IPB
direct recording from live streams
PhilDC
post May 20 2007, 19:09
Post #1
Group: Members
hello, I'm new to this forum so first time greetings biggrin.gif and I hope someone can proffer some advice in my direction regarding a problem I have been trying to solve all afternoon. I run AbletonLive 6.0.3 and Soundforge amongst other music software and I'm having trouble recording live and direct from the internet. I'm wondering if my soundcard (very basic laptop Sigma jobbie) cannot do this task for me - when I go into volume controls and recording options I only have 2 options Mic and Line In ... all I want to do is record what is coming through my speakers - I'm sure I could do this on my old PC !! ... Thanks in advance for any help sent this way
Go to the top of the page
+Quote Post
eevan
post May 20 2007, 20:12
Post #2
Group: Members
Hellp PhilDC,
you could use the streamripper for capturing mp3, aac and ogg streams. You can download the winamp plugin (if you use it) or cli tool.
There is a tool for capturing wave out, but it's not free. It's called Total Recorder
+Quote Post
PhilDC
post May 20 2007, 20:35
Post #3
Group: Members
QUOTE (eevan @ May 20 2007, 20:12) *
Thanks very much for your advice eevan and for the welcome .. the Total Recorder software looks custom made for the job - it may be my best option ... on my old PC, I was able to record straight to Soundforge I'm sure, in my recording options I used to have 4 or 5 faders, now I only have two - Mic and Line In - before I only had to open up the WAV fader to enable recording to hard drive so I'm sure a more simple solution exists .. just a case of finding it ... thanks again
+Quote Post
eevan
post May 20 2007, 21:17
Post #4
Group: Members
Well, the recording of "What U Hear" as the Creative is calling it is not supported on all devices. I don't know what's the sound hardware in your laptop, but try to update the driver. It seems that you have to use the software solutions.
Cheers
+Quote Post
Nikaki
post May 21 2007, 04:23
Post #5
Group: Members
Recording the "what you hear" or "stereo mix" form the sound card is not recommended, because if you encode that, you're actually transcoding or re-encoding.
It's better to "rip" the stream as-is (bit-perfect recording). I know Winamp can do this with at least MP3 and Ogg Vorbis:
For MP3: CTRL+P -> Plug-ins -> Input -> Nullsoft MPEG Audio Decoder -> "Streaming" tab -> "Save files to:" checkbox.
For Vorbis: CTRL+P -> Plug-ins -> Input -> Nullsoft Vorbis Decoder -> "Streaming" tab -> "Save streamed files to:" checkbox
+Quote Post
AndyH-ha
post May 21 2007, 04:34
Post #6
Group: Members
Just to cover what may or may not be obvious.
The Windows mixer usually defaults to showing the playback controls, so one has to select Properties, under Options, in order to tell it to display the recording controls. On that page, at the bottom, is usually a window where one checks the particular controls to be displayed. No control without a check mark will appear on the mixer.
In order to play, an stream has to be decoded. If one selects that input and records to an uncompressed format (usually WAV), then no transcoding or re-encoding is occurring.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 29th January 2015 - 08:31
