13 Pages V  « < 5 6 7 8 9 > »
GAPLESS Playback now in iPods - New!, Apple just announced today! GAPLESS playback...!
hit_ny
post Sep 14 2006, 19:10
Post #151
And it this gapless info passes the diskwriter test ?
ie..compared WAVs are identical
This post has been edited by hit_ny: Sep 14 2006, 19:13
Maurits
post Sep 14 2006, 19:12
Post #152
QUOTE (greynol @ Sep 14 2006, 18:54) *
QUOTE (grommet @ Sep 14 2006, 10:30) *
It will not modify your existing MP3 files with these extra tags. (It didn't touch any of my LAME MP3 content.)
I just verified this with my iPod's LAME MP3 content.
That's odd compared to this users statement:
http://www.hydrogenaudio.org/forums/index....8231&st=29# blink.gif
Edit: Or not.
I suppose tags are only written if iTunes had to analyse the encoder delay/padding itself. The values it finds are then stored in an ID3-tag. If iTunes could just rely on the data already in the MP3-info header put there by LAME it skips writing the tag because the data is already in the file.
This post has been edited by Maurits: Sep 14 2006, 19:21
guruboolez
post Sep 14 2006, 19:16
Post #153
Group: Members (Donating)
QUOTE (hit_ny @ Sep 14 2006, 19:57) *
In fact someone just said they noticed very slight changes, that is proof enough for me that this is a best effort with mp3 that is not a gaples format to start with.
The workaround is to use CUE.
And what about fixing the existing problem instead of jumping to another shaky solution like cuesheet?
MPC had the same issue: small glitchs on transition. An updated encoder fixed this issue and there's no complaint anymore.
Cuesheet is nice, but it supposes that you must upload to your iPod the full album, and that you can't delete from it some annoying tracks and to keep the most enjoying ones. Moreover, cuesheet doesn't work well with MP3-VBR. foobar2000 did it well, but this makes MP3 seeking much slower, even on 3GHz CPU... so let imagine the issue on a small iPod.
hit_ny
post Sep 14 2006, 19:19
Post #154
Sure but the beauty of cue sheet is it will play gapless on even the simplest mp3 player, or every mp3 player.
The only issue is you can't see the track names if the player is not equipped for this. Mjor issue on portable players but the sound is ok.
vs...gapless info with LAME header which only works with the right player & if it was encoded with this info in the first place.
Also the problem with a few bad tracks, well dont play the album then right smile.gif
If its a gapless album to start with and you cut tracks off that are mixed in, the transition is sure to be jarring either way.
Regarding speed for seeking, i'm inclined to think its more of a HD issue than a CPU issue, the bottle neck is how fast it can read off the HD.
This post has been edited by hit_ny: Sep 14 2006, 19:30
greynol
post Sep 14 2006, 19:26
Post #155
QUOTE (Maurits @ Sep 14 2006, 11:12) *
I just pulled a track from my ipod and looked at it with a hex editor. The file is exactly the same as it was before I put it on my iPod using iTunes. iTunes has never written anything to this file.
(Still lots of talk about gapless playback with iTunes and very little about gapless playback on iPods)
Bingo!
Placebophiles: put up or shut up!
kincaid
post Sep 14 2006, 19:29
Post #156
QUOTE (greynol @ Sep 14 2006, 11:26) *
Bingo!
iTunes only adds the tag to a track which IT encodes.
greynol
post Sep 14 2006, 19:30
Post #157
@hit_ny, quit trolling with the off-topic nonsense.
hit_ny
post Sep 14 2006, 19:34
Post #158
My intention is not to troll, i noticed the title gapless playback and stated my opinion on the topic.
If you want gapless, Apple's implementation is close but no cigar.
It's the only issue preventing me from getting an iPod atm.
This post has been edited by hit_ny: Sep 14 2006, 19:38
greynol
post Sep 14 2006, 19:39
Post #159
QUOTE (hit_ny @ Sep 14 2006, 11:34) *
And this thing that isn't a cigar, is this fact or also your stated opinion?
hit_ny
post Sep 14 2006, 19:41
Post #160
Diskwriter test...
yes or no ?
I've yet to read about it.
record ouput from the iPod to WAV doing its "gapless" thing
This post has been edited by hit_ny: Sep 14 2006, 19:46
Maurits
post Sep 14 2006, 19:46
Post #161
QUOTE (kincaid @ Sep 14 2006, 19:29) *
Bingo!
Hhmm... I had my doubts about that and did a check. So far you seem right.
Where does iTunes store the values then? In the database? I suppose that makes sense because that's where the iPod needs the values as well since it won't read the tags on the files. Anyone notice any changes to the database structure?
This post has been edited by Maurits: Sep 14 2006, 19:47
grommet
post Sep 14 2006, 19:56
Post #162
QUOTE (Maurits @ Sep 14 2006, 11:46) *
Yes, that's in the database... that's what iTunes does when it does the long/painful initial "gapless scan."
Maurits
post Sep 14 2006, 20:11
Post #163
QUOTE (grommet @ Sep 14 2006, 19:56) *
It is a bit odd to store the results of gain-level analysis in the metadata but not the results of gap-analysis though. huh.gif
Gabriel
post Sep 14 2006, 22:32
Post #164
LAME developer
QUOTE (kincaid @ Sep 14 2006, 20:29) *
Bill, could you please confirm if iTunes is using the gapless info provided by Lame, as it seems?
(btw welcome here)
Maurits
post Sep 14 2006, 23:01
Post #165
Ouch! Seems I questioned a statement I shouldn't have questioned. Sorry.
Big Fella
post Sep 15 2006, 05:47
Post #166
I have a 5th gen video ipod and the gapless playback is not on the player only via itunes, as far as I can see this was apples intnetion as they have also timed this with the release of the new updated 5th gen 30 and 80g which has longer battery life and .........gapless playback.
Dissapopinted that they have seen a niche and sought to exploit it, but hey ho we live in a world of captialism.
Has anyone on here actually experienced gapless playback on their ipod when it is not played thorugh itunes?
My music is set to gapless playback, have also ripped the odd cd again to see if this makes a difference or not, which it did not.
Oh and hello all, been a lurker for some time, just thought i'd interject with my experience.
grommet
post Sep 15 2006, 05:50
Post #167
Big Fella, did you upgrade your firmware? That should bring it to parity with the updated 5G.
Big Fella
post Sep 15 2006, 06:00
Post #168
Doh!! Yeah just figured that in a moment of clarity, all is good now.
Canar
post Sep 15 2006, 13:47
Post #169
QUOTE (Maurits @ Sep 14 2006, 06:14) *
What did you test and how?
LAME -aps encoded MP3s, in which I ended up with noticable gaps.
LAME -aps encoded MP3s split with pcutmp3. This most definitely writes LAME header information, which iTunes promptly ignored.
I've successfully got gapless working with ALAC ripped by iTunes itself, but that seems to be the one instance where it's working without issue on my 5G 60GB iPod Video. Nero AAC is intermittent.
You cannot ABX the rustling of jimmies.
No mouse? No problem.
kincaid
post Sep 15 2006, 17:50
Post #170
QUOTE (Gabriel @ Sep 14 2006, 14:32) *
(btw welcome here)
Thanks, Gabriel. Yes, iTunes does use LAME's gapless info (after some sanity checks).
John Lockwood
post Sep 15 2006, 18:33
Post #171
QUOTE (AtaqueEG @ Sep 14 2006, 16:40) *
QUOTE (rontonic @ Sep 14 2006, 10:34) *
So I got iTunes 7 today, installed and plugged in my iPod with 3750 songs. It has now been doing that "Gathering information about gapless playback" for many many hours, and it is only about half way! How can I stop this??!! And what the h... is it really doing?
Computer specs and encoder settings of the file?
I tried it yesterday, with a library of roughly 4000 LAME 3.97 files on a P4 1.5 GHZ and it took about 40 minutes!
Ah ha! I think I now know why iTunes 7 did not show this "Gathering information about gapless playback" when I upgraded (or it disappeared so quick I did not notice). All (100%) of my tracks are in Apple Lossless, it appears that for Apple Lossless (and highly likely iTunes encoded AAC) this process is not necessary but is necessary for LAME / MP3 tracks.
Admittedly I have only ripped about 600 tracks so far but based on other peoples reports of it taking hours to scan I think this is the answer.
kincaid
post Sep 15 2006, 19:26
Post #172
[/quote]
[/quote]
Correct. The scan is also required for store files. The scan is particularly slow for VBR MP3 files because of the need to decode the whole file to get an accurate sample count.
smiler
post Sep 15 2006, 22:37
Post #173
I couldn't wait to try out this feature, but when I installed iTunes 7, I noticed a distinct lack of "Gathering information about gapless playback". My entire collection is Nero AAC (as it's been converted, via foobar2000 from FLAC and high bit-rate MP3 or MPC purely for my iPod).
I'm a little disapointed that iTunes didn't even try...
What's the feasibility of a 3rd party app 'converting' Nero AAC gapless data into iTunes gapless data?
It definately hasn't worked: I even tested with Dark Side of the Moon, just as Apple suggested happy.gif.
This post has been edited by smiler: Sep 15 2006, 22:40
Maurits
post Sep 16 2006, 10:15
Post #174
QUOTE (kincaid @ Sep 15 2006, 17:50) *
(btw welcome here)
Thanks for the confirmation and the great work on this all together. smile.gif
This post has been edited by Maurits: Sep 16 2006, 10:15
Canar
post Sep 16 2006, 15:31
Post #175
iTunes does, yes. However, for some reason, this isn't translating over to gapless playback on my iPod...
RSS Lo-Fi Version Time is now: 24th July 2014 - 15:43
