7 Pages V   1 2 3 > »
FLAC 1.1.3 beta1 available
jcoalson
post Oct 10 2006, 17:18
FLAC Developer
The first (and hopefully only) beta for FLAC 1.1.3 is ready. Usually I don't do betas but there are a lot of new things. See the changelog.
One thing that I'm pretty sure will come up is how flac handles legacy WAVEFORMATEX files with odd bit depths (WAVEFORMATEXTENSIBLE should work fine) and multi-channel files. if you have WAVE or AIFF files that flac refuses, let me know here so I can zero in on how to handle the wierd ones. Any other feedback is also welcome.
You can get the source tarball, or binaries for windows:
http://prdownloads.sourceforge.net/flac/fl...tar.gz?download
http://prdownloads.sourceforge.net/flac/fl...in.zip?download
(or)
http://sourceforge.net/project/showfiles.php?group_id=13478
MD5's:
2f305538a17e35d8153a34423c508dbf  flac-1.1.3-beta1-devel-win.zip
6d43afc5a44015d8fa13fcd6767b1e25  flac-1.1.3-beta1-win.zip
c97c0d35c6193952c2e516f062d3e15d  flac-1.1.3-beta1.tar.gz
Axon
post Oct 10 2006, 18:07
Group: Members (Donating)
Dayumn. We like, couldn't call this 1.2 or 2.0, could we?
jcoalson
post Oct 10 2006, 18:15
FLAC Developer
http://flac.cvs.sourceforge.net/*checkout*...ease_versioning
Egor
post Oct 10 2006, 18:47
Great work, very cool!
QUOTE (changelog)
WAVEFORMATEXTENSIBLE channel mask is also saved to a tag on encoding and restored on decoding for situations when there is no natural mapping to FLAC channel assignments.
What is the tag name/format? (I couldn't find it in the new documentation.)
QUOTE (options - apodization)
The encoder chooses suitable defaults in the absence of any -A options; any -A option specified replaces the default(s).
Synthetic Soul
post Oct 10 2006, 19:08
Have you given up on the idea of -9 Josh?
(NB: I can compile this one smile.gif)
I'm on a horse.
haregoo
post Oct 10 2006, 19:23
1.1.3b1 consumes more bits especially on short sample(less than 30sec) than 1.1.2. I always use default setting(-5).
Is this because of redundant data for recovery?
jcoalson
post Oct 10 2006, 19:41
FLAC Developer
QUOTE (Egor @ Oct 10 2006, 12:47) *
QUOTE (changelog)
WAVEFORMATEXTENSIBLE_CHANNEL_MASK
right now, yes smile.gif but it may get smarter.
QUOTE (Synthetic Soul @ Oct 10 2006, 13:08) *
no, just saving it for something good (which I haven't come up with yet)
QUOTE (haregoo @ Oct 10 2006, 13:23) *
no, there's no redundant data, the only thing that should cause that is the new default padding size of 8k (was 4k in 1.1.2). is the difference more than that? you can always change the amount of padding with -P
Josh
P.S. the other thing that I would like to know is how good the --picture option is at automatically extracting the correct resolution/color info from gif/jpg/png files. if it chokes or gets it wrong, send me the file and I'll try to improve the detection code.
Josh
haregoo
post Oct 10 2006, 19:48
QUOTE (jcoalson @ Oct 11 2006, 03:41) *
"-P 4096" solves this and clear my doubts. Thanks.
Edit: This problem occurs only when I use flac.exe with foobar2000 0.9 pipe encoding.
This post has been edited by haregoo: Oct 11 2006, 04:55
.halverhahn
post Oct 10 2006, 20:18
Just a cosmetic difference: Encoding with option -V, Flac 1.1.2 outputs "Verify OK" V1.1.3b1 don't.
.halverhahn
madoka@ex-sounds
post Oct 10 2006, 21:35
Just one sample (CHOIR OF ALL SAINTS, HONIRA - Jisas yu holem hand blong mi / a cappella) is tested -8:
reference libFLAC 1.1.3-beta1 20061010 -> 8,983,544 Bytes (8.57 MB)
reference libFLAC CVS 20060425 -> 8,961,400 Bytes (8.55 MB)
more testing now...
Edit: dranken TYPO
This post has been edited by madoka@ex-sounds: Oct 10 2006, 21:40
<name>madoka</name>
<uri>http://codecs.ex-sounds.net/</uri>
Egor
post Oct 10 2006, 22:04
QUOTE (madoka@ex-sounds @ Oct 11 2006, 03:35) *
(new! smile.gif ) 1.1.3 uses 64k padding for audio longer than 20 min , and 8k padding for shorter samples, this may be the reason. Try removing all tags and metadata and then see the filesize difference...
skelly831
post Oct 10 2006, 22:41
wooyay! thanks Josh!
we was young an' full of beans
Wombat
post Oct 10 2006, 23:44
--best plays fine on my Squeezebox. Size is nearly the same as Garfs 1.1.2.1 build but somewhat bigger than flake -11
TBeck
post Oct 11 2006, 03:22
TAK Developer
I don't know, if this is the right place to post some compression results...
Participiants:
FLAC 1.1.2
FLAC 1.1.3 file flac-1.1.3-beta1-win.zip from sourceforge.
Flake 0.10 file flake-0.10-win32-i686.zip from sourceforge.
I have set the padding size for FLAC 1.1.3 to 4096 (-P 4096) to avoid an artifical compression penality compared to 1.1.2.
Test system:
P3-800 with a (slow) 40 GB HD.
            FLAC    FLAC  |  Flake |
            1.1.2   1.1.3 |  0.10  |
            -8      -8    |  -8    |
rw                        |        |
Ratio:      59.54   59.05 |  59.06 |
EncoTime:  280.47  285.75 | 133.57 |
songs                     |        |
Ratio:      51.35   50.61 |  50.27 |
EncoTime:  185.51  188.79 |  86.14 |
sh_2444                   |        |
Ratio:      60.28   59.59 |        |
EncoTime:   96.54   95.70 |        |
sh_2496                   |        |
Ratio:      57.92   56.21 |        |
EncoTime:  184.58  170.96 |        |
Ratio is the compression ratio in percent, EncoTime the duration of encoding in seconds.
For the test sets:
"rw" contains 46 files from http://www.rarewares.org/test_samples/.
"songs" contains CD-Ripps of the beginning of some songs.
"sh_2444" contains 5 files with 24 bit and 44 or 48 Khz.
"sh_2496" contains 6 files with 24 bit and 96 Khz.
Some remarks
Nice improvements for the first two sets. Contrary to my expectation, even "songs" (a set with slowly changing signal characteristics) benefited significantly from the optimizations of the compression efficiency.
And big surprise: Considerable improvements even for high resolution audio, especially for 24 bit / 96 KHz!
Congratualations!
jcoalson
post Oct 11 2006, 07:35
Post #15
FLAC Developer
QUOTE (.halverhahn @ Oct 10 2006, 14:18) *
thanks, fixed in CVS.
QUOTE (TBeck @ Oct 10 2006, 21:22) *
Some remarks
that is a nice surprise. thanks for the info, I don't have much 24bit material to test with. also, as you have already found, there are simple improvements to FLAC that can increase the compression further for hi-res samples but I didn't want to delay the release any further for them.
Josh
spies
post Oct 11 2006, 07:48
Post #16
I am having trouble creating binaries of FLAC 1.1.3 beta1 on Mac OS X.
I am running a 500 MHz G4 with system 10.4.8 and xcode tools 2.4.
Running ./configure on the FAC 1.1.3 beta1 directory, the terminal
spits this out after a while
checking for gas... no
/usr/libexec/gcc/darwin/ppc/as: I don't understand '-' flag!
Apple Computer, Inc. version cctools-622.3.obj~2, GNU assembler version 1.38
and then freezes. Works fine on the FLAC 1.1.2 directory.
Any suggestions would be appreciated. I would really like to try 1.1.3 beta1.
Keep in mind that I am fairly inexperienced when it comes to compiling.
Of course a location where I can get Mac OS X binaries would be great too!
jcoalson
post Oct 11 2006, 08:10
Post #17
FLAC Developer
yeah, I have not tried building it on my ibook yet so the tests for the assembler must not be up to date.
I think you can get past this problem by deleting line 22818 in configure:
test "$AS" = "as" && as --version | grep GNU >/dev/null && AS=gas
ffooky
post Oct 11 2006, 10:30
Post #18
QUOTE (jcoalson @ Oct 11 2006, 08:10) *
Doesn't do the trick (on my Intel iMac at least).
sshd
post Oct 11 2006, 11:05
Post #19
I get the following warning message on a 192/24/2 wave file created with wvunpack 4.2. Might not be a problem with flac, but thought I should mention it anyway.
options: --lax -P 8192 -b 4608 -m -l 8 -q 0 -r 3,3
02 The Carter Family.wav: WARNING: legacy WAVE file has format type 1 but bits-per-sample=24
Egor
post Oct 11 2006, 11:30
Post #20
QUOTE (sshd @ Oct 11 2006, 17:05) *
This is because your 24-bit audio is in WAVEFORMATEX instead of WAVEFORMATEXTENSIBLE.
WAVEFORMATEX does only support 8 and 16 bit resolutions, while some applications (like foobar2000) do use non-standard values.
See also WAVEFORMATEXTENSIBLE, output wav files topic.
probedb
post Oct 11 2006, 12:42
Post #21
Does this include the Winamp plugin, and has this been updated to use the Media Library yet or do I still need to install the patched 1.12 I have?
jaybeee
post Oct 11 2006, 13:17
Post #22
QUOTE (FLAC 1.1.3 beta 1 Changelog)
flac now supports FLAC as input to the encoder (i.e. can re-encode FLAC to FLAC) and preserve all the metadata like tags, etc.
^^ Excellent stuff Josh.
And of course the rest of it.
FLAC has always been my lossless format of choice. Glad to see there's still enhancements being made.
http://www.health4ni.com/
spoon
post Oct 11 2006, 13:49
Post #23
dBpowerAMP developer
Group: Developer (Donating)
Not technically true, Microsoft says an extensible should be used, not that is must be used. Programs were creating 24 bit wave files long before extensible was invented.
Spoon http://www.dbpoweramp.com
aharden
post Oct 11 2006, 13:57
Post #24
I have some 24/96/6ch music content that I had compressed with FLAC 1.1.2 level 8. Recompressing a 2 minute, 44 second track with 1.1.3b1 level 8, I got the following results:
PCM:
Bit Rate: 13824 kbps
File Size: 283 392 044 bytes
FLAC 1.1.2:
Bit Rate: 8938 kbps
File Size: 183 225 838 bytes
Comp %: 64.7
FLAC 1.1.3b1:
Bit Rate: 8545 kbps
File Size: 175 164 660 bytes
Comp %: 61.8
FLAC 1.1.3b1 improved compression by almost 3% on this material.
Thanks for the update, Josh!
This post has been edited by aharden: Oct 11 2006, 13:57
Alex Harden * http://alexharden.org
Speek
post Oct 11 2006, 15:06
Post #25
After installing FLAC 1.1.3 beta1 on Slackware (gcc 3.4.6) I tried recompiling vorbis-tools 1.1.1, but I get this error:
easyflac.o(.text+0x547): In function `EasyFLAC__init':
: undefined reference to `OggFLAC__stream_decoder_init'
easyflac.o(.text+0x1e1): In function `EasyFLAC__set_read_callback':
: undefined reference to `OggFLAC__stream_decoder_set_read_callback'
easyflac.o(.text+0x1f4): In function `EasyFLAC__set_read_callback':
: undefined reference to `FLAC__stream_decoder_set_read_callback'
easyflac.o(.text+0x221): In function `EasyFLAC__set_write_callback':
: undefined reference to `OggFLAC__stream_decoder_set_write_callback'
easyflac.o(.text+0x234): In function `EasyFLAC__set_write_callback':
: undefined reference to `FLAC__stream_decoder_set_write_callback'
easyflac.o(.text+0x261): In function `EasyFLAC__set_metadata_callback':
: undefined reference to `OggFLAC__stream_decoder_set_metadata_callback'
easyflac.o(.text+0x274): In function `EasyFLAC__set_metadata_callback':
: undefined reference to `FLAC__stream_decoder_set_metadata_callback'
easyflac.o(.text+0x2a1): In function `EasyFLAC__set_error_callback':
: undefined reference to `OggFLAC__stream_decoder_set_error_callback'
easyflac.o(.text+0x2b4): In function `EasyFLAC__set_error_callback':
: undefined reference to `FLAC__stream_decoder_set_error_callback'
easyflac.o(.text+0x2dd): In function `EasyFLAC__set_client_data':
: undefined reference to `OggFLAC__stream_decoder_set_client_data'
easyflac.o(.text+0x2ec): In function `EasyFLAC__set_client_data':
: undefined reference to `FLAC__stream_decoder_set_client_data'
easyflac.o(.text+0x56a): In function `EasyFLAC__init':
: undefined reference to `FLAC__stream_decoder_init'
collect2: ld returned 1 exit status
make[2]: *** [ogg123] Error 1
make[2]: Leaving directory `/tmp/vorbis-tools-1.1.1/ogg123'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/vorbis-tools-1.1.1'
make: *** [all] Error 2
Any idea what this is about?
Also when compiling mpd (music player daemon) I get an error:
In file included from inputPlugins/_flac_common.c:26:
inputPlugins/_flac_common.h:33:42: FLAC/seekable_stream_decoder.h: No such file or directory
inputPlugins/_flac_common.h:57: error: syntax error before "FLAC__StreamDecoderErrorStatus"
inputPlugins/_flac_common.c:190: warning: type defaults to `int' in declaration of `FLAC__StreamDecoderErrorStatus'
inputPlugins/_flac_common.c:190: error: syntax error before "status"
inputPlugins/_flac_common.c:192: warning: no previous prototype for 'flac_error_common_cb'
inputPlugins/_flac_common.c: In function `flac_error_common_cb':
inputPlugins/_flac_common.c:193: error: `data' undeclared (first use in this function)
inputPlugins/_flac_common.c:193: error: (Each undeclared identifier is reported only once
inputPlugins/_flac_common.c:193: error: for each function it appears in.)
inputPlugins/_flac_common.c:196: error: `status' undeclared (first use in this function)
inputPlugins/_flac_common.c:197: error: `FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC' undeclared (first use in this function)
inputPlugins/_flac_common.c:198: error: `plugin' undeclared (first use in this function)
inputPlugins/_flac_common.c:200: error: `FLAC__STREAM_DECODER_ERROR_STATUS_BAD_HEADER' undeclared (first use in this function)
inputPlugins/_flac_common.c:203: error: `FLAC__STREAM_DECODER_ERROR_STATUS_FRAME_CRC_MISMATCH' undeclared (first use in this function)
make[3]: *** [mpd-_flac_common.o] Error 1
make[3]: Leaving directory `/tmp/mpd-0.12.1/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/tmp/mpd-0.12.1/src'
make[1]: Leaving directory `/tmp/mpd-0.12.1'
Looks like a headerfile is missing?
This post has been edited by Speek: Oct 11 2006, 15:07
7 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 1st August 2015 - 12:35
