IPB
MP3 main data pointer:, main data pointer points between 36 bytes of header and side info
Ravi
post Jun 10 2009, 19:37
Post #1
Group: Members
Hi All,
I am facing a new problem while decoding the Mp3 frames. My main data pointer of few frames is pointing to back in between the "header+side info" of the previous frames. for example:
Lets assume a frame starts at byte 4086 of Mp3 file.
So the header of the frame will end at byte (4086 + 4 =) 4090
and if side info is 32 bytes the side info will end at (4090 + 32 =) 4122.
So the header + side info for this frame lies between 4086 to 4122
Assume that the length of the frame is 418 bytes. So the next frame will start from (4086 + 418 =) 4514
Now in the new frame starting from 4514th byte the main data begin value indicated by first 9 bits of side info is 410.
This means that the main data will start from the byte number 4514 - 410 = 4104th byte which is in between 4086 to 4122( the range of header + side info of previous frame)
Is there a possibility of such case? (I think answer of this question is yes as I am facing it in a file).
Another question is that if such case can happen then how to deal with it?
Thanks in Advance
-R/\\/I-
Go to the top of the page
+Quote Post
Ravi
post Jun 10 2009, 19:41
Post #2
Group: Members
There is one calculation wrong above so I added this as a reply to correct it. All correction are marked by *.
Assume that the length of the frame is 418 bytes. So the next frame will start from (4086 + 418 =) 4504*
Now in the new frame starting from 4504th byte the main data begin value indicated by first 9 bits of side info is 410.
This means that the main data will start from the byte number 4504* - 410 = 4094*th byte which is in between 4086 to 4122( the range of header + side info of previous frame)
Thanks in Advance
-R/\\/I-
+Quote Post
SebastianG
post Jun 16 2009, 19:18
Post #3
Group: Developer
QUOTE (Ravi @ Jun 10 2009, 19:41) *
You are supposed to buffer the main data bits separately from the header and the side info block. Create a FIFO of size 511+max_frame_size and fill it with main data bits only. Use that buffer for decoding the main data bits.
Cheers!
SG
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 23rd July 2014 - 08:52
