> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
SDK Compliation Problems, Linker errors in pfc.lib
zzzzzz
post Oct 13 2012, 03:22
Hi, I am trying to set up a test plugin using the SDK in VS2010 in Windows 7.
I have linked to Foobar2000_SDK, Foobar2000_component_client and pfc .vcxproj projects in the References dialogue of my foo_testplugin project. This solved the first set of linker errors. Now I am getting 3 errors in foo_testplugin when linking against pfc:
1>Link:
1>     Creating library ~~~~~~~~~~~~~\FoobarSDK\foobar2000\Debug\foo_testplugin.lib and object ~~~~~~~~~~~~~\\FoobarSDK\foobar2000\Debug\foo_testplugin.exp
1>pfc.lib(string.obj) : error LNK2019: unresolved external symbol __imp__CharLowerW@4 referenced in function "unsigned int __cdecl pfc::charLower(unsigned int)" (?charLower@pfc@@YAII@Z)
1>pfc.lib(string.obj) : error LNK2019: unresolved external symbol __imp__CharUpperW@4 referenced in function "unsigned int __cdecl pfc::charUpper(unsigned int)" (?charUpper@pfc@@YAII@Z)
1>~~~~~~~~~~~~~\\FoobarSDK\foobar2000\Debug\foo_testplugin.dll : fatal error LNK1120: 2 unresolved externals
Any help with these would be greatly appreciated.
Zao
post Oct 13 2012, 12:10
Group: Members (Donating)
CharLower documentation on MSDN mentions which import library to link to (User32.lib) at the bottom.
zzzzzz
post Oct 14 2012, 00:45
Thanks, i added
#pragma comment(lib,"User32.lib")
to the top of string.h in the pfc project and it now compiles
RSS Lo-Fi Version Time is now: 31st August 2014 - 06:05
