2 Pages V   1 2 >
iTunes Encodes vs. Amazon (Spectrograms), Spectograms.
Engelsstaub
post May 14 2012, 02:39
A spectral comparison of an iTunes file and its counterpart from Amazon:
Fear Factory - Recharger (Single) iTunes/m4a
Fear Factory - Recharger (Single) Amazon/mp3
I understand a spectrogram tells us pretty close to nothing about how a music file actually sounds to the listener. I still challenge anyone to find results that are reversed. I never have. (I get "credits," like many others, for Amazon mp3s. I download the iTunes versions as an iTunes Match subscriber.)
At this bitrate I personally doubt listeners will discern between the two. Does this discount the validity of saying one encode is of a "higher quality" or that it is "better" in that it retains more of the source? These graphs can still tell us "what is missing" and what the respective encoders saw fit to lose in lossy encoding.
Thoughts...
This post has been edited by Engelsstaub: May 14 2012, 02:44
The Loudness War is over. Now it's a hopeless occupation.
Gentoo64
post May 14 2012, 03:01
I think anyone would prefer a higher bitrate purely for peace of mind, weather you think you can hear a difference or not.
On my computer I only listen to FLAC, but I can't hear a difference between that and a high bitrate MP3 afaik but it's good to know that you're not losing any quality.
For a portable device if you're going to be out and about I guess it wouldn't matter as much. I personally don't use a portable player but if I did I wouldn't bee too fussy, but sitting at home listening I would want the best specced music so I know I'm not missing out on anything.
But if the music is more full in the spectrogram and closer to the original piece than another version, then it is higher quality.
This post has been edited by Gentoo64: May 14 2012, 03:02
onkl
post May 14 2012, 04:10
First of all, if you can't hear tones above 20khz, then this would be "useless" information to begin with. Second, removing this and using the bitrate purely for the "usefull" information seems to be more efficient.
I don't know how AAC works in this regard, but I guess the resulting file could be slightly smaller with the high frequencies removed, so a lowpass would be desirable for maximum efficiency. For MP3 this could potentially improve the quality when close to the maximum frame size (320kbit + bit reservoir), IIRC there has been someone posting an ABX proving this in a previous discussion about worst case scenarios. (Here it is, was about maximizing frame sizes to improve quality. Reducing the actual information that has to fit into a single frame could lead to the same improvement.)
This post has been edited by onkl: May 14 2012, 04:21
saratoga
post May 14 2012, 04:12
QUOTE (Engelsstaub @ May 13 2012, 21:39) *
Yes, its still a meaningless test.
No. All they show you is what the lowpass filter used to preprocess the PCM was set to.
Thoughts...
Don't we have a FAQ entry for this kind of thing? I feel like we must its asked constantly.
Edit: Yes, took me a minute to find it though. See the entry here and the links:
http://wiki.hydrogenaudio.org/index.php?ti...dio_Compression
This post has been edited by saratoga: May 14 2012, 04:18
greynol
post May 14 2012, 04:48
QUOTE (Gentoo64 @ May 13 2012, 19:01) *
One only needs to play with the blade encoder in order to dismiss the idea that a full spectrum means higher quality as rubbish and nonsense. In terms of "closer to the original" you need to define it, at which point the best you can possibly do is a truism which isn't very interesting.
This post has been edited by greynol: May 14 2012, 22:23
Engelsstaub
post May 14 2012, 05:01
QUOTE (saratoga @ May 13 2012, 22:12) *
Thoughts...
If you don't want to participate in a discussion, feel free not to.
Engelsstaub
post May 14 2012, 05:06
QUOTE (onkl @ May 13 2012, 22:10) *
That's a good point, Onkl. I'm no expert, but I'm seeing frequencies below this being cut off. The average bitrate for the Amazon encode is seemingly higher.
FWIW I've seen similar results from CBR MP3s @320 Kbps from Zune Marketplace.
eahm
post May 14 2012, 05:19
QUOTE (onkl @ May 13 2012, 20:10) *
OT: Actually both my brothers can up to 23khz, don't know how but they can.
saratoga
post May 14 2012, 05:21
QUOTE (Engelsstaub @ May 14 2012, 00:01) *
Thoughts...
You should begin by reading that link. Then if you still have questions, ask here.
But no sense explaining something here that's already explained better elsewhere. smile.gif
Engelsstaub
post May 14 2012, 05:43
Okay, Saratoga. I said: "These graphs can still tell us "what is missing" and you said: "No. (Emphasis mine.) All they show you is what the lowpass filter used to preprocess the PCM was set to."
I'm seeing that one encode is missing nearly everything above 19 kHz. That sure seems to demonstrate that the spectrogram is showing me something that is missing.
(...and I never said I was "hearing" it.) What exactly do I need to read that refutes this?
Even if I drill down to this link HA I'm beginning with reading this: "Lossy compression is a form of compression that significantly reduce multimedia file size by throwing away information imperceptible to humans." If this is true than I believe Amazon's encoder is taking some extreme liberties with what it "thinks" is imperceptible to humans. eahm's brothers aside, it doesn't take some extraordinary ear to hear frequencies that were discarded in the mp3.
Edit: improper wording.
This post has been edited by Engelsstaub: May 14 2012, 05:46
saratoga
post May 14 2012, 06:00
QUOTE (Engelsstaub @ May 14 2012, 00:43) *
If they could tell you what was missing, then you would probably conclude your AAC file is lossless. Not so, much that is missing is not shown.
Instead, what they show is what the lowpass filter setting was that was used to preprocess the signal before it was encoded.
Hearing music -40dB below peak at 19kHz would in fact be quite extraordinary! I think even a pure tone would be extremely impressive, and certainly beyond my hearing.
Canar
post May 14 2012, 06:30
QUOTE (Engelsstaub @ May 13 2012, 21:43) *
According to the Terms of Service, to continue this discussion, you must provide scientific evidence that you do, indeed, hear said difference if you wish to claim that you can. It may seem counterintuitive that something you can see is not necessarily something you can hear, but that is pure illusion.
saratoga's position mirrors that of mine as a moderator.
2. Assume good faith.
onkl
post May 14 2012, 06:40
QUOTE (Engelsstaub @ May 14 2012, 06:06) *
The difference in bitrate is due to completly different formats/encoders. If you were to encode the same file with everything but the lowpass being identical, you would see a decrease in bitrate OR an increase in quality for hard to encode passages hitting the frame limit OR in case of exceptional hearing capabilites you might notice the absence of higher frequencies.
Try this test and then redo it with music playing in the background. You might be supprised how hard it is to hear anything above 16khz.
saratoga
post May 14 2012, 07:29
Someone should add a feature to LAME that subtracts the input and lowpass PCM samples, and then uses the difference to guide the quantizer such that it adds noise with vaguely similar power spectrum to bands above the lowpass cut off (but of course chooses the signal such that it is compressible with little bitrate overhead).
Would be very useful for companies like amazon that sell MP3s to people biggrin.gif
Engelsstaub
post May 14 2012, 07:51
Post #15
Canar: I never claimed anything regarding my personal hearing. In fact if you read the entire thread I state more than once that I'm not personally claiming to hear any difference in these files at this bitrate. I said that which Amazon's encoder saw fit to throw out was within the range of human hearing. I see things below that 20 kHz getting completely thrown out. If I worded something poorly then please try to see it in the context of that which I've stated again and again.
I'm basically trying to figure out how to interpret spectrograms. If those frequencies are still there and my program is "lying" to me, then I'd really like to know.
Saratoga: is there any particular reason I have to read everything on HA and you can't just give me a direct link to something that tells me why your answer would be no to "these graphs can still tell us what is missing?" You want me to "keep reading past that link." Read what? What am I missing here that you can't be bothered to reiterate?
Just asking simple questions. If you don't want to discuss it then don't. Give me a specific link to what you'd like me to consider or let someone else discuss it with me.
Onkl: I see what you're saying. I know I can't hear the stuff that was cut off of in the mp3 file. My point is only that it is gone and I am just wondering if that was more significant than whatever lossy reduction the iTunes encoder performed? Or maybe: "which file theoretically would better represent the source to all humans?"
Engelsstaub
post May 14 2012, 07:56
Post #16
QUOTE (saratoga @ May 14 2012, 01:29) *
Oh, now you're funny too. I can get that this discussion is too far beneath you because you're a dev or whatever. Why do you still bother to dignify people with less knowledge than you about certain subjects?
Just close the thread if you want, Canar. There's just way too many flaming dickheads on here to have a constructive conversation at my level. I should have known better.
saratoga
post May 14 2012, 08:09
Post #17
QUOTE (Engelsstaub @ May 14 2012, 02:56) *
I'll try this one more time. The answer to this question:
Is this:
QUOTE (saratoga @ May 13 2012, 23:12) *
or this:
Nothing can be said about quality or audible difference by looking at pictures
You should look at those graphs and be able to read the low pass settings used to preprocess the PCM. Also, maybe guess the sampling rate, but that should be obvious I think. There is nothing else to interpret. Nothing else is contained in those pictures.
QUOTE ( @ May 14 2012, 02:56) *
Don't insult me for because you didn't get the answer you wanted. I only offered you an honest answer. If you're not interested in learning new things, you should not be asking questions.
db1989
post May 14 2012, 08:49
Post #18
QUOTE (Engelsstaub @ May 14 2012, 07:51) *
OK, so the lowpass is at 19 kHz rather than 20 kHz. What now? The point is still that most people will not hear any such frequencies at anything near a ‘normal’ SPL, even as a pure tone—and especially not as part of complex music with content that runs the gamut of all lower frequencies.
No, they’re not there. Why would a program lie? But again: Chances are you and almost every other human in the world cannot hear them, so removing them might actually improve perceptual quality (or, at higher bitrates, the theoretical probability thereof, since both lowpassed and non-lowpassed encodes might be transparent and thus indistinguishable) by sparing bits for lower and more probably audible frequencies, rather than reducing it as you appear to be inferring from a simplistic visual summary.
Whilst I cannot presume to speak for “all humans”, perceptual technologies such as lossy audio compression are not aimed at that amorphous group. They’re aimed at most humans. Otherwise, nothing would ever advance due to encoders being too nervous to excise anything for fear of that one mythical golden-eared sage.
This post has been edited by db1989: May 14 2012, 08:50
Porcus
post May 14 2012, 09:17
Post #19
Is this low-pass thing an AAC vs MP3 difference, rather than 'iTunes' vs 'Amazon'?
LithosZA
post May 14 2012, 09:41
Post #20
Encoding stuff above 20Khz is dumb especially for lossy encodings. You are wasting good bits that are better used for stuff you can hear instead.
The lossy encoding will sound better if you do a lowpass at 20Khz or slightly higher/lower.
For lossless I would say keep whatever frequencies you want even if you can't hear them for peace of mind.
db1989
post May 14 2012, 09:50
Post #21
QUOTE (LithosZA @ May 14 2012, 09:41) *
I’d say “Well, of course!”, but then there are tools like lossyWAV et al., which some users like to apply before ‘lossless’ compression; lowpassing beforehand doesn’t seem so different. I would do neither, but that’s me being a literalist when it comes to lossless-ness. wink.gif
onkl
post May 14 2012, 10:11
Post #22
QUOTE (LithosZA @ May 14 2012, 10:41) *
Well that would be a too bold generalization of a rather theoretically worst case scenario. I'm not even sure these frame size limitations apply to AAC aswell. But it would certainly lower the required bitrate and thus increase efficiency.
QUOTE (db1989 @ May 14 2012, 09:49) *
pdq
post May 14 2012, 11:54
Post #23
All right, let me try my hand at an analogy.
Two patrons walk into a restaurant. Patron A is known to be a very generous tipper, while patron B is just an average tipper. They both sit down and order a meal, but both patrons have exactly the same amount to spend.
Patron A orders a hamburger and a coke, leaving enough to cover a very generous tip. Patron B, however, orders a steak and a glass of wine.
After they leave, someone wonders who had the higher quality meal. Looking only at the size of the tip, he concludes that patron A must have had the better meal.
The bottom line is, you can choose any metric you like for judging quality, but if you choose the wrong metric then you may not get the answer you want.
Porcus
post May 14 2012, 11:58
Post #24
Just because there are high frequencies, it does not mean that they are the same as in the original. At least theoretically, it could simply be that one of the basis vectors decodes to a signal with high frequency content. Not faithful in the sense that it is precisely the same high-frequency content as the original signal, but at least those listeners (if any) which can hear that high, will get a comparable tonal balance. Or whatever. As long as it isn't too loud, it probably isn't worse than silence, and it wouldn't cost any bits. (Too dumb example: if you choose a square wave as basis rather than a sine wave, you will automatically get high frequency content.)
Old days' organ makers employed a few tricks up in the treble, for e.g. 'reed' type sound. To make the sound somewhat brighter, you would use a pipe for the overtones. Of course in the far treble end, you would have to make a pipe for a hardly-audible frequency. IIRC, there are quite some where they would save on the number of 'overtone' pipes at the extreme of the range. They would strictly speaking be disharmonic, but on the other hand, leaving them out would yield a sudden discontinuity in the tonal balance, and (by the organ maker's ear) that was more important – the disharmony was hardly anything the listeners would care about.
This post has been edited by Porcus: May 14 2012, 12:00
2Bdecided
Post #25
ReplayGain developer
One has a ~19kHz low passs filter, the other doesn't.
You can't read much else useful from these pictures...
The temporal resolution of those pictures is about half a second (1 pixel = 400ms). The temporal resolution of the human ear is about 5ms at best due to temporal masking, and 0.011ms at best when detecting interaural time delays. So most of the interesting, audible and relevant details are lost in those pictures.
The amplitude resolution of those pictures is something like 10dB - at least my eyes struggle to see a change any smaller than about 10dB on the colour scale. Whereas human ears can, at best, detect a 1dB change. So again, most audible changes are basically invisible in those pictures.
A to-the-nearest-10dB snapshot of the spectrum, taken only twice each second - it still tells you a lot of course, but it also tells you nothing useful when comparing two almost identical files. In fact, it can perfectly hide many extremely audible differences. While clearly showing you some inaudible ones!
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 28th May 2015 - 07:48
