Best frequency range test?
CoyoteSmith
post Dec 11 2010, 23:29
I've seen quite a few of these only, however, they all seem to have their share of problems from not going high enough in frequency (looking for 22khz or above) or if they are high enough then they do not have long enough clips (more than two seconds) which makes listening hard. Where can i find a good test that is guaranteed to go over my hearing capacity?
saratoga
post Dec 11 2010, 23:53
AFAIK foobar2000 will generate any tone you ask it for, and of any duration. Assuming you have at least a 48khz sample rate (really 96k is likely to be preferable), go to 'add location' and type 'tone://22000,10' for a 22kHz 10 second long tone.
CoyoteSmith
post Dec 12 2010, 02:51
where do i type that? i tried a lower frequency in the "filter" filed but nothing happened
saratoga
post Dec 12 2010, 02:58
File Menu IIRC.
greynol
post Dec 12 2010, 07:40
Make sure your hardware is capable of playing these signals without trouble. Depending on your signal, some hardware may resample poorly causing false-positives resulting from aliasing. If this is the case, configure foobar2000's resampler to convert the signal to your soundcard's native sample rate.
Kees de Visser
post Dec 12 2010, 09:53
This site offers some interesting tests:
http://www.audiocheck.net/audiotests_frequencycheckhigh.php
dhromed
post Dec 12 2010, 12:12
QUOTE (saratoga @ Dec 11 2010, 23:53) *
Additionally, the command sweep://8000-10000,10 will generate a sweep.
dhromed
post Dec 12 2010, 12:16
QUOTE (Kees de Visser @ Dec 12 2010, 09:53) *
A good one in terms of length and range, though the voiceover is something of a distraction.
pawelq
post Dec 12 2010, 18:12
QUOTE (dhromed @ Dec 12 2010, 06:12) *
Linear or logarithmic?
Ceterum censeo, there should be an "%is_stop_after_current%".
dhromed
post Dec 12 2010, 18:18
The spectrogram displays a straight slanted line so I assume linear.
Sunhillow
post Dec 12 2010, 22:38
Group: Members (Donating)
the spectrogram per default has a logarithmic scale, so I assume the sweep is logarithmic
pawelq
post Dec 13 2010, 00:31
The discrepancy of opinions made me check myself. It's logarithmic.
dhromed
post Dec 13 2010, 11:58
Indeed, my mistake. I find no aesthetic merit in the logarithmic scale, and had forgotten I'd set it to linear the very minute I started to use FB, several years ago. In addition to that, I commonly only use sweep to test a narrow bandwitdh of a few thousand Hz. The graph is then indistinguishable from a straight line.
That means I need to redo my listening tests of my ears' (or my equipment's) upper limit. Around halfway through 16KHz and 18KHz doesn't exactly mean 17KHz, though it's perhaps close enough.
Arnold B. Kruege...
post Dec 13 2010, 13:11
QUOTE (dhromed @ Dec 13 2010, 05:58) *
I question using pure sine waves for listening tests on the grounds that spectral masking is a huge influence in the human ear.
Kees de Visser
post Dec 13 2010, 14:09
Post #15
QUOTE (dhromed @ Dec 13 2010, 12:58) *
16, 17 and 18 kHz are roughly a semitone apart, so on the (imaginary) piano they are pretty close smile.gif
dhromed
post Dec 13 2010, 14:21
Post #16
I'm aware of that. Suppose I reach, say, 18KHz, I do not conclude from that that a 16KHz lowpass must sound like crap.
This post has been edited by dhromed: Dec 13 2010, 14:22
RSS Lo-Fi Version Time is now: 25th May 2015 - 05:37
