2 Pages V   1 2 >
Reasons to switch to EAC from foobar or winamp for ripping., was: "why is EAC the best?"
airtas
post Mar 7 2010, 07:38
I have been using foobar and or winamp with lame to rip my mp3s and flacs.
What benefits do I get from EAC? Is it better error correction? If my cds have no scratches do I need EAC?
Please explain as when I looked into EAC settings I found a 6 page guide on customizing settings, and with winamp everything is auto, am I missing something, quality wise?
Sycraft
post Mar 7 2010, 07:56
More or less EAC seems to do the most through job of checking for errors of any ripper out there. It does this in all kinds of ways like testing the CD-ROM to see how it rips, what kind of errors it can detect and so on, and also by checking against a database. If EAC says your rip is good, it is extremely likely it is good. If there's a problem, like damage to a disc that causes read problems, EAC very often can find a way to compensate for it and still get a good rip.
So it is kind of a quality assurance thing. Rip with EAC, you probably have no problems.
How much does this matter? Hard to say. It partially depends on your discs. If they are in good condition then there is less likely to be any trouble reading them and thus you are more likely to get a good rip regardless. However just because they look ok doesn't mean there isn't damage that you can't easily see with the naked eye. Remember that the pits on a CD are very small, so there could be damage smaller than you can see that still causes problems. It also partially depends on your drive. Some drives do a really good job reading audio CDs, others are very poor at it. So if you have a good drive, you aren't likely to have a problem, but if you don't you may.
As an example with drives back in the day they used to have real problems with accurate seeking. The computer would say "Go read data from this spot," and they'd just kinda go to the general area. That meant to get a good rip you had to have your program compensate for this, read more than it needed to, and correct all the read jitter. As far as I know, drives these days don't have that issue. The one I have doesn't at least. I'll seek accurate to a single sample and start reading again, meaning that no correction needs to be done.
I personally just use EAC because it is free, works well, and is the best way to guarantee a good rip. I probably don't need to, something else would probalby work fine, but since EAC doesn't cost anything, I figure why not?
The reason why this is necessary is that audio CDs don't have as good an error correction as data CDs. You can actually see this in sizes. A normal CD these days holds 700MB of data, or 80 minutes of audio. Well CD audio is 44.1kHz, 16-bit stereo. That equals 172 kilobytes per second, or about 10MB per minute. That means that 80 minutes of audio needs 800MB. So how's that work? Well in data mode that extra 100MB is used up in the additional error correction that is done. In audio mode, it isn't there. As such audio CDs can have errors much easier than data CDs that can't be corrected.
Light-Fire
post Mar 7 2010, 08:14
QUOTE (airtas @ Mar 7 2010, 01:38) *
What benefits do I get from EAC? ...
Use a ripper that check for the AccurateRip database. If it is correct than you don't need to use EAC. Use EAC only if you have problems with your normal ripping software (because the CD is damaged).
EAC forces your CD/DVD drive to work hard, reducing it's life.
This post has been edited by Light-Fire: Mar 7 2010, 08:16
Light-Fire
post Mar 7 2010, 08:18
QUOTE (Sycraft @ Mar 7 2010, 01:56) *
... A normal CD these days holds 700MB of data, or 80 minutes of audio...
There is no such a thing as audio in a CD. The "audio" in the CD is actually data.
westgroveg
post Mar 7 2010, 10:37
QUOTE (Light-Fire @ Mar 7 2010, 20:18) *
Yes there is, "audio data" is recorded differently on CD's, thus why more fits. It's a method of recording & the standard for audio CD's, not that any of this is relevent...
EAC is the best as Sycraft said because you can be very sure, you don't need to rely on a database or anything like that althought you can you don't need to & don't get stuck if your CD isn't listed or the pressing is diffrent or if you have offset issues...
westgroveg
post Mar 7 2010, 10:45
And PlexTools (with Plextor drive) has the best error correction & speed, by far.
What would take EAC hours can be done in minutes, that alone is amazing.
Akkurat
post Mar 7 2010, 11:56
REACT Mod developer
QUOTE (Light-Fire @ Mar 7 2010, 09:14) *
Not in burst mode. Rip in burst mode if you get AccurateRip results, otherwise fall back on secure methods.
Porcus
post Mar 7 2010, 13:58
QUOTE (Light-Fire @ Mar 7 2010, 08:14) *
Then on the other hand, there aren't that many rippers which use AccurateRip. EAC, dBpoweramp (my favourite, from the same developer as AccurateRip itself) and foobar2000 for MS-Windows users. (Edit: And CUERipper?)
Also, the beta version of dBpoweramp release 14 does cross-press verification. Is that into EAC yet? I have not tried it in fb2k, but since it does so in the retro-verification I guess it does so upon ripping too?
QUOTE (Akkurat @ Mar 7 2010, 11:56) *
That's what dBpoweramp (the paid version) does automatically.
This post has been edited by Porcus: Mar 7 2010, 14:00
One day in the Year of the Fox came a time remembered well
Akkurat
post Mar 7 2010, 14:44
REACT Mod developer
QUOTE (Porcus @ Mar 7 2010, 14:58) *
No AFAIK. Personally I've added CUETools (the ArCueDotNet.exe cmd line tool) to do that in my REACT script. Works ok.. and is free. smile.gif
airtas
post Mar 7 2010, 17:24
Why type of errors does EAC prevent?
So If I rip a cd and have errors using foobar, will foobar not tell me? In terms of the translation to sound are errors skips?
Porcus
post Mar 7 2010, 17:39
QUOTE (airtas @ Mar 7 2010, 17:24) *
It detects issues where the so-called C2 pointers flag the read as erroneous. These errors would otherwise go unnoticed. (Note that this relies on the drive reporting these data correctly.)
This post has been edited by Porcus: Mar 7 2010, 17:39
Light-Fire
post Mar 7 2010, 18:13
QUOTE (westgroveg @ Mar 7 2010, 04:37) *
Let's clear up Sycraft misconceptions:
1) The amount of data that fits in a CD is EXACTLY the same. It doesn't matter what type of data you have int it. The maximum capacity of the physical media is always the same (700 Mbyte nowadays)
2) Once more. There is no audio in CDs. Only data. The CD containing PCM data doesn't have an error correction system based on check sum because was never intended to be ripped, so there is no way for the computer to know if the data ripped from the CD is 100% correct of not.
3) EAC (and any other ripper) NEVER knows for sure if got it right. Depending on a data base (AccurateRip) is more likely to give you an accurate result (without destroying your CD/DVD driver). Once your files are ripped in a "modern" type of file (flac, wav, etc.) it is possible for your computer to know (from now on) if that file is corrupted or not, because now you can use checksum to verify it's integrity. Comparing your data with the data that other people got from their different equipment and discs and getting the same results indicate with way more confidence than EAC ripping without AccurateRip that you got it right because if you have an error this error is not likely to be the same as other people have in their CDs so your data will not match anybody's.
Don't take me wrong. I am not against EAC. It is a great tool when you have a damaged CD which rips don't match AccurateRip's data base.
And yes. Using burst mode will not stress your CD driver, but then EAC will be just like any other ripper.
cliveb
post Mar 7 2010, 20:36
WaveRepair developer
QUOTE (Light-Fire @ Mar 7 2010, 17:13) *
If you decide to aggressively correct what someone else has said, you'd better be sure you are right.
An audio format CD stores 2352 bytes of data in every sector. A data format CD stores 2048 bytes of data in every sector. The remaining 304 bytes are divided between addressing data (16 bytes) and additional error detection and correction data (288 bytes). The reason that a data CD has less data and more error correction redundancy is because you absolutely cannot tolerate a single bit in error, whereas unrecoverable errors on an audio CD can usually be masked by interpolation.
In summary, a standard "80 minute" CD can store about 700MB when written in data format, and about 800MB if it is created in audio format.
westgroveg
post Mar 9 2010, 12:27
QUOTE (cliveb @ Mar 8 2010, 08:36) *
Perfect, simple yet technical, you should write some online tutorials :-)
It amazes me someone can write such fiction, Light-Fire I mean.
Light-Fire it's easy, I know you don't care & just want to feel like you have a PHD in BS but do the simple test of extracting the PCM data & then re-writing it as a standard data CD.
Sorry to be an ass but your just wrong.
airtas
post Aug 14 2010, 06:06
Post #15
QUOTE (westgroveg @ Mar 7 2010, 05:37) *
what do you mean by pressing different and what are common offset issues?
spoon
post Aug 14 2010, 13:16
Post #16
dBpowerAMP developer
Group: Developer (Donating)
QUOTE (westgroveg @ Mar 7 2010, 10:37) *
In that case the security of your Rips is much reduced. C2 pointers miss errors, re-reading also misses errors (when the wrong data is re-read the same both tries). This goes for Plextools also, the CD drive its self cannot detect all errors.
Spoon http://www.dbpoweramp.com
airtas
post Sep 5 2010, 22:41
Post #17
QUOTE (spoon @ Aug 14 2010, 08:16) *
what would an error sound like?
pdq
post Sep 6 2010, 00:42
Post #18
QUOTE (airtas @ Sep 5 2010, 17:41) *
It would probably sound like a click or a pop.
bahathir
post Sep 6 2010, 04:36
Post #19
How about cdrdao or cdparanoia ? Are these tools are good compared to EAC ? smile.gif
greynol
post Sep 6 2010, 04:45
Post #20
I bet I'm not the only one here viewing the title of this discussion as problematic.
bahathir, I suggest you familiarize yourself with this forum's search function and work your way back through the archives. These questions have become quite tiresome.
In your pursuit of other discussions, here's a freebie:
http://www.hydrogenaudio.org/forums/index....showtopic=82032
Here is fairly new article in our wiki, but it doesn't seem to be available through navigation at the moment (well at least I can't find it except through a search or it's discussion here in the forum):
http://wiki.hydrogenaudio.org/index.php?ti...n_of_CD_rippers
EDIT: After reading the title one too many times, I finally decided to change it.
This post has been edited by greynol: Sep 8 2010, 07:18
I should publish a list of forum idiots.
bahathir
post Sep 6 2010, 07:18
Post #21
QUOTE (greynol @ Sep 6 2010, 11:45) *
spoon
post Sep 6 2010, 09:30
Post #22
QUOTE (pdq @ Sep 6 2010, 00:42) *
Often the error is just a section of silence as the CD drive has interpolated the error to nothing.
This post has been edited by spoon: Sep 6 2010, 09:30
Engelsstaub
post Sep 6 2010, 09:46
Post #23
QUOTE (greynol @ Sep 5 2010, 22:45) *
Not only is it problematic, but it invites some serious trolling and in-fighting amongst usually civil audio enthusiasts. biggrin.gif
If the poster is just looking for a good reason to use EAC, as greynol has aptly pointed out, many reasons can be found here in HA.
CUETools ripper is a great alternative for those who must have free sw. dBpoweramp, in its current iteration, is a respectable "rival" to EAC (I prefer dBp personally.) ...but you will have to pay a (very fair, IMO) amount for it in its fully-functioning form.
It really comes down to what you think it's worth. My opinion is that EAC and dBpoweramp are both superb secure rippers. dBp's advantage is that it is easier to maintain and a bit more novice-friendly. It is worth the asking price, IMO, for what it lacks in it's cost of personal time. EAC is well-respected around here and it's strong-point is that it's free. They'll both give you great results.
If you just don't care about rip-reports and cue sheets to "recreate" the CD with exact offset, I found that iTunes had a good ripper with the error correction turned on. I never heard a pop, click, or anything in the rips I made with it in the past.
Whatever works for you.
The Loudness War is over. Now it's a hopeless occupation.
greynol
post Sep 6 2010, 20:58
Post #24
QUOTE (spoon @ Sep 6 2010, 01:30) *
Which can also sound like a click or a pop, depending on how much data has been interpolated.
greynol
post Sep 6 2010, 21:02
Post #25
QUOTE (Engelsstaub @ Sep 6 2010, 01:46) *
While I think dBpoweramp has some superior attributes to and refinement over EAC, I do not agree with this idea that it is easier to maintain and is novice-friendly. I once counted the number of settings related to secure ripping and EAC had fewer.
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 19th September 2014 - 12:08
