2 Pages V   1 2 >
Need help with command parameters for FhG AAC
Pulstar
post Nov 1 2012, 18:26
I tried various options but it seems I can't get a "solid" file output. Perhaps someone could help me out with the appropriate parameters for fb2k's converter?
Shadoko
post Nov 1 2012, 20:01
Command Line Encoder Settings - Editing Preset
Encoder: Custom
Encoder file: yourpath\fhgaacenc.exe
Extension: m4a
Parameters: --vbr 4 --ignorelength - %d
lossy
24
A_Man_Eating_Duc...
post Nov 1 2012, 20:08
here you go
EDIT: too slow smile.gif
This post has been edited by A_Man_Eating_Duck: Nov 1 2012, 20:09
Pulstar
post Nov 2 2012, 10:23
1 out of 1 tracks converted with major problems.
Source: "C:\Users\X\Music\sample.mp3"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "C:\Users\X\Music\sample.m4a"
  Additional information:
  Encoder stream format: 44100Hz / 2ch / 32bps
  Command line: "C:\Program Files (x86)\foobar2000\components\fhgaacenc.exe" --vbr 3 --ignorelength - "sample.m4a"
  Working folder: C:\Users\X\Music\
  Conversion failed: The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters
lvqcl
post Nov 2 2012, 15:58
Did you set 'Highest BPS...' setting to 32 instead of 24?
Pulstar
post Nov 2 2012, 16:02
QUOTE (lvqcl @ Nov 2 2012, 16:58) *
Yes, thanks for offering further help. I guess it's something with stdin/stdout.
A_Man_Eating_Duc...
post Nov 2 2012, 20:39
have you got all the required files in the same directory as fhgaacenc.exe?
enc_fhgaac.dll
fhgaacenc.exe
libmp4v2.dll
libsndfile-1.dll
nsutil.dll
Pulstar
post Nov 2 2012, 21:56
Yes! I will try to move the files to another directory, but I don't think it's a permissions problem since I have UAC disabled.
A_Man_Eating_Duc...
post Nov 2 2012, 22:49
don't forget this bit
Install VC2008 runtime if you don't have yet
http://www.microsoft.com/downloads/details...0D-3802B2AF5FC2
Pulstar
post Nov 3 2012, 10:38
I have all the runtimes hehe.. I guess I will have to use the command prompt to encode the files. Thanks for everyone who pitched in.
This post has been edited by Pulstar: Nov 3 2012, 10:39
A_Man_Eating_Duc...
post Nov 3 2012, 23:12
Try running the command line manually from the CMD prompt and see if it works.
Pulstar
post Nov 4 2012, 20:59
I've switched to QAAC now, and it works nicely. However there's a new quirkiness: The capital V switch for True VBR doesn't function unless I write it like so e.g. -V90 if I write it -V 90 it just defaults to its, er default value. Too bad Nero seems to be discontinued, I liked it, but it's time to move on.
nu774
post Nov 5 2012, 06:25
QUOTE (Pulstar @ Nov 5 2012, 04:59) *
Not reproducing here. Please show me console message of fb2k.
Pulstar
post Nov 6 2012, 16:29
I don't get an error message, but the resultant files are always the same size regardless of the TVBR switch value, unless I write it concatenated.
nu774
post Nov 7 2012, 01:18
Post #15
QUOTE (Pulstar @ Nov 7 2012, 00:29) *
Strange. Version of qaac? And I'd like to know exact command line which should be printed in the console of fb2k (view->console).
Also, try it from directly command line. qaac will show something like the following by which you should know if TVBR quality value is misinterpreted.
AAC-LC Encoder, TVBR q63, Quality 96
Although you can specify 0-127, it is rounded to the nearest available value. In case you specify 60, you will get 63.
Pulstar
post Nov 8 2012, 23:47
Post #16
Hmmm it seems that spaces in the path screw up the V switch for me, no big deal. Just tested this with a sample on the root folder, and the resultant file sizes are similar. Thanks for the help smile.gif
nu774
post Nov 9 2012, 10:53
Post #17
QUOTE (Pulstar @ Nov 9 2012, 07:47) *
Whiltespace in the pathname of input file has nothing to do with space in "-V 91" (or something).
They are completely different things.
  1. Pathname of input has nothing to do with a CLI encoder. It's fb2k who opens it and decodes it. fb2k then feeds decoded audio to the encoder via pipe or temporary file.
  2. Also you don't have to care about pathname of output (placeholder %d) . fb2k will take care of it for you so that even a CLI encoder which doesn't handle Unicode pathnames will work.
  3. Command line parser of qaac is based on BSD getopt (modified to handle Unciode), and capable of both "-V91" and "-V 91" style (for short options).
"Similar size" of resultant files doesn't prove nothing. If you are using fb2k, just open up property dialog for the song, and look at "tool" tag information. You can see VBR quality or something. Alternatively, you can use tools like Mediainfo.
botface
post Nov 8 2013, 13:25
Post #18
I've recently installed Win 7 (Pro 64) and am trying to get everything set up but I'm having problems getting FB2K to work with the Fhg AAC encoder.
FB2K is set up as per A_Man_Eating's example in Post 3.
enc_fhgaac.dll, fhgaacenc.exe, libmp4v2.dll, libsndfile-1.dll & nsutil.dll are in the same folder. But I'm getting exactly the error that Pulstar reported in Post 4. As it's a fresh install I assume it won't be related to VC2008 runtime.
Can anybody help?
lvqcl
post Nov 8 2013, 15:45
Post #19
QUOTE (botface @ Nov 8 2013, 16:25) *
I don't understand this part of your post. Did you install VS2008 runtime?
botface
post Nov 8 2013, 20:22
Post #20
I assumed it would be included but just in case I downloaded and installed it. No change. Same error message
eahm
post Nov 8 2013, 20:36
Post #21
botface, can you please try with my "encoder pack" to see if you have the same error? http://dropcanvas.com/x732m (I removed foobar2000 from the package so now it's should be ok to post it here).
This post has been edited by eahm: Nov 8 2013, 20:36
/lwAsIimz
botface
post Nov 9 2013, 15:11
Post #22
I tried your fhgaacenc.exe. Same error
lvqcl
post Nov 9 2013, 16:30
Post #23
Did you install x86 or x64 version of VS2008 runtime?
botface
post Nov 9 2013, 19:54
Post #24
QUOTE (lvqcl @ Nov 9 2013, 15:30) *
X86. Do I need the X64 version as I'm using a 64bit OS?
lvqcl
post Nov 9 2013, 20:08
Post #25
No, x86 is the correct version.
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 21st August 2014 - 17:43
