103 Pages V  « < 34 35 36 37 38 > »
CUETools versions 1.9.5 through 2.1.5 (current), AccurateRip support & more
krafty
post Mar 27 2010, 19:17
Post #876
Thanks for your explanation Gregory...
I think I am missing something though, as I can't run under mono (1.9.5 and 2.0.4a tested)...
$ mono CUETools.exe
** (CUETools.exe:2671): WARNING **: The following assembly referenced from /home/krafty/win32/CUETools_2.0.4a_x86/CUETools.exe could not be loaded:
     Assembly:   System.Windows.Forms    (assemblyref_index=0)
     Version:    2.0.0.0
     Public Key: b77a5c561934e089
The assembly was not found in the Global Assembly Cache, a path listed in the MONO_PATH environment variable, or in the location of the executing assembly (/home/krafty/win32/CUETools_2.0.4a_x86/).
** (CUETools.exe:2671): WARNING **: Could not load file or assembly 'System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies.
Unhandled Exception: System.IO.FileNotFoundException: Could not load file or assembly 'System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies.
File name: 'System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
Gregory S. Chudo...
post Mar 27 2010, 19:26
Post #877
I guess this is a problem with your mono installation. The missing .dll (Windows Forms) should be a part of normal mono package.
If you built it from source, try rebuilding and reinstalling it. Check configure options, perhaps you need to specifically enable Windows Forms support.
If you installed it as a package, perhaps there's a separate package for Windows Forms.
CUETools 2.1.4
krafty
post Mar 27 2010, 20:38
Post #878
Gregory, excellent!
I have installed:
libmono-winforms1.0-cil
libmono-winforms2.0-cil
libmono-system-runtime1.0-cil
libmono-system-runtime2.0-cil
Now it works... (both only works with WAV)
Tested 1.9.5 and the 2.0.4a.
Were you saying "new" versions the experimental ones?
Many thanks for this help.
This post has been edited by krafty: Mar 27 2010, 20:51
shanahan
post Mar 27 2010, 20:59
Post #879
QUOTE (Gregory S. Chudov @ Mar 27 2010, 18:37) *
Oops, sorry again, forgot one file, had to reupload.
Gregory S. Chudo...
post Mar 27 2010, 21:00
Post #880
Yep, 2.0.6/2.0.7
CUETools 2.1.4
krafty
post Mar 27 2010, 21:07
Post #881
Confirmed, FLAC working with 2.0.6
neovibe
post Mar 28 2010, 14:57
Post #882
Dear all, thanks for this great software, BUT, I'm having a big issue... files converted to ALAC don't play in my iphone! And I have just spent one week converting hundreds of albums with cuetools to find I now have to do it all again sad.gif
I am converting flac+cue to ALAC using libALAC. Everything works great, files play ok in itunes under mac and windows. BUT, when I sync files to my ipod, each song is presented as being 3 or 4 hours in length, I get a 1sec sound at the start and then no audio.
If I take these cuetools files and transcode them again to ALAC using MAX... they play perfectly in the iphone...
Is there any reason why cuetool's alac encoding is incompatible with ipod/iphone? anyone else had this experience?
I'm using standard options in cuetools... anything I should have selected/unselected?
thanks in advance, your help is appreciated.
cheers
zfox
post Mar 29 2010, 16:28
Post #883
I've found a duplicate in the base here. As long as the redundancy file is not uploaded twice, there would be no size problem for the base. If duplicates appear that way though, this could render the web interface unreadable/unsearchable in the future.
Gregory S. Chudo...
post Mar 31 2010, 07:00
Post #884
QUOTE (zfox @ Mar 29 2010, 19:28) *
Thank you. This shouldn't happen, i will find out why it did.
ctdb=> select DISTINCT tocid from submissions2 s1 where exists(select * FROM submissions2 s2 where (s1.id <> s2.id AND s1.tocid = s2.tocid AND s1.crc32 = s2.crc32 AND s1.trackcount = s2.trackcount));
            tocid
6BsNdDOAjhrnEfNfk0Nj65F30ag-
m.NFbfRVymivB0Gxo2nKCqljoTo-
ozAmTcdW0sVURX.5cj4nd9rtIb4-
(3 rows)
Looks like there's already three of them.
CUETools 2.1.4
Gregory S. Chudo...
post Mar 31 2010, 07:15
Post #885
QUOTE (neovibe @ Mar 28 2010, 17:57) *
That's very unfortunate. I'm sorry, i don't have an ipod (i prefer cowon), so i cannot fix it right now, not until i borrow one. When i first published this encoder and asked to test resulting files on ipod, there were reports that it works. Encoder didn't change much since then, so there's a possibility that it does work on certain models/firmware versions, so can you please tell which one do you have?
The only option in cuetools that could affect this is a high compression level (9-10), but i doubt it.
UPD: here's three clips encoded with different versions of encoder. Can you please test if any of those work on your ipod?
This post has been edited by Gregory S. Chudov: Mar 31 2010, 07:34
Attached File(s)
CUETools 2.1.4
prefab
post Mar 31 2010, 11:27
Post #886
QUOTE (Gregory S. Chudov @ Mar 31 2010, 08:15) *
I have an ipod touch latest hardware (3rd g), with latest OS (3.1.3) and I can reproduce the problem described by neovibe: the file length when playing is 16:16, although in the description it accurately says 0:22.
If the files are converted to Apple Lossless with itunes they play correctly. I am enclosing them here in case it will be of help.
I have also tried adding the itunes tags BPM, ITUNESMEDIATYPE, ITUNNORM from the converted files but without luck.
Cheers
Attached File(s)
Gregory S. Chudo...
post Mar 31 2010, 11:54
Post #887
Thank you. This should help.
CUETools 2.1.4
radio_cascara
post Mar 31 2010, 20:13
Post #888
QUOTE (Gregory S. Chudov @ Mar 27 2010, 20:49) *
To summarize: if you use default settings, all should be well. You can damage your image only by selecting exotic features, such as gaps handling methods other than default.
Thank you very much for your most useful and detailed explanation. Also for all the time and hard work invested in this project smile.gif
Manlord
post Apr 2 2010, 16:18
Post #889
Gregory, thank you so much for this fantastic tool. I have been using it for some time and now I can't imagine how I could live without it.
When I use it to enconde from image to tracks I like to use the automatic tagging, to write the tags from the cue file. But, if you do this using FLAC the tag that contains the number of tracks is written as "TRACKTOTAL" when the deffault name (I think that) is "TOTALTRACKS". ┐Could you please fix this so everything works automatically?
Thank you for your effort.
This post has been edited by Manlord: Apr 2 2010, 16:31
neovibe
post Apr 2 2010, 20:24
Post #890
QUOTE (Gregory S. Chudov @ Mar 31 2010, 06:15) *
Hello and thank you for your reply.
I am using a recent iPhone 3GS 16gb, libALAC encoder compression set to 5 on cuetools.
Would try the files you sent, but in itunes they show as 0:00 (tried in two intals, MAC and PC).
Regarding the files I already converted, I could probalby use MAX or DBPoweramp and transcode them to ALAC (from ALAC) and it would work... but as I'm not sure what went wrong and I'm not planning to convert these files ever again, I think I'm going to do it all over again. First use CUETOOLS to split to FLAC (would prefer WAV but it doesn't support tags) and then DBPoweramp to convert to ALAC.
still think it's a great tool, thanks for your work.
cheers
jpl73
post Apr 2 2010, 21:37
Post #891
QUOTE (Gregory S. Chudov @ Mar 25 2010, 19:02) *
Thank you. I'll have to add one of those drives to my shopping list. Here's a slightly different version of CUERipper, i hope this works: http://www.cuetools.net/install/CUETools_2.0.7.rar. This is only a CUERipper update, no changes to CUETools there.
Gregory: Thanks for the update. I just tried it out and CUE Ripper works great on my Samsung drive now. I feel like a kid at Christmas. First I find FlaCUDA, then I find CUETools and now CUERipper. This is great!!!
Alex B: Thanks for copying my post over here, to a more lively thread.
gregory
post Apr 3 2010, 15:20
Post #892
Could a variable be added to the output syntax that would return the selected audio output(flac, ape, etc.)?
jaaktmgi
post Apr 6 2010, 08:23
Post #893
Thank you very much, Gregory, for your continuos work on CUETools!
I have one small problem when using v2.0.7 on Windows XP SP3.
Namely, I am splitting a WAV-file (whole CD image) according to cuesheet that is UTF8 encoded (and has also BOM at the beginning of the file).
The libFLAC is selected as encoder. CUETools does fine job and splits the CD image into tracks that have correct UTF8 filenames.
Unfortunately the created NONCOMPLIANT CUESHEET is not UTF8 encoded and has "?" marks instead of Unicode characters.
I can't figure out what I am doing wrong...
The settings look as seen in the attachment.
Many thanks in advance,
Jaak
Attached thumbnail(s)
kitzik
post Apr 6 2010, 09:19
Post #894
Is there any way to disable comment writing for embedded album art (now it writes full album art path as a comment)?
Alex B
post Apr 6 2010, 15:33
Post #895
QUOTE (jpl73 @ Apr 2 2010, 23:37) *
... Gregory: Thanks for the update. I just tried it out and CUE Ripper works great on my Samsung drive now. ...
I can confirm this. I finally had time to test the v.2.0.7. My Samsung drives work now.
In general CUERipper is very nice, but unless I am missing something, it doesn't seem to be able to handle "various artists" albums. I'd like to request a similar system that EAC has.
Tigerman
post Apr 9 2010, 19:47
Post #896
Great updates of cuetools, very much appreciated!
Found a small inconvenience: After the log is written, it's not released by cuetools, so a directory containing the last log can't be deleted or moved (without closing cuetools or using unlocker).
This post has been edited by Tigerman: Apr 9 2010, 19:49
kasiusclay
post Apr 10 2010, 01:08
Post #897
First of all. Thanks for all the time you have put into this awesome application, now I have it I would feel a little lost without it. Talk about making life easy.
A feature that I would like to see is to be able to choose whether or not the album should have 'FLAGS DCP' in the cue.
I have been trying to create a batch file to drop my cue into and have it insert the FLAGS DCP on the next line after the TITLE entry, so far unsuccesful. If some one can help I would be greatly appreciated.
Again, Great work
Fandango
post Apr 10 2010, 20:15
Post #898
QUOTE (Tigerman @ Apr 9 2010, 19:47) *
using unlocker).
Oh, is it really CUE Tools that has the handle on the log file?
For me usually it is always the file editor (UEdit32 to be exact) or in rare cases the Windows Explorer.
Tigerman
post Apr 11 2010, 10:27
Post #899
QUOTE (Fandango @ Apr 10 2010, 20:15) *
using unlocker).
After some more testing, it's only after a log written when a cd is not found in the AR database (I'm using the "only if found" script.
And only the last one.
But it is cuetools which has the handle then.
Fandango
post Apr 11 2010, 13:08
Post #900
QUOTE (Tigerman @ Apr 11 2010, 10:27) *
Ah, ok. That explains why I never encountered it.
RSS Lo-Fi Version Time is now: 23rd September 2014 - 01:53
