EAC profile - Error message, The profile belongs to a different version of EAC and cannot be loaded
daven
post Nov 20 2012, 18:11
Hi everyone,
I am using EAC V1.0 beta 3 and had created a profile using this version. I recently had a major O/S issue which resulted in a reinstall (its XP SP3) and am slowly getting my software back up and running.
EAC did not require a reinstall but it had lost my profile. I can see the profile out on the C: drive and can find it when I access the EAC>Profiles>Load Profile option. However, when I try to load the profile I get the error message which says "The profile belongs to a different version of EAC and cannot be loaded".
Is there any fix for this or have I got to start from scratch again?
Thanks,
Dave
Cynic
post Nov 20 2012, 18:45
Are you trying to load the profile from Application Data\EAC\Profiles or from the Profiles folder in the installation directory (typically C:\Program Files\Exact Audio Copy)? Try the former if you haven't yet.
EDIT: Nevermind, I've only now noticed that you had to reinstall XP, that certainly wiped out all user settings from the Application Data folder.
This post has been edited by Cynic: Nov 20 2012, 18:51
daven
post Nov 20 2012, 23:03
QUOTE (Cynic @ Nov 20 2012, 09:45) *
Yep - Application Data is gone.
Meanwhile as an update, I find that the .cfg file that is under C:\Program Files\Exact Audio Copy starts with "EACV0991" when I open it in Notepad. I am wondering if somehow EAC thinks its an older version even though it was created in the new version.
This post has been edited by daven: Nov 20 2012, 23:15
korth
post Nov 21 2012, 00:23
V1.0 beta 3 creates cfg with E A C V 1 0 0 0. Looks like that one was created with one of V0.99 builds.
This post has been edited by korth: Nov 21 2012, 00:26
korth
daven
post Nov 21 2012, 04:30
QUOTE (korth @ Nov 20 2012, 15:23) *
So, Korth, no way to "upgrade" this profile to one that could be used in V1.0 beta 3?
korth
post Nov 21 2012, 05:34
From the EAC website describing a fix for a different problem:
If you need your old profiles, it would be best to install the new version side by side with the old version. Then load a profile with the old version and close the program. Open the new version and save the appropriate options
Don't forget to check the compression options and placeholders.
korth
RSS Lo-Fi Version Time is now: 1st August 2014 - 18:44
