Strongest FLAC compression possible?, FLAC;compression;best compression
BFG
post Nov 24 2012, 03:13
Currently, I'm ripping my entire CD collection and compressing into FLACs. I'm interested in making the FLACs as small as possible and have no concern whatsoever for encoding time.
To achieve this, I'm currently using -V -p -l 12 -b 4096 -m -e -r 8.
(Those who use FLAC regularly will note these settings are even stronger than -8. I tried using -r 16 which the documentation states is supported, but anything over -r 8 caused an error in my tests.)
My question is: what settings, if any, would allow for even better compression?
saratoga
post Nov 24 2012, 03:17
You could try flake, or cudaflac. They might be able to squeeze a little more compression out.
BFG
post Nov 24 2012, 03:33
QUOTE (saratoga @ Nov 23 2012, 20:17) *
Thanks! I'm not interested in flake since the current version doesn't support metadata (though it'd be great to see the optimizations applied in the reference FLAC). And it's my understanding that "cuda flac" is a class of Nvidia GPU-based encoders. If so, is there a specific one you'd recommend?
skamp
post Nov 24 2012, 10:27
QUOTE (BFG @ Nov 24 2012, 03:13) *
FWIW, FLAC -8 is only 0.35% smaller than FLAC -5 on my music collection, and the difference between -8 and your settings is probably going to be a lot smaller than that. It's just not worth it.
Also, see FLACCL.
This post has been edited by skamp: Nov 24 2012, 10:28
lvqcl
post Nov 24 2012, 10:41
Also, see FLACCL.
This wiki page is a bit outdated: CUETools 2.1.4 contains FlacCL encoder ver. 0.4.
Porcus
post Nov 24 2012, 11:41
The metadata could of course be transferred to flake-encoded files afterwards, if you are a bit handy.
But those who are truly obsessed with compression, should maybe consider other codecs than FLAC, which was optimized for decoding speed. There is really no way to improve over FLAC without sacrificing some degree of compatibility, but if that is no issue, then ... TAK.
One day in the Year of the Fox came a time remembered well
IgorC
post Dec 1 2012, 19:08
Additional settings "-A tukey(0.5) -A flattop" should bring a bit more compression gain.
http://www.synthetic-soul.co.uk/comparison/lossless/
BFG
post Dec 3 2012, 18:21
QUOTE (IgorC @ Dec 1 2012, 12:08) *
Thanks for the suggestion. Not knowing anything about the different -A options, I've left it at default in the past. I don't suppose you're aware of a website that discusses the different algorithms in depth?
saratoga
post Dec 3 2012, 19:18
If this is for portable use, you may want to experiment with lossyflac, as it will remove some of bits wasted storing noise.
RSS Lo-Fi Version Time is now: 25th July 2014 - 19:33
