the XML parsing problem.
Getting many these:
foo_discogs: error: release 4632804: XML parse error
LAyout matches...
Please fix this!
bubbleguuum
post Jun 7 2013, 21:18
Post #1225
The two releases linked above give no error for me. If you find a non working release, give the link.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Hydroc
RSS Lo-Fi Version Time is now: 30th May 2015 - 20:36
