Different Grouping Schemes for Playlists
codemati
post Dec 6 2012, 01:12
Hey,
I've been using foobar for a couple years but never really tried to modify the view at all.
I would like to have different grouping schemes for different playlists. I.E. I would like to group my main library by album artist, but group a soundtrack playlist by album. How can I go about this?
On a side note:
When grouping by album artist, some artists are split into multiple groups even though they have the exact same name. Why is this?
morphguy12
post Dec 6 2012, 01:53
Are you using DUI or CUI?
Look into using ELplaylist if you are on CUI and make different panels for each of those groupings.
For the side note,
Highlight them all and look in the tag properties, make sure they are all spelled exactly the same and there are no extra spaces at the end of any of them.
If they are different you'll see: "Multiple Values"... then lists them.
You'll only see a single album artist if they are all exactly the same.
codemati
post Dec 6 2012, 03:21
QUOTE (morphguy12 @ Dec 5 2012, 19:53) *
For the side note,
I'm using the Default User Interface right now. Thanks for the advice, I'll check that out!
I had one more question:
Is it possible to group by artist, and then within those groupings, group by album?
This post has been edited by codemati: Dec 6 2012, 03:22
Daeron
post Dec 6 2012, 05:58
It's also doable with CUI/NG Playlist, you will just need to put a special string to the playlist's title (like '-a-' for albums or whatever) and then go to 'Prefences/Display/CUI/Grouping/doubleclick on your script/show only on playlists' and define a pattern such as '*-a-*'. You can also link specific columns to a playlist similarly.
Alternatively if your soundtrack albums are always tagged with GENRE=Soundtrack, something like this might work (if the GENRE is soundtrack, it writes the value of ALBUM, otherwise ARTIST):
$if($stricmp(%genre%,Soundtrack),%album%,%artist%)
This also relies purely on tags and not on playlist names.
QUOTE (codemati @ Dec 5 2012, 20:21) *
You just have to add two grouping patterns then. The second always ends up 'inside' the first. Though using only one with a pattern such as 'ARTIST / ALBUM' would make more sense in my opinion.
This post has been edited by Daeron: Dec 6 2012, 06:38
RSS Lo-Fi Version Time is now: 23rd November 2014 - 13:25
